PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS! |
BMW Garage | BMW Meets | Register | Today's Posts | Search |
BMW 3-Series (E90 E92) Forum
rear-275/30/19--what size fronts do I go with?
Wheels and Tires forum Sponsored by The Tire Rack
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer |
10-26-2009, 11:39 AM | #1 |
Rep 2,000
I've been told 245/35/19, as well as 235/35/19...what does everyone here recommend?
This will be for a 2010 335i coupe with OEM M sports package. I will NOT be lowering. rims are 19x8.5 front 19x10 rear obviously im no tire/rim expert, and am hoping some of you can give better suggestions/advice on what set up to run with. |
10-26-2009, 11:53 AM | #3 |
Rep 957
Drives: 2022 X3 M40i
Too large of a rear tire versus the front tire will increase the car's under steer. I personally went with 245s in the front, but without trying 235s, it's hard to say if it will be a problem. I think the more tire the better.
10-26-2009, 03:20 PM | #5 |
171
Rep 2,057
You do not want to increase your staggered setup. We recommend to use a 245/35/19 front tire to match a 275/30/19 rear as long as the offsets allow it. What front offset are you going to be running?
10-26-2009, 03:36 PM | #7 |
Meat Puppet
66
Rep 1,127
Drives: '11 e90 M3 Competition
im rocking 245's front, 275 rear on my 08 e90 335i.
10-26-2009, 03:42 PM | #8 |
171
Rep 2,057
10-26-2009, 04:19 PM | #10 | |
171
Rep 2,057
19x10 ET +38 and a 275/30/19 on a E92 is not a combination that will be a guaranteed rub free. You`ll most likely rub with that setup although a slight fender roll could resolve that but it is not a setup that`ll guarantee no rubbing. About a 295 series tire only on an M3. Matt. |
10-26-2009, 05:04 PM | #12 |
Rep 29,202
I'd go with 235/35.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals | |
10-27-2009, 10:24 AM | #13 |
Rep 1,410
you can get away with 235 front (using 275 rear) if you find them cheaper but for handling/balance purposes you will definitely like the 245's better. Do you drive aggressively, like on a track? If this is your work car and grocery getter 235 is fine.
10-27-2009, 12:37 PM | #14 |
Rep 2,000
definately not on a track..its my daily driver...that I will push every now and then..... seems like 245 might be the way to go--Im not worried about the $ difference between the two, I just want whats going to be right, look right, and handle/perform right.
245 it is? |
