Tirerack
Use the following links to go directly to useful tirerack winter items: Tirerack Winter Tires. Gary's Winter Tire FAQ.
Using the links directly supports E90Post with tirerack sales commision!
  E90Post
The Tire Rack
   PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS!
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > LC Dyna's + Nexen 3000's + Stock Suspension = Rubbing ?
Wheels and Tires forum Sponsored by The Tire Rack
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer
Reply
      04-05-2010, 12:30 PM   #1
cisc0tek
Drives: 2007 335i Coupe
Several months ago I purchased a set of Dyna's from a board member who got them from Zoeb. They are your standard 235/30/19 and 265/35/19 et32 I believe with Nexen 3000's. A couple of months after putting the wheels on i noticed a rubbing sound in the front. I only hear it at low speed and during a turn (the worst is taxing through parking lots). I went to a tire shop and we jacked it up and found where the tire was coming into contact with the fender lining. Its on the front side and halfway back (center of the wheel). Does anyone know how I could be having this problem with wheels that are supposed to be a perfect offset with stock sport suspension?
Thanks -Jeff
      04-05-2010, 01:00 PM   #2
XYR03
Drives: Cayman S
Wow thoes shouldn't be rubbing at all...ur fender lining falling off?? i dought is the shape o the wheel.
[SIGPIC]2015-Cayman S (Can't leave bimmerpost)
2009-E92 M3
2005-E46 M3
1998-E36 M3
2007-E92 328i[/SIGPIC]
      04-05-2010, 01:05 PM   #3
Zoeb@WheelDude.com
Zoeb@WheelDude.com's Avatar
Drives: M3 (e92), X5 (E70), 428i (F32)
1995 BMW M3  [0.00]
2008 BMW M3  [8.00]
You shouldn't be running those tire sizes
Are you sure it's not a 235.35.19 / 265.30.19?
Also, they aren't made in ET32
Theres a +22 and a +37
If it's a +22, that's M3 offset and it might rub.
      04-05-2010, 01:33 PM   #4
cisc0tek
Ahh, I always get the profiles backwards. Yes they are 35F and 30R. Is there anywhere on the wheel itself I can see the offset ?
XY ...The lining looks secured ( I had a 540 where is was basically hanging by a screw, had to switch to M5 linings)
      04-05-2010, 01:35 PM   #5
Zoeb@WheelDude.com
1995 BMW M3  [0.00]
2008 BMW M3  [8.00]
yes, the offsets are stamped on the back of the wheel.
It will say eXX
Reply
e90post
