SUPPORT ZPOST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS! |
04-08-2010, 01:56 AM | #1 |
Rep 6
HID Problem
hey guys, I have a question about my lights, my left side went out so I replaced the bulb and the light worked and lastnight it went out again. I checked the bulb, ignitor and fuses. So I assume the only think left would be the ballast itself. I disconnected the plug from the connector and there was moisture in the plug, would this ruin the ballast? I'm guessing yes
Thanks in advance If so I can make an appointment to go into bmw beverly hills or if someone knows how to change the ballast and has one I would rather pay you instead of the stealship. |
04-08-2010, 11:01 AM | #2 |
Rep 96
I'd probably buy a headlight off of eBay and replace it with that. It will be a lot cheaper than going to the dealer and it's very easy to change out. All you need to do is remove a few screws to remove the bumper and 4 screws hold the headlight in place. The ballast is screwed onto the bottom of the headlight.
