BMW Garage | BMW Meets | Register | Today's Posts | Search |
BMW 3-Series (E90 E92) Forum
tyres
05-30-2010, 07:11 PM | #1 |
NM7
Rep 185
tyres
hi guys, I seen loads of post on tyres at present just wanted to get an indication of whats the best RFT to get. Everyone keeps hating on bridgestone due to the large amount of inner wear. i got a new set when i got the car 4 weeks agos just wanted some advice on what a good replacement RFT would be Pirelli Pzero seem to get a good review. I know most probabily would put non-runflat tyres.
Also what do you all recommend pressure wise on the tyre:255/30 R19 rear 225/35/19 front front: 2.6 bar rear 2,8 bar Thanks Neetin |
05-31-2010, 05:14 AM | #2 |
Rep 2,834
Neetin,
You're running an E92 right? ed's old motor? I too have an E92 335d M-Sport and I run 2.7Bar on the front and 3.2 on the back. These settings are basically square in the middle of the of the max-min loading values shown on the door sticker (which is a little cryptic to decipher). I find these settings offer predictable handling and hopefully as their higher than the min-loading value will help to counter some of the inner edge wear issues. I would say, experiment for yourself starting from the min-loading value (assuming it's usually just you in the car) and go from there. You will find a sweet spot where the car feels right as the tyre pressures affect the handling dynamics a fair bit IME. Let me know how you get on... |
05-31-2010, 05:35 AM | #3 |
Rep 898
Drives: F90 M5
I switched from Bridgestones to the Pirellis and found the ride to be more compliant (unless you hit a big pothole then it's just as bad). I'm still holding out for the new 3G Bridgestones that are supposed to be as comfortable as a regular tyre, but for the moment the Pirellis are the best choice (the P-Zeros, not the Eurforias).
F90 M5 (Marina Bay Blue, M Performance Parts)
Previous: F82 M4 / F20 125d M / E92 335i M Ind / E90 325i SE / E46 318i SE / E36 316i |
05-31-2010, 05:55 AM | #4 |
NM7
Rep 185
toxicnerve. I do have EDs old motor to be honest i cant fault the car just wanted some advice in which direction with regards to tyres theres soo many post about different pressure and tyres just bit confusing which way to go some ppl say run the rears 0.2 bar above recommended pressure and so on. Thanks for the advice though i just put pressure recommended pressure the other day might have to try some different valaues as you recommended.
thanks Neetin |
05-31-2010, 06:06 AM | #5 | |
Rep 6,912
I, for a long time, neglected to check pressures regularly on the Bridgestones and noticed inside wear on the rears - actually the dealer picked it up on the first service at 18k miles and tried to make me buy two new rears. I questioned the dealer and they suggested that 0.2bar over recommended pressures would help to counter the wear caused by 'aggressive set-up'. I did this, and checked pressures regularly and got another 6k miles out of the rears with no further inside wear, but did get even wear across the tread. Hope this helps! Ed
E92 M3, Jerez Black, Fox Red Novillo, 19'' M Double Spoke, folding mirrors, lumbar support, front seat heating, PDC, USB, DAB, EDC, Bluetooth, Logic 7, High Gloss Shadowline, big smile
05-31-2010, 08:27 AM | #7 |
Rep 2,834
05-31-2010, 09:22 AM | #8 |
The Tarmac Terrorist
951
Rep 29,345
Drives: 997.2 GT3
It snot BRIDGESTONE THAT INNER WEAR FFS.
997.2 GT3
05-31-2010, 10:33 AM | #10 | |
951
Rep 29,345
Drives: 997.2 GT3
Now this ''can be'' dialled out. I wouldnt personally though as the hhandling will be affected.
997.2 GT3
05-31-2010, 12:20 PM | #11 |
Rep 400
Drives: F30 LCI 330e M Sport
I'm running Nokian Z RFTs on my 320d in 225/45/17. Very compliant ride, much better than the Contis that came with car. I recently took a friend out in the car who's got a 320d MSport: he thought that they were non RFTs as they were so different to his Bridgestones. I'm also running +0.2 bar above min recommended pressures and check them every 10 days.
06-02-2010, 02:39 PM | #12 |
Rep 53
does anyone know if the 3rd generation bridgestone RFT's are available yet ? plus the price?
I cant really tell which edition each one is...Im in need of two rear tyres for my 335d. tyres look circa £270 each online from where ive looked. I was hoping these would be around the £240 mark |
06-02-2010, 04:13 PM | #13 |
Rep 3,923
the handling will also be affected when the cords are showing through on the insides of the tyres!!!
06-02-2010, 09:55 PM | #14 |
Rep 194
oh i didnt know that and im soon about to get a KDS realignment due to abnormal wear. is the handling effected that much? i dont go on track days at all so would it matter much?
06-03-2010, 07:04 PM | #15 |
Rep 540
Check out this stickied thread:
http://www.e90post.com/forums/showthread.php?t=381079 If you decide to go for RFT Bridgestones make sure you get the latest revision that have been updated to reduce inner edge wear.
Current: Skoda Octavia Scout 4x4 DSG
Previous: F30 318d Sport, R56 MINI Dooper 2010, E93 325i M-Sport auto 2007, E91 320d SE 2005, E46 318Ci Coupe 2002 |
