BMW Garage | BMW Meets | Register | Today's Posts | Search |
BMW 3-Series (E90 E92) Forum
660USD for front brake service (pads, rotors)!!!
07-15-2010, 07:20 AM | #1 |
Rep 6,311
Called in my dealer today. They gave me a quote on changing front brake rotors, pads and a sensor. Quote is around 660 usd.
An independent shop with non OEM parts (Brembo mind you) is around 300 usd. SO i'm facing a dilema. Should I change the bloody things at independent shop or at dealer? here's what I'm gonna pay for at dealer: - Brake disks -- USD 130 x 2 - pads (x4) -- USD 250 for pack that has 4 pads in it - sensor - USD 32 With work at around 80 bucks, it will be nearly 660 USD. Independent offers Brembo disks, Oem fitment, plus Brembo or Ferodo pads. All for around half that with labour. No mention of the frigin sensor though.... I thought if difference would have been around 100 bucks i'd go OEM route but twice the difference? What would you do? Is 660 for brake replacement makes sense? That sound like mighty expensive. PS: FAK YOU OEM WARPED ROTORS!
F30.F11.E86.E90.E90.E36 Last edited by Tallest; 07-15-2010 at 07:25 AM.. |
07-15-2010, 07:33 AM | #3 |
Rep 6,311
not sure about them being brembo but could be... i know that rims are thought by everyone to be BBS but actually they aren't all of them. Smaller sizes like 17s and all of 16s to the best of my knowledge are Borbets.
F30.F11.E86.E90.E90.E36 |
07-15-2010, 09:31 AM | #4 | |
Been there, wrecked that.
18
Rep 547
BMW Performance Brakes are the Brembo
-Brian
~199K miles. I -still- don't fear my 335i. |
07-15-2010, 09:39 AM | #5 |
Rep 6,311
so you reckon that taking the brembos instead of oem for 320d is actually a better bet? I dont know if they all weight differently or material is worse or better..
07-15-2010, 09:40 AM | #6 | |
18
Rep 547
A quick check shows ~$98 for a set of rear pads and ~$160 for a set of front. I didn't check Tischer, I would imagine they are even cheaper: http://www.getbmwparts.com/
-Brian
07-15-2010, 09:57 AM | #8 |
Powered By 36DD
337
Rep 7,369
life after warranty is a biatch................
2006 E90 330i Jet Black | 20" WORK VS-XX | FK452 | H&R Sport on Koni Yellow | REMUS QUAD
07-15-2010, 09:58 AM | #9 | |
Rep 6,311
07-15-2010, 10:10 AM | #10 | |
Rep 1,391
In any rate the front pad sets has 4 pieces, 2 pads to sandwich each rotor. |
07-15-2010, 10:18 AM | #11 | |
Rep 6,311
supposedly it contains some other crap, it's a 'kit'. :S pair of pads is around 50 bucks here from independent (brembo or ferodo, supposedly they think ferodo is better a bit).
07-16-2010, 02:18 PM | #13 |
2006 330i, TSM, Black, manual, sport
878
Rep 3,699
Drives: '17 C2, GTI, Z4 3.0si Racecar
I purchased the pads online and used stock rotors and sensors for my wife's '06 325xi. Totaly parts front and rear were about $550.
I did the install myself and saved $700 from what the stealership wanted for the parts and labor. It's not too difficult to do yourself. The first wheel will take a while, but the second one goes much quicker once you get the hang of it. Biggest bitch is installing the pads into the piston.
2017 Porsche C2 - manual of course
2015 GTI S 2008 BMW Z4 3.0si Coupe - because racecar |
