E90Post
Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Alignment
Reply
      07-21-2010, 01:38 AM   #1
jacky822
jacky822's Avatar
48
Drives: E60 M5
Question Alignment
I went to a alignment shop the other day, and wanted to have the front camber more negative and the shop told me that there are no ways to do anything on oem front camber settings. Is it ture?
I have an E92 335i
      07-21-2010, 02:01 AM   #2
LOLrance
The Law.
LOLrance's Avatar
Taiwan
301
You can drill out the alignment pin to get slightly more camber. If you want more without getting full on camber plates, you could also get m3 wishbones, and dinan "camber plates" (which aren't really camber plates, they just offset the mounting points on the strut for another -0.5 degrees)
      07-21-2010, 09:15 AM   #3
David1
David1's Avatar
Drives: 09 E92 09 X5
Even taking out the pins won't get you much more. If you get camber plates on stock suspension, you will probably increase the ride height depending on brand/style. Easiest way to gain some negative camber up front is to install the M3 control arms.
2021 M2 Comp Sunset Orange |Black with orange Stitching Dakota Leather|Executive Pkg|DCT
      07-21-2010, 12:07 PM   #4
zsapphire7
zsapphire7's Avatar
Drives: 08 e92 M3
yes they are right. get some camber plates
Reply
e90post
