BMW Garage | BMW Meets | Register | Today's Posts | Search |
BMW 3-Series (E90 E92) Forum
ID this sway bar (Pic)
07-25-2010, 06:12 PM | #1 |
Rep 10,309
Drives: A///MERICAN!!!
Got my car up on the lift to see if I could get a name off the sway bars that are causing problems on my car...couldn't see anything. Here's a pic I snapped, but haven't found any in this finish (light silver) looking at vendors websites. Anyone have any ideas? (Totally slipped my mind to measure diameter - sorry)
Thanks, Brian |
07-26-2010, 08:45 AM | #2 |
Rep 10,309
Based on color alone, I have ruled out:
Eibach (red) Hotchkis (blue/gray or red) H&R (black) RDSport (green) The only one I've found that is similar in color is the UUC...odd I would be having problems since I usually hear great things about UUC [img]http://www.**********s.com/zoom_img/_1236602166.jpg[/img] |
07-26-2010, 10:20 AM | #3 |
Rep 1,288
Drives: 135i
My UUC is grey..... Problems? What problems? My endlink basically shattered once and I had a bushing come loose, but that was because a moron (i.e. me) installed it.
Performance: UUC Sways CDV Mod KW V3 Vorshlag plates Pagid Yellow VK OC Hotchkis Brace STETT IC/CAI Braille B2015 VK Catless DP BMS JB3 M-Tech
#1 Mod: AutoX/HPDE HPDE 3 Many Thanks: **********s UUC Motorwerks VK Motorwerks HP Autowerks SOLD |
07-26-2010, 10:44 AM | #4 |
Rep 10,309
It is audibly hitting my tie rod and once warmed up becomes very squeaky, this is the only aftermarket suspension component so I am hoping switching to the M3 bar will alleviate this.
07-26-2010, 05:43 PM | #5 |
Rep 1,288
Drives: 135i
Lube the bushings.... Also, I think I remember hearing that a lot of people install them upside down by accident somehow?
07-26-2010, 09:40 PM | #6 | |
Rep 10,309
Lubing the bushing may help the squeaking but the main factor is the knocking against the tie rod - this may not be terrible but can't be good. I've already ordered a new front bar so that's all moot, just curious to see if anyone knew what this one was - maybe it will have a stamping once I take it off. |
07-27-2010, 03:21 AM | #7 |
Supreme Allied Commander
3847
Rep 54,376
Drives: F80 M3
Location: Santa Barbara, AP, Brembo, GIAC, Koni, Ohlins, Performance Friction, www.hpautosport.com
Agreed. Looks like the UUC bar. You will find the rear to be too stiff and may want to go with something a bit smaller.
The M3 convertible front bar may be a good choice with the UUC rears on the softest setting. |
07-27-2010, 08:20 AM | #8 |
Rep 10,309
How easy is it to adjust the rear settings?
Please let me know if my thought process is flawed. I'm putting on the M3 front bar, which assuming it's softer, will increase increase grip at the front relative to the rear and the car will have more of a tendency to oversteer? |
07-27-2010, 10:54 AM | #9 | |
3847
Rep 54,376
Drives: F80 M3
07-27-2010, 12:04 PM | #10 |
Rep 10,309
Other than the sways I have regular ZSP suspension, after I change the bar I will get an alignment. I guess I'll just have to wait and see
