E90Post
Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Alignment needed if installing wheel spacers?
Reply
      08-03-2010, 02:41 PM   #1
BimmerPod
Drives: e92 335i, f85 x5m
I am finally getting rid of my RFTs, and while I'm at it, I figured I'd install some spacers (conservative, 5mm front 10mm rear). Would that require an alignment job? tia!
      08-03-2010, 03:01 PM   #2
mike-y
just another bmw douche bag
Drives: 1.9L of fury
spacers should not change your alignment. just make sure all the mating surfaces are clean and free of debris before you put them on. it's a good idea to go over everything with a wire brush before installing.
      08-03-2010, 03:42 PM   #3
ianbiz
Back in a BMW
ianbiz's Avatar
Drives: 2015 335i Msport
agreed. while technically wont change the alignment, it will def. add a bit more camber
Ian
      08-03-2010, 03:52 PM   #4
mike-y
No, they won't add camber at all. technically, changing camber would be changing the alignment
      08-04-2010, 05:58 AM   #5
ALPINA2BMW
Drives: M2 Competition
Just a note of caution when fitting 5mm wheelspacers. When I fitted these to the front wheels of my e90, there was a certain amount of vibration speeds above 30mph; the OEM hub centric lip does not appear to be long enough to centre the wheel perfectly. I'm not sure if the OEM hub centring lip is tapered or not?
This is a shame as the 5mm spacer with stock 8 x 19 (ET37) rims is a decent subtle modification.
Does anyone else have this issue?
Reply
e90post
