BMW Garage | BMW Meets | Register | Today's Posts | Search |
BMW 3-Series (E90 E92) Forum
Wheel alignment & BMW Performance Suspension
08-13-2010, 08:14 PM | #1 |
Rep 17
Can I ask what should be the alignment settings on an e92 if it is fitted with the BMW Performance Suspension.
My car has the following setting at the moment. Are they correct? Front: Toe - neutral Camber - neutral Rear: Toe - neutralCamber - negative 1.5 deg ( is this too much or should be 1 deg?) What does BMW recommends? Some say all BMW cars in stock form comes with some Toe 'in' esepcially the rear. If that is the case, how much toe should be dialled? Appreciate some guidance. |
08-19-2010, 08:14 AM | #3 |
Rep 17
Thank you.
Is that the setting we get in our BMW when we first got our cars. I asked around and some say there is no toe at all in the stock setting while that are some that say it has(such as your description). Am terribly confused. |
