BMW Garage | BMW Meets | Register | Today's Posts | Search |
BMW 3-Series (E90 E92) Forum
will changing sway bars void my warranty?
08-23-2010, 01:42 PM | #1 |
AC Schnitzel
85
Rep 546
im thinking of installing these UUC sway bars for my 325xi..wondering if anyone knows or thinks doing so could possibly void my warranty? any help is appreciated
08-23-2010, 01:45 PM | #2 |
I ask the questions you're afraid to ask.
44
Rep 2,489
In general, no single mod will "void your warranty" but any mod may lead the dealer to refuse warranty service on a failure if they believe that the failure was caused by that mod.
For sways, that would include any suspension related issues |
08-23-2010, 01:46 PM | #3 |
Rep 660
It won't void your entire warranty, only the portion of warranty related to the sway bars which is very limited and comprised of components that rarely fail anyway. It should'nt be an issue. Also keep in mind that the rear sway bar is fairly labor intensive to install, it requires lowering the rear subframe.
08-23-2010, 01:48 PM | #4 |
Rep 10,309
Drives: A///MERICAN!!!
On the contrary, the M3 bars look stock enough to get overlooked quite often...
08-23-2010, 01:51 PM | #7 |
Moderator
618
Rep 10,855
Use BMW sways and you should be OK.
My recent ED photos: http://f80.bimmerpost.com/forums/sho....php?t=1026808
my not-so-recent ED: http://www.e90post.com/forums/showthread.php?t=31829 Please join BMWCCA http://bmwcca.org/index.php?pageid=c...&ref_by=300279 |
08-23-2010, 01:55 PM | #8 | |
AC Schnitzel
85
Rep 546
the only way they can void it is if i try to claim something under warranty and they can prove that it is caused by the aftermarket part (ie. suspension issues) but they cant just decide to void the warranty if i just bring my car to the dealer one day and they happen to see it there while doing seasonal maintenance not related to it at all (ie. oil change)?
08-23-2010, 02:20 PM | #10 | |
44
Rep 2,489
In general, warranties don't get "voided," but the dealer refuses warranty service on a particular failure. While the mere presence of an aftermarket sway bar won't cause you issues during routine service, nothing stops the dealer from noting your modification in their computer. That may cause you problems in the future if you have suspension issues. Sway bars often cause noise issues and will wear your suspension components faster. On a side note - there is a whole other discussion on the benefit of larger sway bars (especially for an xi) and, quite simply, you'd be better off spending the money on a performance driving class than adding a sway bar - but the driving school won't look as cool in your sig line. |
08-23-2010, 02:21 PM | #11 |
Rep 5,660
I don't know much about sway bars, but they sound like they are something that's pretty integral to the suspension system of the car. I do know about warranties and the legal aspects of them. If the sway bars you want to put on the car aren't the ones that came with the car or that were put there by a dealer to repair/replace any original sway bars, your installation of the new sway bars will minimally void any part of the warranty that covers any and all things that could possibly be related to the installation of said bars. Depending on the terms of the warranty, such an action could void the whole darn warranty.
The rationale for this is that the installation of substantial parts and components creates a plausible/debatable case that the new sway bars effect changes in some behavioural aspect of the car (too much vibration, not enough vibration, sharper vibrations, increased vibrational transference to this or that bit of the vehicle resulting from the greater rigidity, etc.) which in turn caused the failure of thus and such a part. The fact is that dealers generally have no incentive to give you the benefit of any doubt when it comes down to their having to potentially provide you with something for free. But then, maybe you buy a dozen cars from your dealer each year and so they have a reason to give you some benefit of the doubt as goes the latter scenario I mentioned. The former scenario nonetheless describes a very risk you face should you opt to replace your sway bars.
Cheers,
Tony ------------------------------------------------------------------------------------------ '07, e92 335i, Sparkling Graphite, Coral Leather, Aluminum, 6-speed |
08-23-2010, 02:24 PM | #12 |
AC Schnitzel
85
Rep 546
so as a followup i just spoke to a dealer and they said that it will only void the warranty on the actual sways and bushings and not the entire car/suspension
08-23-2010, 02:25 PM | #13 | |
Rep 5,660
I mean lets face it, we are talking about sway bars not floor mats.
Cheers,
08-23-2010, 04:04 PM | #14 |
44
Rep 2,489
08-23-2010, 06:12 PM | #15 |
Rep 15,818
This.
You have a very nice dealer. As stated, a Perf. class will go along way. I don't know for your car, but if you car is 2 tons like mine.. sways bars (specifically front) will increase handling phenomenally.
08-23-2010, 06:31 PM | #16 |
Rep 10,309
I'm assuming they mean the actual sway bar bushings - not every bushing on the suspension. AFAIK changing the sway bars requires changing the bushings anyway, so really the only parts they won't warranty are the non-oem parts, which is good news. I believe most aftemarket bars come pre-packed with bushings. My M3 bar required different bushings, and the UUC I took out had pre-packed bushings, so you are in the clear there. Just don't be an idiot like me and install the bar upside down the first time! (Won't be a problem if you get one with pre-packed bushings)
08-23-2010, 09:59 PM | #17 |
Modder Raider
753
Rep 8,633
Drives: M3
Actually, the e93 bars are thicker, but be careful. Thicker isn't necessarily better.
Put a huge bar up front then you will understeer like crazy. Put a huge bar in the back with no suspension components to go along with a stiffer bar and you will snap oversteer. If you don't track and just want it for looks or changing lanes on the street then you might as well not go with OEM. I have the e93 M3 bar up front and the e92 M3 rear bar.
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
08-24-2010, 09:04 AM | #18 | |
Rep 859
2007 335i SG Coupe
2009 128i AW |
08-25-2010, 04:45 PM | #19 | |
AC Schnitzel
85
Rep 546
