BMW Garage | BMW Meets | Register | Today's Posts | Search |
BMW 3-Series (E90 E92) Forum
Help with KW V1 Setup.........Updated with pics!
09-08-2010, 10:55 AM | #1 |
Rep 116
Just installed a KW V1 setup on my E90 335XI. Im not sure if its a problem but I have the front spun all the way down and there still seems to be a significant gap. From the center of the wheel to the lip of the fender well is 13.5. The rears are spun down half way and I have 12 7/8 - 13 to the lip. I was hoping with this kit i would be able to have the front sit a little bit lower that the rear not the other way around. Any advise suggestions appreciated.
Front Rear Last edited by msp116; 09-08-2010 at 11:47 AM.. |
09-15-2010, 12:09 PM | #5 |
Rep 2,007
looks to me like you have the front set at the highest level possible (as in the car is not lowered at all) someone correct me if i'm wrong, but you need to compress the springs for the car lo go lower and that picture shows no compression of the spring at all. |
09-15-2010, 01:31 PM | #6 | |
Rep 411
09-15-2010, 02:19 PM | #7 |
Rep 420
Drives: 2011 e90 335 ix, 08 335i e92 6
keep in mind...smaller spring lower it goes...extend the spring and higher it goes...
09-15-2010, 03:23 PM | #8 | |
just another bmw douche bag
195
Rep 3,640
the spring shows no compression because he's jacked up the car and took off the wheel, allowing the suspension to sag. This type of coilover does not use preload and adjustable shock bodies to change height. It's a simple adjustable spring perch only. lower the spring perch, and you lower the car (because the spring sits lower on the shock body, and everything else is unchanged). |
10-11-2010, 04:17 PM | #10 |
Rep 1,558
Its the complete opposite of this statement. You have it set to the lowest setting. Let it settle for a few days or week and then measure it again.
Sport pack, JB3, Dci, factory oil cooler, 18" M3 reps, Michelin PSS, painted trim, black grills, smoked side markers, LED plate lights, H&R coils, Borla catback |
11-16-2010, 02:01 AM | #11 | |
Rep 767
04-05-2011, 04:53 PM | #13 |
195
Rep 3,640
I can't tell if that is the highest setting, but it is raised above the lowest position. If you adjust the collar up, so that the purple spring seat touches the top lip of the black upper mount, you will lower the car.
Keep in mind this works the opposite way of the front, where you would lower the collar to lower the car. |
05-19-2011, 12:17 PM | #14 |
Rep 247
So did you go lower at all? Im thinking about getting V1 but if thats the lowest setting thats not gonna cut it for me.
05-19-2011, 01:20 PM | #15 | |
Rep 4,784
Plus op has an xi. those always ride a bit higher.
ERnie
2016 BSM/f80/ZCP |
05-20-2011, 07:43 AM | #16 |
Rep 727
Drives: 2010 E91 328i xDrive 6MT
05-20-2011, 07:44 AM | #17 | |
Rep 727
06-03-2011, 11:16 AM | #18 |
Rep 93
Question for OP.
Did your setup settle to your liking? I've noticed this in some pictures people have posted after coilover installations and I'm hoping to learn from you experience since I'm in the market. |
06-05-2011, 11:04 PM | #19 |
Pro Hater
49
Rep 1,717
I am also not happy with the lowest setting on my KW V1s for xDrive.
I think it may be an xDrive specific issue, because OEM xDrive suspension sits 0.5-1" higher. So when you lower 2" from stock xDrive, it's not as low as if you lower 2" from OEM sport suspension. |
06-06-2011, 11:08 AM | #21 |
Rep 4,771
Wow... definitely not set to the highest setting... it's a very simple system. You adjust the spring upwards and the car gets higher, and vice verse. Some of you guys are very wrong. I am surprised that you car isn't lower though. My coilovers are adjusted only halfway down and the car sits really low
