2010 2011 BMW 5 Series Forum F10
2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums Regional Forums UK 520d SE Auto Sport
      08-08-2011, 11:15 AM   #1
blaz
blaz's Avatar
Drives: F10 520d,F30 330e,G20 M340i
520d SE Auto Sport
due tomorrow
http://f10.5post.com/forums/album.php?albumid=4855
Sophisto Grey 2 / Oyster / Black Dakota (std) Leather
Auto Sport transmisison
Variable Damper Control
Active Steering
Dynamic Pack with W type 332 19" wheels
Visibility Pack
Air Con Extended features
Grey Windscreen ShadeBand
Delete Smoker Pack
Model Delete
USB audio something..
Fold Dim Ext Mirrors
Lumbar Support
      08-09-2011, 02:09 AM   #2
blaz
blaz's Avatar
well - it's here - first impressions count and it looks the business.
arrived 8am on a trailer which seemed respectful but (100+ miles on the clock)
wanted the mirrors to auto fold - and they do if you hold down the badge to lock
see you later!
      08-09-2011, 03:25 AM   #3
Jon D
Jon D's Avatar
Scotland
224
Drives: 2022 840d
see you later!
100+ miles on the clock? What was the dealer's explanation? Personally speaking, I would find that unacceptable on a new car and I wouldn't have taken delivery.
      08-09-2011, 04:07 AM   #4
xenon
xenon's Avatar
England
1397
Drives: 2021 G21 330i M-Sport
Nor I. Nevertheless, enjoy your car.
Ian
Current: 2021 G21 330i M-Sport
Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2
      08-09-2011, 05:22 AM   #5
blaz
blaz's Avatar
oops - at ease - when I got back in I realise that was the range.. there were 10 miles on the clock...
      08-09-2011, 05:24 AM   #6
xenon
xenon's Avatar
England
1397
Phew. Mind, I'd be pissed off with such a low amount of fuel too!
Ian
      08-09-2011, 05:31 AM   #7
blaz
blaz's Avatar
brain dumping for now... need to do some work....
100 miles covered this morning - suitably impressed I have to say with my first BM.
After playing have set sport setting to chassis only for now which I find very comfortable, no steering vagueness that others reported, good for handling, and gives the 8th gear economy. Plan would be to go manual or to reactivate drivetrain settings on the fly when needed or go the whole sport+ hog. Early days, early thoughts.
Interested that I couldn't connect the bluetooth audio and USB phone audio interface with my (i)phone(4) at the same time so that I could swap easily - but as I'm getting album artwork (even without a Nav package) and steering wheel controls and charging plugged in the I can do without the bluetooth stream (although its a cool feature).
I tried to open a conference call and found that the DTMF(?) tones for the pin number didn't work. Is that either expected or switchable?
Lots of nice glances at the car
      08-09-2011, 05:32 AM   #8
blaz
blaz's Avatar
Lease co policy is more than a tenner in the tank - probably screwed on price..
      08-10-2011, 03:56 AM   #9
blaz
blaz's Avatar
Well 250 miles so far and smiling - a lot
So many questions - so little help in the owners manual though. Some things are in the onboard version - others I'll have to try and work out.
First of all my initial thoughts on my spec
Sophisto Grey 2 - hit!
Oyster / Black Dakota (std) Leather - hit!
Auto Sport transmisison - hit!
Variable Damper Control - no idea - but very happy with the ride and handling in sport
Active Steering - no idea - but very happy with the handling and turning circle
Dynamic Pack with W type 332 19" wheels - lovely but made to look small by the arches
Visibility Pack - not convinced that i have active lights or beam assist yet - maybe it was too light to notice so far
Air Con Extended features - auto recirc hit!
Grey Windscreen ShadeBand - really? well if I look closely...
Delete Smoker Pack - surely they can package a non-ashtray and the front stow area more usefully?
Model Delete - i like it - some won't
USB audio something.. was worried about this one without Nav - good for iphone
Fold Dim Ext Mirrors - hit! foldy mirror look I like
Lumbar Support - getting old!
      08-10-2011, 04:41 AM   #10
blaz
blaz's Avatar
So questions I will research include already..
- why does the radio continue until you close the door? I play too loudly for that
- why is there an aircon timer?
- what are additional indicators?
- where is the residual heat function?
- how much @ how fast does speed related volume setting change?
- when I voice dial - is the phone or the car phone book answering?
- what are the auto relock scenarios and dangers?
- how I lock the car when I'm in it without getting the key out?
- can I unlock the other doors when I pick someone up without getting key out?
- why did the passenger seat back suddenly 'unrecline' with no-one in it??
- what does SPORT drivetrain consist of if I deselect it?
- why is there a pimple on the centre screen right hand plastic bit??
- is S/W 003.004.037 (or was it 031?) the latest?
- how can you get back to S(7) after manually overriding to M(8)?
- data transferring from device seems confused with some other data option?
further thoughts
- yes go for chassis only in SPORT (allowing for D8) and move gear lever to left when S7 required
      08-10-2011, 04:42 AM   #11
blaz
blaz's Avatar
yep - I am
      08-10-2011, 06:09 AM   #12
Jon D
Jon D's Avatar
Scotland
224
Drives: 2022 840d
Haven't noticed that - sorry, can't help
I think that's what previously was known as Residual Heat, but now with a timer
Pass
See above
Never noticed it changing, so it must be pretty good
Pass
Pass
Press the button between the centre face level vents
As above
You had the Invisible Man in the car
It depends on whether or not you have Adaptive Drive and what option you select - 'Chassis only' alters roll bars, dampers, and steering response. 'Drivetrain only' alters throttle and shift response and restricts 8th gear. Personally, I have sport configured to chassis only and when I want the lot, I select sport+
It's a camera linked directly to BMW to see how often you pick your nose
Pass
You have to move the gear selector sideways
      08-10-2011, 06:52 AM   #13
blaz
blaz's Avatar
ah - found in manual it is to open the airvents for cooling
Pass
ah - found it is the right side of the fan button on the driver side and works if under 25 degrees outside
Never noticed it changing, so it must be pretty goodagree
Pass
Pass
Press the button between the centre face level ventsthx
As abovethx
You had the Invisible Man in the carlol
It depends on whether or not you have Adaptive Drive and what option you select - 'Chassis only' alters roll bars, dampers, and steering response. 'Drivetrain only' alters throttle and shift response and restricts 8th gear. Personally, I have sport configured to chassis only and when I want the lot, I select sport+great thanks - not explored sp+ yet - so selecting S on gear lever when wanting that - which suggests I have all of the sport features then - which is what I hoped - although VDC and active steering may or may not dilute that
It's a camera linked directly to BMW to see how often you pick your noseoops
Passit is 031 - not checked if latest
You have to move the gear selector sidewaysand then back again to get to S7 then
      08-10-2011, 06:53 AM   #14
xenon
xenon's Avatar
England
1397
The radio continues unless you press the Start / Stop twice (one to stop engine; one to switch off accessory circuit). However, if you lock the car then the radio etc. will go off.
Additional indicators - I'm guessing you mean the setting that pressing the indicator against the pressure without going over-centre, will flash the indicators three times for lane changing.
Voice Dial - Your contacts are transferred from the phone to the car and the car synthesises the dial commands from the address book (*at least with Pro Media)
Auto Relock - if you open the car with the fob but don't open the door within two minutes the car will relock itself. Good idea should the unlock be accidentally pressed in your pocket whilst inside and the car on the drive, say.
"Pimple" near the screen is a light-dependent resistor to dim or brighten the screen depending on ambient light.
Ian
      08-10-2011, 06:53 AM   #15
blaz
blaz's Avatar
apparently I have it on the correct =)A setting - so we'll see
      08-10-2011, 06:55 AM   #16
blaz
blaz's Avatar
bluetooth stream would be nice on short / broken trips though...
      08-10-2011, 06:59 AM   #17
blaz
blaz's Avatar
hi Ian
The radio continues unless you press the Start / Stop twice (one to stop engine; one to switch off accessory circuit). thx However, if you lock the car then the radio etc. will go off.
Additional indicators - I'm guessing you mean the setting that pressing the indicator against the pressure without going over-centre, will flash the indicators three times for lane changing.think that is separate - think it is about showing them again in the instrument panel??
Voice Dial - Your contacts are transferred from the phone to the car and the car synthesises the dial commands from the address book (*at least with Pro Media) ok thx - explains why my normally working dulcet tones need some attention
Auto Relock - if you open the car with the fob but don't open the door within two minutes the car will relock itself. Good idea should the unlock be accidentally pressed in your pocket whilst inside and the car on the drive, say. thx
"Pimple" near the screen is a light-dependent resistor to dim or brighten the screen depending on ambient light. at least it was until I touched it - thx
      08-10-2011, 07:06 AM   #18
xenon
xenon's Avatar
England
1397
You've confused me now with the additional indicators as I don't know what you mean...
Ian
      08-10-2011, 07:08 AM   #19
Jon D
Jon D's Avatar
Scotland
224
Drives: 2022 840d
That's what I initially thought, but nothing happens to the screen brightness when you cover it with your finger.
This has been previously, and equally inconclusively, discussed in another thread.
      08-10-2011, 07:13 AM   #20
xenon
xenon's Avatar
England
1397
It does if it's dark (i.e. the screen has already switched to night mode which it does by virtue of the sensor for the auto headlights).
If the screen is in night mode (i.e. the colours have all changed), and you cover the pimple completely, it goes very dim in the night mode colours.
Ian
      08-10-2011, 07:16 AM   #21
Jon D
Jon D's Avatar
Scotland
224
Drives: 2022 840d
Ah-ha, sounds like there's a conclusion after all - not that I'm doubting you, but I'll try it out next time I'm driving at night.
      08-10-2011, 11:17 AM   #22
blaz
blaz's Avatar
erm - I needed to set the indicator stalk button to =)A as well - try that later...
5post
