BMW Garage | BMW Meets | Register | Today's Posts | Search |
BMW 3-Series (E90 E92) Forum
I got stuck.. shock removal
01-01-2012, 07:24 PM | #1 |
Rep 842
Could you guys give me some tips here. I'm trying to remove the front nut on my strut assembly but I can't get it to move anywhere. When I use my breaker bar the whole assembly just twists.
I had the idea to remove the whole assembly, then put it in a vice to remove but I can't even get the assembly out nor do I have a vice :P Any ideas for me? How to remove the top nut and/or how to remove the whole assembly? Thanks guys.
2006 325i: Matte Black Grills, AG m310 19's (19X8.5et35 & 19X9.5et33 - 235/35/19 & 265/30/19), Amber Covers, Magnaflow with black tips, Blacked Emblems, M3 Replica Bumper and Vorsteiner hood! |
01-02-2012, 07:55 PM | #3 |
Rep 842
Me no have impact but I've been looking for a set. Any recommendations?
And I ended up getting the top nut off but now the strut is still stuck. I got one out by hammering the crap out of it. Is there a better way? Or a good way to put them back in?
01-02-2012, 08:05 PM | #4 |
Rep 7,089
Drives: '06 AW 330xi
How would an impact gun work on the shock cylinder? It will just rotate...
You have to grab the cylinder with something. I can normally just get it off by using my hand to clamp it and unbolt the nut. You should have the spring compressed when your doing this. |
01-03-2012, 12:24 PM | #6 |
just another bmw douche bag
195
Rep 3,640
an impact does work for the top nut. but you can use regular tools if you remove the whole assembly out of the car first. if you have a hard time spreading the pinch collar at the bottom of the strut, grab a 1/4" to 3/4" socket adapter and slip it in the gap, then turn it a quarter turn with your ratchet. you can pull the strut out pretty easily after that, though expect to ruin the adapter after a few uses.
