BMW Garage | BMW Meets | Register | Today's Posts | Search |
BMW 3-Series (E90 E92) Forum
Sway bars, are they worth it?
01-19-2012, 04:11 AM | #1 |
Rep 394
I have a 2008 335i sedan lowered on Koni FSD and Eibach pro springs. I am considering getting a sway bar kit (maybe eibach or hotchkis). I don't do many track runs - hopefully this summer tho. Is it really with it? Does it make enough of a difference to justify the $500?
2008 Monaco Blue/Tan interior 335i sedan. Mods: AFE intake w/ scoops, AFE Exhaust, ER FMIC, Koni FSD/Eibcach Pro-Kit, Breyton Race GTS wheels w/ Continental ExtremeContact DW tires, Cusco OS strut bar. BavAuto Black/Beige seat covers w/ black floor mats, M3 rep trunk lip, eBay front splitters.
01-19-2012, 05:12 AM | #2 | |
Rep 1,727
Hiatus |
01-19-2012, 08:11 AM | #3 | |
Rep 1,160
Your life is greatly improved w/flat cornering; a suddenly very cohesive rear with all your ponies getting power to the ground. Sex is better. Food tastes great! Careful: Your smile may blind oncoming traffic.... Last edited by CALWATERBOY; 01-19-2012 at 12:13 PM.. |
01-19-2012, 10:45 AM | #4 |
Rep 2,556
I wouldn't. No LSD=leave sway bars alone..
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS |
01-19-2012, 01:48 PM | #5 |
Rep 394
Thanks for the help. I was planning on getting an LSD soon, so I think the best plan is to wait until after that at least. I want to make sure that when I start upgrading the horsepower that it transfers to the pavement efficiently. After LSD is COBB AP and FMIC!
01-19-2012, 07:30 PM | #6 |
Rep 632
I would more likely to get rear sway first.
Front is not that necessary. BTW, LSD is a great upgrade, I will do it when I get my money. Front<Strut<Rear<LSD |
01-19-2012, 10:09 PM | #7 |
Rep 4,109
Drives: BMW M3
Unless you have an LSD as noted, don't do the rear sway. You will be worse off in turns. The inside wheel gets nearly all of the power in a tight turn because of that open differential; a thicker rear sway will actually lessen the grip and you'll have even less 'push' going through.
FYI rear sway = drop the subframe, which is very expensive. Do it at the same time as LSD + subframe brushings.
2024 BMW M3 Sedan Frozen Pure Grey II/Fjord Blue, 6MT
Past: 2021 Z4 M40i Frozen Grey II/Black Alcantara | 2017 F30 340i Mineral Gray/Coral Red, 6MT | 2011 E92 335i Le Mans Blue/Black, 6MT |
01-20-2012, 08:28 AM | #8 | |
Rep 632
hmm, sounds |
01-20-2012, 08:58 AM | #9 | |
Rep 1,160
A macabre device programmed for your vexation, rear brake shoes disappear long before fronts, all the while providing inferior performance and feel. The engineers responsible for that should be outed and forced to view every minute of every Oprah every day. Take the cure! Wavetrac or Quaife for street duty, and you may thank GOD for that! . Last edited by CALWATERBOY; 01-20-2012 at 04:51 PM.. |
01-20-2012, 11:04 AM | #10 | |
Rep 1,244
