Tirerack
Use the following links to go directly to useful tirerack winter items: Tirerack Winter Tires. Gary's Winter Tire FAQ.
Using the links directly supports E90Post with tirerack sales commision!
  E90Post
The Tire Rack
   PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS!
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Rubbing Passenger side Oil Cooler
Wheels and Tires forum Sponsored by The Tire Rack
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer
Reply
      04-22-2012, 03:41 PM   #1
justaguy
Drives: 335xi coupe
I recently changed my tires from 225/35/19 to 235/35/19, and i'm getting rubbing on the passenger side wheel well where the oil cooler trim is.
The wheels i'm running are 19x8.5, and i know this is a pretty common tire and wheel combo.
Anybody have this issue?
I have a 2008 E92 XI with m sport.
      04-22-2012, 04:27 PM   #2
bmw325i
Drives: 2006 BMW 325i
Offset?
      04-22-2012, 05:53 PM   #3
justaguy
Drives: 335xi coupe
30 offset
      04-22-2012, 05:57 PM   #4
bmw325i
No way you should be rubbing on the inside. Did you make sure that's where your rubbing at?
      04-22-2012, 07:04 PM   #5
justaguy
Drives: 335xi coupe
yup...i can feel it touching when i have it turned full left. It doesn;t rub wheni drive, only when im backing out of driveways.
      04-22-2012, 08:25 PM   #6
Wes335XI
Wes335XI's Avatar
107
Drives: 2008 335XI Space Grey
I have the exact same setup, except my offset is different. I've never had an issue with rubbing, especially not where the oil cooler trim is.
      04-22-2012, 08:47 PM   #7
justaguy
Drives: 335xi coupe
hmm... i find it strange too... I've been reading about the m Tech bumper having a different wheel liner, my car came with it on, and i don't know if it was an aftermarket bumper or not. Could somebody with a m tech bumper post a pic of their wheel liner?
My driver side is tight, but the extra trim on the passenger side cause it to rub. If i take the panel off it just barely clears.
I'm getting my kw's installed this week, and i fear that it'll be even worse after that.
      04-23-2012, 04:01 AM   #8
Ctm309
Ctm309's Avatar
Drives: '09 M3 AW Carbon roof DCT '11
Same rubbing here, only at left turn just before full lock. 235/35/19 - 35 and lowered on coilovers with modest drop. 2011 335 ix M Sport.
2009 M3 Alpine, carbon roof, Akra slip on.
2011 335ix, Le mans Blue, Black Dakota, M-sport, PE Exhaust, VMR VB3's, ZCP 359m's, JB Stage-2, H&R Coilovers.
      04-23-2012, 07:33 AM   #9
emre
emre's Avatar
Turkey
85
Drives: G30 540i xDrive
I had the same issue, rubbing the oiler cooler vent and also the additional water cooler vent (PPK installed)
I took off the vents and ran like that since end of last summer. There was still slight rubbing during full lock and just before full lock.
Today I went to an indy shop and they took care of it. It was on my mind for quite some time and your thread made me decide to have it done today.
They used heat gun and then pushed the liner forward. Now the vents are put back on and there is no rubbing at all.
I am running 235/35/19, OEM wheels 8x19 ET 37 with 12mm spacers. Dropped a bit with Bmw Performance Suspension.
If you install KW's it will definitely be worse. But it is easy to take care of.
G30 540i xDrive M Sport MPPSK / BM3
Reply
e90post
