Tirerack
Use the following links to go directly to useful tirerack winter items: Tirerack Winter Tires. Gary's Winter Tire FAQ.
Using the links directly supports E90Post with tirerack sales commision!
  E90Post
The Tire Rack
   PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS!
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > **********s Miro 111...need HELP
Wheels and Tires forum Sponsored by The Tire Rack
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer
Reply
      04-25-2012, 01:54 PM   #1
GRIP
Drives: BMW 335i
need help with wheel sizes....2008 E92 335 with stock 189's....I'm wanting to get the Miro 111's in a size as close as stock as possible, because I just bought tires, and don't want to have to buy new ones. they are available in 18x8.5 ET35, as well as 18x8.5 ET20, and 18x9.5 ET20. **********s has the 8.5 ET20's listed as front wheels, but that offset seems mighty low to me...will that work? Also, will the 9.5 ET20 work in the rear? I'm not looking to roll or modify my fenders at all. Is my only option to just go with the 18x8.5 all around, and will the front 225's fit with no issues on those front wheels?
"When everything feels like an uphill struggle, just think about the view from the top"
      04-25-2012, 02:19 PM   #2
MRRwheels
Drives: E92
if your looking for something that is not going to require mods or risk of rubbing then you need to stick to standard off sets, our recommendation would be
18x8.5 35et fronts and rears if your doing same size, 18x9.5 should run about a 33-38et max, if its a 18x9 do 30et. 20et is a no no.
      04-25-2012, 02:55 PM   #3
ModBargains IV
ModBargains IV's Avatar
Drives: e92 335i, 135i, E46 M3, 540i
Location: 1721 E. Lambert Rd. Unit C, La Habra, CA 90631
We do have the 18x8.5 ET35mm available for a non-staggered setup if you want. We also have the 18x9.5 ET40mm available as well.
-Frank
      04-25-2012, 09:45 PM   #4
ModBargains.com
Drives: JB E92 335i
I know we've already discussed this in a pm but here's some more info for anyone else who may have the same question. The 18x9.5 ET20 will work, but it is going to require you to roll your rear fenders. If your looking for a direct fit, you can run either the 18x8.5 ET35 all around or get the 18x9.5 ET40 in the rear for a staggered fitment.
      04-26-2012, 03:56 PM   #5
divisionbell77
divisionbell77's Avatar
Drives: 2011 335i XDrive Coupe
What you doing with those 189's?
Reply
e90post
