PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS! |
BMW Garage | BMW Meets | Register | Today's Posts | Search |
BMW 3-Series (E90 E92) Forum
fitment gurus... will this fit?
Wheels and Tires forum Sponsored by The Tire Rack
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer |
05-03-2012, 10:33 AM | #1 |
Rep 239
Hey guys, i have a question with the offset and tires specs. Will this fit my 335i e92 with sport suspension WITHOUT a drop or fender roll. Will the tire spec make the tire rub on bumps or with passenger? Thanks
Tires: 245/40/19 Wheels: 19x10 +25 Also with the same spec wheels, whats the max i can use so it doesnt rub? Thanks. Thanks |
05-03-2012, 10:39 AM | #2 |
79
Rep 1,682
Absolutely, without a drop or fender roll, you could probably get away with even more meat on the tire aswell.
a 265/30/19 on 19x10 et 25 will fit on a STOCK suspension. |
05-03-2012, 02:16 PM | #3 |
Rep 239
Sounds good, exactly the answer I was looking for. Thanks for your time e90fun, I might be switching out the fronts too, but let me see first maybe the stock ones on them now will look good
05-03-2012, 04:23 PM | #6 |
79
Rep 1,682
Tire profile too high. Better to go with a 245.35.19 if you decide to go with 245 |
05-03-2012, 04:52 PM | #8 |
Rep 1,324
Drives: 335i Coupe, 6 Speed
I know you can fit 255/35/18 on the stock sport suspension on the front. Similarly, you can probably fit 255/30/19 on the front with an 8.5" wheel at +35mm offset.
05-04-2012, 10:51 PM | #9 | |
Rep 239
So altogether i can run a 255 or 265 in the rears with /35/19? with out roll, camber adjustment, or a drop which tire width can i use that wont rub at all? |
05-04-2012, 11:25 PM | #10 |
Rep 6,604
Drives: e92 335i
I am running a 19x10 et 27 with a 265/30/19 in the rear. I am on st coilovers and rubbing slightly on the sidewall of the tire. I was wondering if i only adjust the camber will that prevent my rubbing?
05-04-2012, 11:39 PM | #11 | |
Average Car Exceeding Expectations (ACEE)
358
Rep 4,806
yes add (or take away depending how you look at it) -1.25 degrees on top of what you already have and you'll be good... You can do -3 degrees stock...and still keep everything in bmw specs.
too much to list...just know its wide and bagged |
05-05-2012, 12:12 AM | #12 |
Rep 6,604
Drives: e92 335i
so just by adjusting the camber should cut out my rubbing and i won't need to roll my fender? How much you think I should tell them to camber then?
05-05-2012, 01:29 AM | #13 | |
79
Rep 1,682
IMO, without a drop, its easily doable with a 265. If you had a drop, its more a squeeze and some camber would need to be played in but you will be fine running 265/30/19 without a doubt on stock height. I might dare even say 275/30/19 but I would stick with 265.. Do you have fenders rolled? That would be the BEST and cheapest starting place (imo, everyone should get a fender roll done if they are even thinking about going aftermarket wheels..) and from there either you can raise the car up alittle or you can dial in camber. |
05-05-2012, 09:41 AM | #14 |
Rep 6,604
Drives: e92 335i
no my fenders are not rolled and I do not plan on rolling them if i don't have to. I want to play with camber since i need an alignment anyways since i just lowered my car. I am rubbing slightly on the sidewall of my tire but i just want to avoid it because some driveways i am not even able to go up because it is rubbing. Let me know if just adjusting the camber will fix my rubbing without having to roll my fenders
01-12-2013, 02:17 PM | #15 |
Rep 623
I have a 2008 E92 335 M-sport with 19x10 HRE P40s wheels in the rear with a 275/30/19 and I had to get my fenders rolled for it to not rub. Now if i have a passenger and a couple girls in the back then it rubs over bumps and dips. If I have only 1 passenger about the same weight as me which is about 175lbs then it doesnt rub unless its a big dip. And even then its a minor rub. Getting your fenders rolled isnt that big of a deal as long as the right person is doing it OP...
On another note I just came across a killer deal on some Michelin Pilot PS2's for the front of my car which i just replaced the rears with the same Michelin Pilot PS2's and LOVE THEM. The car hooks and honestly I dont think there could be a better tire out there for atleast the way I drive my car lol. But I need your guys opinion on these tires I just came across... They are a 245/40/19 and literally have less than 15 miles on them and my buddy at Discount Tire said the guy brought them back because he didnt like the tread pattern on them and the way they smell....hahahaha. So there is literally less than 15 miles on them and I'm getting them for 100 bucks for BOTH. WILL THEY FIT??? Im worried if they are going to fit or not... I have KW coilovers and can adjust them as much as possible to squeeze them in the front fender well.
[SIZE="2"]Crimson Red E92 335i M-sport 6-speed with MHD custom stage 2+ flash only , 40% E85/93 mix,+ HRE P40S wheels, KW Clubsport, M3 sways,+BMW performance CF Mirrors, BMW Performance CF deck lid spoiler,+ CF interior trim, p3 vent boost gauge,+ LUX angel eyes (11.73@124mph on street tires)
01-13-2013, 06:17 AM | #16 | |
Rep 29,202
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals | |
