PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS! |
BMW Garage | BMW Meets | Register | Today's Posts | Search |
BMW 3-Series (E90 E92) Forum
18x9.5+22 square with 245/40/18 n 275/35/18 RS3
Wheels and Tires forum Sponsored by The Tire Rack
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer |
05-03-2012, 09:20 PM | #1 |
MOE
214
Rep 2,530
would this fit on an e92 lci?
currently at rear camber -2.3 no fender work if not, how would I get this to work
05-03-2012, 09:43 PM | #2 |
Rep 5,120
Not sure about the front because of the plastic fenders I would probably do 9.5 et 30-33 in the front with a 235/35/19 and 9.5 et22 in the rear with a 265/30/19. The rear shouldn't rub with the camber you have.
05-03-2012, 09:52 PM | #3 |
MOE
214
Rep 2,530
thanks but this did not answer anything :/
05-03-2012, 10:26 PM | #4 |
Rep 769
I'll be mounting 18x9.5 ET 22 squared with 255/35/18 squared Yokohama Neova AD08 next week (these tires run very wide). I'll let you know how it goes.
FYI though, I have 18x8.5 ET30 with 245/40/18 conti DWS in front right now with -2.8 camber and it rubs when the wheels are turned while reversing. This shows the tire profile is definitely too tall. With 18x9.5 et22, I doubt it'll work. At the minimum you'll need the camber plates you sold to me () and rolled rear fenders. |
05-03-2012, 10:27 PM | #5 | |
MOE
214
Rep 2,530
lmao I told you I would need them some day . . .
05-04-2012, 12:19 AM | #6 |
Rep 1,324
Drives: 335i Coupe, 6 Speed
I'm going to say no based off of this.
My setup is a 9" wide tire at 32mm offset with hankook rs3 255/35/18 on -1.1 degres of camber. Per tirerack calculation, your setup is 4mm MORE clearance on the strut side, and the outside edge of the wheel will EXTEND an extra 16mm Currently I can't even fit my pinky finger in the gap between the top of the fender and the wheel. An extra 16mm will most def not fit. If you run some extreme camber and perhaps have the car sit a little higher, then perhaps. I'd say slim chance even with that. |
05-04-2012, 12:21 AM | #7 |
Rep 2,823
Here is E92 with 9.5 et22 allround
http://illmotion1.wordpress.com/2011...bmw-e92-328xi/ But with 235/35/19 tyres. Not much room left. |
05-04-2012, 12:25 AM | #8 |
MOE
214
Rep 2,530
tits
235/40/18 and 265/35/18 it is
05-04-2012, 07:45 AM | #9 |
Hellafunctional
37
Rep 426
235 is going to be super stretched on a 9.5" wheel.
Go: Cobb S2+, Big Tom FMIC, CP-E DP & DCI, Royal Muffler, AR OC Turn: TC Kline/Swift SA, Vorshlag Plates, UUC Front Bar, H&R M3 Rear Bar, VAC endlinks & spacers, Forgeline 18x9.5/NT05 265 Square Stop: Endless MX72, Stoptech Rotors/Lines, Motul RBF600 |
05-04-2012, 09:39 AM | #10 |
MOE
214
Rep 2,530
05-04-2012, 09:47 AM | #11 |
Hellafunctional
37
Rep 426
Ok, dude. What do I know? I only tried 245 with similar tires and immediately took them off... The sidewalls of near r-comps are too stiff to be properly "stretched".
05-04-2012, 09:56 AM | #12 | |
MOE
214
Rep 2,530
thanks tho
05-04-2012, 10:19 AM | #13 | |
Hellafunctional
37
Rep 426
That is what I thought too. In practice it didn't work out. The tires I used had a 9.8" section width (star specs 245/40) v. the 9.5" for your 235 RS-3s. The result was the rim protector pulled away from the rim by about .5". It is the rigidity and square nature of the tires that doesn't allow them to be "stretched". I really do hope it works out for you. But, I'm skeptical. Be sure to post pics.
05-04-2012, 11:10 AM | #15 |
Hellafunctional
37
Rep 426
I stand corrected. They look good. My experienced dictated otherwise, but I guess the RS3's can handle it. That must be one meaty f'in tire, lol. Proof that you can't go by what Tire Rack has on their "specs"!
05-04-2012, 11:24 AM | #16 |
MOE
214
Rep 2,530
thanks but i already knew 235/40 would be fine
now can i have camber plates back? lol
05-04-2012, 03:20 PM | #17 | |
Rep 2,823
http://www.equnit.com/EVO/pics/ And soon i can take pictures myself 18x9.5 with 235/40/18 i only need my wheels. |
05-04-2012, 04:48 PM | #18 | |
Hellafunctional
37
Rep 426
05-05-2012, 07:54 PM | #19 |
Rep 8,801
go down a size for the rear -
rs3 very meaty. for the front even with the 235/40 u'll rub if ur low enough. u'll need to knock out the notch and pull more camber or camber plate.
FrankiE90 AKA:.[The TANK] *CLICK THE SIG
E90s (been gone but not forgotten) • KW clubsports • • • • • • • • • • 18" BBS GT4 // Build E30 (pending) + E46 M3 Wagon ESTORIL Blue |
05-10-2012, 12:50 AM | #21 |
Rep 769
Just fit 18x9.5 ET 22 in front with 255/35/18 Yokohama Neova AD08 tires (Basically 265)
No fender modification, -2.8 camber. No rubbing for front. Rear is different story.. my fenders are rolled and slightly pulled and it rubs with the same set up as fronts (got squared set up) I'll be raising height and changing negative camber to -2.5 from -2.0 |
05-11-2012, 11:31 AM | #22 | |
MOE
214
Rep 2,530
what is your rear set up?
