PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS! |
BMW Garage | BMW Meets | Register | Today's Posts | Search |
BMW 3-Series (E90 E92) Forum
Can you run diff tires on Front and diff on back?
Wheels and Tires forum Sponsored by The Tire Rack
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer |
05-04-2012, 09:17 PM | #1 |
Rep 1,288
Drives: 2014 435iX, FBO
I have just replaced my rears with Bridgeston pole positions - non rft - 265/30/19s on stock 230s
I need to replace the fronts - because one of them won't balance. I want to go with Michelin PSS now. (I think) Either case, the Pole Postion is not sold any more, and I have to go with the new Bridgestone if I want to be close. QUESTION: what will happen if I have 2 fronts the same, and 2 rears from different vendors - but all non RFT? I know it probably isn't recommended.... but what will happen to the handling/stability?
2020 M2 Competition HS, DCT, 763s, Carbon: splitter, side skirt, grill, diffuser, wing
Previous: 2014 BMW F32 435iX - JB4, MHD Flash, BMS Meth Kit, ER Intercooler, intake, catless DPs, KW Streets, 437M Reps with 245/35 and 275/30 Michelin PSS 4S |
05-05-2012, 01:33 AM | #2 |
79
Rep 1,682
Its not "recommended" but realistically you can easily get away with it.
I ran it for several months awhile back and aslong as you have the same tire brand on the same axle you should be fine. Only place it causes it issue is if your performance driving like on a track or REALLY pushing it curvy roads. The different tires on the track will cause a difference in handling so the car becomes alittle less predictable. On a daily driving basis, you wont notice a difference. |
05-05-2012, 10:36 AM | #3 |
Rep 10
Yep, just make sure the tires have the same speed rating. PS2s are very good tires and may give you a little more oversteer feeling with the different tires front and back.
Cheers |
05-05-2012, 02:51 PM | #5 |
Rep 1,288
Thanks guys... I'll go with the PSS's and just burn the F out of the rears... won't be long to replace the rears too.
