Tirerack
Use the following links to go directly to useful tirerack winter items: Tirerack Winter Tires. Gary's Winter Tire FAQ.
Using the links directly supports E90Post with tirerack sales commision!
  E90Post
The Tire Rack
   PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS!
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > 245/35 265/30 E90 prelci ?
Wheels and Tires forum Sponsored by The Tire Rack
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer
Reply
      05-05-2012, 08:54 AM   #1
pacyk
Drives: E90 pre-lci
hi guys,
I've bought recently a square set of ASA AR1's - they are 8.5 + 40
found tires (michelin PS2's)
245/35/19 and 265/30/19
will it fit?
got 20mm spacers for the rear if necessary
lowered on eibach prokit -30/25
any suggestions?
i'm afraid that fronts might rub while cornering
      05-05-2012, 09:22 AM   #2
bmw325i
Drives: 2006 BMW 325i
I wouldn't use 265's on an 8.5" rim especially if there ps2's.
      05-05-2012, 09:39 AM   #3
pacyk
Drives: E90 pre-lci
I know that 265's on 8.5 rim is way too wide but those ps2's are real bargain.
normally i would go with 235/35 all around
I just want to know if I will have any rubbing issues with this setup.
      05-05-2012, 11:04 AM   #4
Brian@bavarianx
Drives: E36 M3
No rubbing at all but I do agree that it is too much rubber for that size.
      05-05-2012, 11:53 AM   #5
pacyk
Drives: E90 pre-lci
thank you Lawrence
can I also run 20mm spacers on the rear ? (8.5 ET20 265/30)
      05-05-2012, 12:44 PM   #6
bmw325i
You might be able to. With the right sized tires it'll fit no problem.
Reply
e90post
