PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS! |
BMW Garage | BMW Meets | Register | Today's Posts | Search |
BMW 3-Series (E90 E92) Forum
Unstable @ highway speeds with rear spacers...(?)
Wheels and Tires forum Sponsored by The Tire Rack
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer |
05-07-2012, 02:36 PM | #1 |
Rep 364
Hey guys,
So I have rear spacers (maybe 12mm) on my 335i and questioning how safe it is... When going over 80mph on the highway, it feels as if I'm steering a boat rather than a german car anymore. I use to take it up to 110mph, but anything near 80+ I don't feel as safe, especially while changing lanes. Feels as if there is snow on the ground in between lanes. Is it because I have spacers on the rears and not on the fronts? Should I install front spacers as well to make this awkwardness go away? It has a slight "fishtail" feel when changing lanes on the highway. Does the camber have that much of an impact in which only the inside of the tires are having less contact when increasing speed? I also have Yokohama S drives on now. Would it be because of softer sidewalls? Any thoughts or experiences would be appreciated. Thanks Henry |
05-07-2012, 04:19 PM | #4 |
Guest
Rep n/a
Drives:
So, wait...did you put new tires AND spacers on at the same time? If so, it's probably just a "feel" of the new tires sidewall that you aren't used to. Easy way to eliminate the biggest variable though is to just remove the spacers all together and drive it to see if you notice a difference.
05-07-2012, 05:28 PM | #5 |
Rep 364
I put on spacers about halfway through the life of my previous tires. But the "fishtailing" is about the same as on my new tires. No I've put 1000 miles on my new tires so it's not the "newness" of the tires. Where the first 200-300 miles have that weird rubber feel.
Could my already staggered 8.5 rear wheel setup + my 12mm spacer be too much of a setup? I may go with the front spacers to try and even it out again. But it's so uncomfortable driving sometimes. |
05-07-2012, 05:30 PM | #6 |
Ex-Diesel Driver
63
Rep 2,000
Would it be the same only at lower speeds? For instance, if you were under 40 mph, but felt nothing over 70 mph? Same setup.
FS: HRE Center Caps http://www.e90post.com/forums/showth...post13972317l] |
05-07-2012, 06:53 PM | #7 |
Rep 281
if all was perfect before the spacers and the only thing you have done differently is to add the spacers then the problem is ( drum roll....) the spacers.
this happens all the time, spacers are sometimes machined in house and is sometimes a human error in either the machining of the spacers being off by a MM or so. if you removed them and the drive is back to normal then consider checking those spacers. good luck. |
05-08-2012, 01:24 AM | #8 |
Rep 2,110
I'd check the torque on the bolts. Just to eliminate any possibly issue with the spacer/wheel not being properly mounted to the hub.
Also what brand are the spacers? |
05-08-2012, 04:35 AM | #9 |
Where'd my VTEC go?
481
Rep 6,067
No such issues with my 12mm rear spacers.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
05-10-2012, 04:45 PM | #10 |
Rep 364
05-10-2012, 04:50 PM | #11 | |
Rep 364
I love the rear spacers, and I may try another brand, but I don't have any crazy setup/suspension on my car. |
05-11-2012, 12:39 AM | #12 |
Rep 857
Drives: 2008 Montego Blue 335i
Sell the car. See ya then... People are just trying to help and asking if it's the tires or another factor.
05-11-2012, 08:18 AM | #13 |
Rep 364
05-11-2012, 11:57 AM | #14 |
Rep 136
I have ebay 20mm rear spacers and felt no difference from stock.
08 335i E90, AW, jb4 and dci, 20% tint, ER CP,synapse bov ,supreme power perches, cyba tips, BMS WW meth kit, M3 front, BMS catch can, mtech AE, AA downpipes, Big tom IC, kickdown disabled, 15 ohm mod.
05-11-2012, 12:39 PM | #15 |
METALCRAFTER
Rep 46
Drives: E92 335i
Are they Hubcentric?
05-11-2012, 01:20 PM | #16 |
Rep 921
Drives: LeMans BLue e92 335i LCI
I was running 10mm spacers in front and 12mm in the rear of my e92
No noticeable difference in feel at highway + speeds.
e92 LCI • LeMans Blue • Saddle Brown • Bamboo Anthracite • Performance Grilles • CF Performance Spoiler • CF Performance Diffuser • ACS Style Roof Spoiler • LED Interior Lighting • BMS Clutch Stop • BMS Intake • BMS CDV • BMW Performance Exhaust • ST V1 Coilovers • Miro 111 Staggered • More to come! |
05-11-2012, 03:35 PM | #18 |
Ex-Diesel Driver
63
Rep 2,000
Do you have 10's or 12's. You might be running into a problem if they are 10's and you will need to step up to at least 12's or 15's because of the lip.
02-05-2013, 08:13 PM | #19 |
Rep 156
I know its an Old post but what was the final result, you sold the car or fix the problem.
I am going with Macht Schnell Spacers E90 335i Sports 18mm on the Rear only. I was thinking it will give more stability to the Car with wider looking wheels in the Rear and may be some under steering.
2007 X5 4.8 | Sport pkg | ZPP | ZCW | ZPS | ZTP | 3rd Row Seat | Entertainment pkg | HUD | Jet Black |Continental Extreme DWS.
02-06-2013, 12:20 AM | #20 |
Rep 1,181
I put 10mm front and 15mm tuner motorsports spacers on my 193m staggered setup and everything seemed to be fine. I hit 125mph on the highway to test any fishtailing or any disturbances the other day. Make sure your bolts are secured and you used extended lugnuts
F80 M3
F32 435i - Daily BMW e92 328i - SOLD /// ST V1 Coilovers /// BMW Performance Exhaust /// OSS Full Blackout /// LCI Tail Lights /// Volk Racing TE37 /// CPS Lip /// |
02-06-2013, 11:52 AM | #21 |
Rep 156
yep I will get the extended lugnuts with the MS spacers.
02-06-2013, 05:42 PM | #22 | |
Rep 25,989
VMR|Wheels | 714.442.7916 |
sales@velocitymotoring.com | www.velocitymotoring.com | facebook | flickr | Instagram |
