Tirerack
Use the following links to go directly to useful tirerack winter items: Tirerack Winter Tires. Gary's Winter Tire FAQ.
Using the links directly supports E90Post with tirerack sales commision!
  E90Post
The Tire Rack
   PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS!
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Wheel calculator on this forum
Wheels and Tires forum Sponsored by The Tire Rack
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer
Reply
      05-10-2012, 08:27 PM   #1
Jhalf
Drives: 08 335i e92
I might be missing something really simple, but when i use the calculator for tire diameter at the top of this page, it says that an increase of 1.5 percent would make the speedometer at 60 actual mph read 61.
In actuality if you have a bigger tire diameter the speedometer would say you are going slower than 60 because the tire travels less revolutions per mile.
Am i missing something? Or misreading it?
      05-10-2012, 08:29 PM   #2
bmw325i
Drives: 2006 BMW 325i
When your speedometers at 60 your actually going 61.
      05-11-2012, 06:46 AM   #3
Jhalf
Drives: 08 335i e92
Doesn't the above say "Speedo will read:____ mph?"
Doesn't that seem written wrong?
Shouldn't it say "Speed when speedometer reads 60:___mph"
      05-11-2012, 09:54 AM   #4
Orion4
The calculator is correct. Think of it this way: Since the new tire has a slightly larger diameter, it takes longer to make a single rotation, although you are covering slightly longer distance per rotation, therefore the speedometer system which is calculating based on number of rotations still thinks your going 60-while because of the slightly greater distance covered for the same time period you are going slightly faster.
Hope that make sense.
      05-11-2012, 12:33 PM   #5
Jhalf
Drives: 08 335i e92
That makes perfect sense, Im saying with a bigger tire the that readout at should say:
Speedo @60mph will read: "59" mph not 61
      05-11-2012, 01:28 PM   #6
The Kingpin
Drives: 2007 335i sedan
I agree. It should say " when spedo says 60 your actual speed is ___"
      05-11-2012, 02:32 PM   #7
BrazilianBimmer
Drives: Black e90 325i
I agree that speedometer should say say 60 but in reality you would be going at 61, however if the wheel is slightly bigger the speedometer would most certainly be lying to you due to the known fact that a bigger wheel travels a slightly longer distance with each rotation than a stock. It should really say, speedometer reads 60, while you are traveling @ 59.
Does that makes sense?
      05-11-2012, 03:33 PM   #8
Jhalf
Drives: 08 335i e92
Thanks guys, just making sure i wasn't going crazy
Reply
e90post
