2010 2011 BMW 5 Series Forum F10
2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums Regional Forums UK F11 Mud-flaps
      07-16-2012, 07:31 AM   #1
CH79
Scotland
19
Drives: 530d xDrive (G31)
F11 Mud-flaps
Do mud-flaps fit on the F11 with the M-Sport body kit? Anyone got any pictures? Ideally on a space grey F11?
I've noticed that there is quite a bit of spray on the skirts/rear bumber which would probably be solved with mudflaps so if they looked okay, I would consider fitting them.
Can you get them anywhere else other than from BMW? Is it an easy DIY job?
      08-17-2012, 08:28 AM   #2
BMWales
Drives: F11 525D sport, silver, vdc...
I've been told by my local dealer they wont fit on an M sport.
Annoying as i want to fit a set too but don't fancy buying them and finding dealer actually knows what he's taling about ;-)
      08-17-2012, 09:27 AM   #3
remmib
remmib's Avatar
Norway
1568
Drives: 2013 F10 520d M-Sport
See post #24 for pics of oem mud flaps on a m-sport. F10, but doubt the F11 are much different.
http://f10.5post.com/forums/showthre...d+flaps&page=2
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals |
      12-21-2012, 11:41 AM   #4
davewf
Drives: BMW F11 520d Msport
Just fitted a set to my F11 520d M sport, they fitted fine but you need to follow the instructions for the 6-cylinder model when fitting the RH rear as they have got the instructions reversed ie page which says (only for 6 - Cylinder) should read (all other models). This because there is a plastic under tray where the 6 cylinder would have its exhaust so you do not need part D. You just screw up through the fixing on the main flap into the plastic tray.
Had me confused for a bit but its obvious when you know.
      12-27-2012, 05:01 AM   #5
JD-IRL
Ireland
Drives: F11
Hi Dave,
Any pics of your work, would love to see what they look like on an F11.
Also can you buy the front and rears separately.
Cheers
JD
      12-27-2012, 11:36 AM   #6
davewf
Pictures as requested flaps installed on 520d M Sport F11. Front and rears can be bought separately.
      12-28-2012, 03:03 AM   #7
HighlandPete
Drives: BMW F11 535i Touring
Interesting, as I also was under the impression mudflaps were not suitable for the M-sport. BMW data still says that, but I do miss not having mudflaps up here, with all the muck we get thrown at our cars.
Will look at getting them for my F11.
Thanks for posting.
HighlandPete
      12-28-2012, 03:58 AM   #8
davewf
Thanks for posting.
HighlandPete
My local dealer got them in for me and we offered them up to the car to check that the profiles fitted OK note that there seem to be two different kit numbers for the rears, these are
82 16 2 155 857 and 860
Unfortunately I have managed to loose the invoice so not sure which part number I fitted. However BMW Direct on Ebay are selling the 860 variant so suspect that was what I fitted.
Suggest you get the dealer to get a set in and check the profiles fit before taking them home. Not a big risk for the dealer as they can always use them for the SE variants
      12-29-2012, 05:39 AM   #9
JD-IRL
Ireland
Drives: F11
Cheers Dave, really appreciate it.
JD
5post
