BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Stock 335i calipers vs M-performance
Studio RSR
      07-18-2012, 10:38 PM   #1
Jadar
Dejan
Jadar's Avatar
Serbia
1753
Drives: 2018 Audi S3
What is the difference? The only thing I can see in the photos is the m-performance is painted and has an m logo painted on oh and the cross drilled rotors as oposed to the stock 335i are just silver and solid rotors.
FBO-PS1 and stuff
      07-18-2012, 11:38 PM   #2
clarence
Drives: F30 328i M-Sport
The discs on all 4 corners are larger & the rear calipers are 2 piston.
      07-19-2012, 10:52 AM   #3
Jadar
Dejan
Jadar's Avatar
Serbia
1753
Aha ok I see. So the stock front 335i calipers are the same? Will they fit this larger disc as well.
The calipers look the Same in the front.
FBO-PS1 and stuff
      07-19-2012, 10:59 AM   #4
martinf79
martinf79's Avatar
191
Drives: 2020 G05 X5 M50i
Same front calipers ... different rear (as per the response above).
2020 X5 M50i | 2015 X3 28i xLine | Retired 2013 335i M Sport
      07-19-2012, 11:52 AM   #5
clarence
Don't think they're the same. The standard front discs are 340mm in diameter, the M-sport brakes are 370mm. U can't fit the larger discs onto the standard calipers.
      07-19-2012, 01:21 PM   #6
martinf79
martinf79's Avatar
191
I never said anything about the discs ... he asked if the calipers are the same as OEM, and they are not. Front calipers are the same ... rears are different ... geeez .. guys read the responses before responding ...
      07-20-2012, 12:32 AM   #7
clarence
That's wht I said, the front calipers are different. The M-Sport front calipers are bigger than the standard 335i front calipers, unless u're talking abt US-spec option 2NH for 328i, then u'll get the same calipers as the standard ones on the 335i but painted in blue. This is confirmed by E90Fleet.
      07-20-2012, 12:39 AM   #8
clarence
No, don't think they'll fit. The front calipers on the M-perf is bigger than the standard caliper.
      07-20-2012, 12:50 AM   #9
clarence
http://www.f30post.com/forums/showthread.php?t=689045
      07-20-2012, 07:48 AM   #10
Jadar
Dejan
Jadar's Avatar
Serbia
1753
I thought so. They look so identical, but Im sure that was BMW's intention. I love to do them in red. I bet the grip is amazing.
Ok that covers pretty much all of it. So if I do this upgrade it wont void my warranty correct? Since it is an M performance part?
FBO-PS1 and stuff
      07-20-2012, 08:43 AM   #11
martinf79
martinf79's Avatar
191
OMG - M -Sport front front calipers are the same as 335i OEM, except they are painted blue, while the rears are different. M "Performace" calipers ARE different (front and rear) vs. OEM. M-Sport vs. M Performance brakes are different.
      07-20-2012, 11:27 AM   #12
clarence
I think u misunderstood some of the facts. To put it simply, for EU/ROW spec, M-sport brakes (i.e. option code 2NH, factory-fitted option ONLY AVAILABLE for cars with M-sport package) are IDENTICAL to M-performance brakes (i.e. dealer fit item from M-performance range), WITH 2 EXCEPTIONS: 1.) colour coded in blue instead of a choice of 4 colours for the M-performance version, & 2.) plain rotors instead of the slotted & grooved discs that come with the M-performance version. The discs are interchangeable between the 2 types of brakes as they are of the same size & same caliper design. This applies to all models of the F30 range w/M-package, from the lowly 316d to 335i.
Now, for US/CDN-spec, there are 2 types of M-sport brakes for M-sport package equipped cars. For 335i M-sport, if option 2NH is specified, it will be the same as EU/ROW-spec (i.e. identical system to M-performance brakes but in blue & plain rotors). For 328i M-sport, option 2NH means brake system from standard 335i (but with EU/ROW pads), only difference is the calipers are in blue w/M logo instead of the unpainted silver. So in a nutshell, US/CDN 335i M-sport w/2NH, then similar to M-performance; for US/CDN 328i M-sport w/2NH, then similar to standard 335i but with EU/ROW pads.
      07-20-2012, 11:32 AM   #13
clarence
Warranty will be intact as they're genuine BMW accessories. I'm not sure whether the warranty clauses in ur area are particular to who fits them, if it is then best to use the services of a BMW dealer.
