BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Introducing Our Evolution Racewerks F30 335i N55 Downpipes
Closed Thread
      09-21-2012, 02:47 PM   #1
Evolution Racewerks
Evolution Racewerks's Avatar
Drives: 20 M340i,15 M4,12 328i,08 135i
Exclamation Introducing Our Evolution Racewerks F30 335i N55 Downpipes
Our new Competition Series 4" Downpipes for your 2012+ 335i (F30 Chassis) six cylinder turbo engine!
Ease of Installation: (1 Easy, 5 Hard) 3
Installation Guide
Parts Checklist
Key Features:
Available for the 2012+ BMW 335i (F30 Chassis) N55 Engines!
Better throttle response and faster turbo spool up times.
Mandrel Bent 4" piping. Smooth transition to the exhaust system.
100% Stainless Steel Construction
100% TIG welded for better quality welds
Precision CNC machined turbocharger V-Band flange.
Brush Finish (standard) or optional Polish Finish
Available with high temperature Black Thermal Coating to reduce underhood temperatures.
Optional - Additional O2 sensor bung for wideband O2 sensors (comes with pre-installed plug)
Optional EGT sensor bung for EGT gauges (comes with pre-installed plug)
Compatible with the factory or aftermarket exhaust systems.
Track tested durability.
Includes all hardware for complete installation.
Limited Lifetime Warranty.
Restrictions in the exhaust system robs horsepower and torque especially on turbocharged cars. Thus, removing as much exhaust flow restrictions will increase horsepower and torque significantly. The factory catalytic converter found in the factory downpipe is a big culprit of this and is a major exhaust flow restriction. The factory catalytic converter is made up of catalyst material formed into "honeycomb" weaves. Exhaust gas must pass through these tiny "honeycomb" weaves on their way to the exhaust system thus causing a major exhaust flow restriction. It also causes turbulence after the catalytic converter which causes the exhaust flow to slow down (which increases restriction). By replacing the factory downpipe/catalytic converter with our Competition Series 4" Catless Downpipe, more power is unleashed! You will feel the difference instantly.
Our Competition Series Catless Downpipes is constructed out of 100% 304 grade stainless steel and utilize mandrel bent piping. They are 100% TIG welded by our in house fabricators and built in the USA. The factory turbocharger turbine housing utilizes a V-Band flange which we have duplicated and CNC machined cut out of billet 304 stainless steel. Stainless Steel CNC machined O2 sensor and laser cut brackets are TIG welded using stainless steel rods. The O2 sensor is positioned at the factory location. Since the outlet of the turbocharger is 3.5" and the factory exhaust system is 2.5", the factory downpipes reduces size using short transitions from 3.5" before the catalytic convert and 2.5" afterwards. Due to space needed for the cataylic converter, the factory downpipes reduce in size using very short transitions. Since our catless downpipes delete the cataylic converter, we have more space. Thus, we use very long transitions. These longer transitions allow the exhaust gas time to smoothly transition from the larger piping to the smaller. This results in less exhaust turbulence and backpressure which again improves throttle response and increase turbocharger spool times (less turbocharger lag).
Our downpipes are designed to fit perfectly with either the factory exhaust system or your aftermarket exhaust system. There are no compatibility issues whatsover. The downpipes will come by default in Brushed Finish. We also offer a Polished Finish as an option.
OPTIONS
Ceramic Thermal Coating - The purpose of ceramic coating downpipes is to keep heat from the exhaust gases inside the downpipe from radiating out. This keeps underhood temperatures lower and less heat absortion by nearby parts/surfaces. Another added benefit is that by keeping in heat (energy) in the exhaust gases inside the downpipe, exhaust flow velocities stay up, resulting in lower backpressure. The ceramic coating also adds additonal corrosion resistance. We utilize the best ceramic coating possible. Our thermal coating can resist up to 2000F of heat. It is available in black only (all the other colors cannot withstand heat that high).
Additional O2 Sensor Bung - An additional O2 sensor bung can be added so that you can easily add a wideband o2 sensor and gauges so that you can monitor air/fuel ratios. The additional O2 sensor bung will come pre-installed with a plug so that you do not need to run the o2 sensor right away.
Optional EGT (Exhaust Gas Temperature) Bung - An additional 1/8" NPT bung can be added so that you can easily add a EGT sensor and gauge. The optional EGT sensor bung will come pre-installed with a plug so that you do not need to run the EGT sensor right away.
      09-21-2012, 03:43 PM   #2
parky1215
parky1215's Avatar
564
Drives: F90 M5C | G06 X6 M60i
awesome!
      09-25-2012, 05:01 PM   #3
///M ARMY
Drives: F90
Those Look Good. Would These Fit The F10 535 Also?
      09-28-2012, 04:33 AM   #4
Underated
Drives: F30 N55
Cant wait!
      10-11-2012, 08:03 AM   #5
Alex@ONEighty
Alex@ONEighty's Avatar
Drives: 2011 E90 M3 CZP 6MT
Updates?
      10-11-2012, 02:45 PM   #6
Evolution Racewerks
updated with specs!
      10-12-2012, 02:19 PM   #7
1clean335i
Perf BMW mag issue 147, 159
1clean335i's Avatar
Vietnam
414
Drives: Project Estoril
Price?
'13 Estoril Blue 335i M-sport
*Don't PM me!* Message me here- http://www.facebook.com/ProjectEstoril
      10-12-2012, 04:15 PM   #8
justinnum1
Drives: 2018 330i Msport 6mt
yea, where is the price?
F30 330i Alpine white/Coral red Msport 6MT
      10-13-2012, 08:14 PM   #9
Evolution Racewerks
For more information regarding to pricing, refer to our website here: http://evolutionracewerks.com/node/213
      10-18-2012, 01:05 PM   #10
1.fresh.f30.335
Drives: 2014 535xdrive M-Sport
...Consider it sold! Top of my xmas list for sure. Thanks guys I can't wait to see some dyno numbers on it!
'12 335i Sport Apline White w/black... Totaled
'14 535i xdrive M-Sport Carbon Black w/Mocha Nappa
      10-18-2012, 01:29 PM   #11
justinnum1
best this would sound redonkulous with mperformance exhuast
      10-22-2012, 09:59 PM   #12
PeterM
Drives: bmw 335i
Great looking downpipes
      12-02-2012, 10:47 PM   #13
1.fresh.f30.335
Do we have any sound clips or dyno numbers yet? I'm going to install it with a stock exhaust so I am interested to see what kind of noise difference I am looking at (hopefully a fair amount)
      12-03-2012, 01:44 AM   #14
TreDirtyFive
Drives: X3 M40i
wow, those look like vintage steampunk robot leg parts! bravo to be one of the first on the market with these. dynos next please!!
X3 M40i G01, M235i F22, 335 F30 MSport, 135 DCT, 335 E92, Audi A3
      12-03-2012, 12:48 PM   #15
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
In General, when you install a DP with a stock system, you'll "hear" the turbo spool more, and it'll spool faster...rarely do you hear a noticeable increase in the sound...and if you do, it usually comes as a cabin drone, which isn't positive. Now, I'm making general statements, unsure WRT to this system...
SOLD: 2012 335i Mineral Gray
      12-28-2012, 09:24 AM   #16
1.fresh.f30.335
[QUOTE=shivaswrath]
I know what your saying, I've done a few set ups before and figured this car needs more turbo, more backfire but not too much more under driving, just a little deeper tone in my opinion. I think the dp would accomplish most of that, hopefully I don't get too much droning though, I haven't given that too much thought.
Can we get a sound clip? Also, the black heat coating... How well does it work and does it work to maintain stock heat levels or reduce heat levels when compared to stock? Or just reduce heat compared to non coated dp.
      12-28-2012, 10:31 AM   #17
J-boogey
J-boogey's Avatar
Drives: F30 335xi Msport
will this fit xdrive?
2013 F30 335i xdrive | Estoril Blue | Black Dakota Leather | Aluminum Hexagon trim | M-Sport | Cold weather | DHP | Premium package | Tech package | Harmon Kardon | PDC | Rearview Cam | IND Painted reflectors | BMW performance grills | JB4 stage 2 | ER downpipe | BMS Intake | H&R sport springs
      03-01-2013, 02:09 PM   #18
lazycat
Drives: f80 m3 CP
I just had these installed, and i've never been more satisfied at a aftermarket part than at this downpipe. Amazing product! Completely transformed my car!
      03-02-2013, 03:58 AM   #19
Evolution Racewerks
We've never tested these on an x-drive yet. However, we are currently looking for a tester so if you're interested give us a call at (626) 814-3403
      03-02-2013, 09:57 AM   #20
verbs
Drives: 2015 M235i
CEL lights yet?
      03-02-2013, 08:55 PM   #21
Monstr6
Drives: 2013 335i M sport
I have x-drive and just installed my Catless dp. Was a little tight under there but i am loving it!! sounds amazing
      03-06-2013, 02:03 PM   #22
Renus
Renus's Avatar
28
Drives: E92 335i
Does it fix on RHD F30 335i? After install this DP, will the 02sensor will trigger the engine light? And price please.
Closed Thread
