BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > xDrive All-Wheel Drive Discussions > Xdrive uses EPS?
      11-19-2012, 09:07 AM   #1
JK479
Drives: 8 Speed Auto Bimmer
Xdrive uses EPS?
Does X drive use the same electronic steering or does it get the old hydraulic system?
      11-19-2012, 09:37 AM   #2
HighlandPete
Drives: BMW F11 535i Touring
EPS in the European models.
HghlandPete
      11-19-2012, 10:56 AM   #3
JK479
xdrive ...
HghlandPete
Can anyone chime in that drives F30 in the USA? is your xdrive a hydraulic setup?
      11-19-2012, 01:04 PM   #4
howiegu
Member
howiegu's Avatar
Drives: 16' 340xi Msport
ESP for US as well.
      11-19-2012, 03:32 PM   #5
S-Dot
Drives: 2013 328i xDrive Luxury
Electric, but not "the same". Different steering box parts for xDrive versus non-xDrive.
      11-19-2012, 03:50 PM   #6
JK479
is there a difference in feel? is the xdrive the better drive than the rwd sister model?
      11-19-2012, 04:06 PM   #7
Gymkhana
Gymkhana's Avatar
Russian Federation
Drives: M3 E46
i dont think you'd notice that. Except hard conering. This is where it differs from RWD turn technic )
Still, as a man,that tryed Xdrive after plenty RWD cars - id suggest to go for RWD.
M3 E46
Best and the sharpest yet
      11-19-2012, 04:15 PM   #8
S-Dot
In my opinion, xDrive is NOT the better drive. The rear-wheel drive is a sharper, better-handling vehicle overall. The xDrive isn't BAD, it's just not as good.
And much harder to tail-slide.
I have xDrive because I live at the end of three miles of mud road, and without it I'd never get anywhere.
      11-19-2012, 04:28 PM   #9
JK479
RWD is generally more interesting. The trade off is more wheel spin on winter days.
Do sandbags really work? adding a few hundred lbs to a truck seems archaic but maybe its smart?
      11-19-2012, 06:53 PM   #10
SPACEMANRICK
Drives: 2016 M3 6 speed manual
Not sure why anyone would spend $50,000 on a sports sedan and then throw 200 pounds in the trunk for traction? Not sure if you are driving a 335 or 328 but in my 2006 rear wheel drive 330i with only 260 horsepower I would get wheel spin all the time on hard acceleration from a stop in Vancouver's heavy rain and in hilly terrain. The only time I ever experienced wheel spin in my 2008 335xi was on ice and that was only briefly before all 4 tires hooked up.....
Some people in rainy and warm Vancouver prefer winter tires an rear wheel drive but in the last 3 years in Vancouver the Winter has averaged about 40 to 50 degrees farenheit with 2 days of snow.......In Vancouver I find all wheel drive with 300 horsepower much less of a sacrifice than rear wheel drive with winter tires when it is 50 degrees out and raining!
      11-19-2012, 08:44 PM   #11
Nedmundo
Drives: Acura TSX, 2010, 6MT
I tested a 328i RWD Sport Line in April, and, a couple of weeks ago, a 328i xDrive M-Sport with Variable Sport Steering. That's not exactly back-to-back, but the steering left me with the same impression both times. I suspect that any steering feel advantage from VSS could have been offset by the AWD and non-sport suspension, but, regardless, I don't think there's much if any difference.
      11-19-2012, 09:15 PM   #12
S-Dot
I actually found VSS to have a worse feel. Or more specifically, it had a less natural feeling to me. They felt the same on-center, but moving from on-center to off-center seemed abrupt and not intuitive to me.
Actual feel and feedback was near-identical feeling to me, but I believe they both use virtually the same setup other than different rack gearing.
I agree that there wasn't alot of steering feel difference from non-xDrive to xDrive models until you really pushed things, but once you start sliding tires, the RWD had more luck going where I wanted it to go and how I wanted it to go.
Or maybe I just like on-demand oversteer...
      11-20-2012, 11:18 AM   #13
JK479
RWD is fun... and sportier. AWD is a superior traction. In the snow belt, it helps gets you going. I won't turn this into a awd vs rwd debate, but being pushed verses pulled with FWD is always better. My understanding is awd uses RWD bias to begin with.
      11-20-2012, 01:10 PM   #14
TheObviousChild
TheObviousChild's Avatar
Drives: '20 M340 xDrive
Yep, this is one of the main reasons I decided to go with Xdrive. In CO, I've gotten stuck a couple of times in my RWD 328. Wanted to go with Xdrive with my 335, but was concerned I'd be giving up the RWD feel.
Turns out Xdrive is biased to the rear by about a 60/40 ratio.
2020 M340 xDrive Sunset Orange over Oyster
Previous: 2016 340xi EBII over Coral Red, 2013 335xi EBII over Coral Red, 2010 328i, 2007 328i, 2004 325i
