BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Activehybrid 3 suspension question
      11-20-2012, 09:59 PM   #1
Boosted John
Internet Ninja
Boosted John's Avatar
47
Drives: 13 AH3
I have a AH3 ordered with the Msport pkg. the hybrid is like 230 lbs heavier than the regular 335. I would like to drop it to eliminate the wheel gap. Do you guys think the h&r springs or some other brand be ok or is the weight difference that significant that it wouldn't work well?
2013 BMW ActiveHybrid 3 /// Msport Pkg. M performance fornt lip, Black Kidney Grills, H&R Sport Springs, BBS CH-R
      11-20-2012, 11:19 PM   #2
SamS
SamS's Avatar
Drives: Tesla M3 Perf + '18 X3 M40i
I don't know the answer to your question, but part of me thinks the AH3 may have different springs than a 335i in the rear, to account for the weight. You know those German engineers think of everything! I doubt they'd slap ~250 extra pounds on there and not compensate. Imagine driving a regular 335i with a couple of girls in the back. It's probably going to look a bit lower. But when I see an AH3, the rear looks the same height as the standard 335i.
2020 Tesla Model 3 Performance - current
2018 X3 M40i - current
2016 M3 - sold
2013 ActiveHybrid 3 - sold
2012 M3 coupe - sold
      11-21-2012, 12:03 AM   #3
claykin
Drives: various BMW
They sure do. N/C...steering vibration, easy to fall out tail lamps, Edison era lamps in turn signals, brake squeal, and super dusty pads to take us back to pre LCI E90. Some OEMs charge $$ for these awesome innovations.
You can probably tell I'm in a mood tonight....
      11-21-2012, 12:58 PM   #4
Boosted John
Internet Ninja
47
Drives: 13 AH3
well the convertibles weight difference form the coupe is about the same amount as hybrid to non hybrid and I'm not sure if there is a difference in the H&R springs for the coupe and convertible.
      05-12-2016, 04:37 AM   #5
Lancelot
France
361
Drives: 2014 M Sport ActiveHybrid3
I can't find a difference in rear suspension part numbers on realoem.com
What would be your recommendation to upgrade the AH3 suspension with EDC? (2VF option)
What kind of handling improvement can I expect?
I'm not unhappy with my OEM adaptive suspension, just considering options to squeeze more out of the chassis as I find it lacking a bit of sharpness
Upgrading the front control arms next saturday with a set of M3 arms by the way!
      11-12-2017, 02:49 PM   #6
Horley900
Drives: 2012 Activehybrid 3
I'd be intrested too in any suggestions?
      11-12-2017, 10:09 PM   #7
afranke
Drives: 2013 ActiveHybrid 3
I have the H&R Super Sport Springs on my AH3, and the back end definitely sits a bit lower than the regular 335. It's fine for me and I managed to fit 20x10.5 wheels in there with Nitto NT555 G2 275/30-20.
2013 ActiveHybrid 3 (335ih) N55 PWG Meisterschaft GT catback Wagner tuning catless DP and Stage 2 Evo Comp Intercooler ER chargepipes CTS intake io2V3 O2 simulator Pure Stage 2 turbo with high-flow inlet and DV upgrade Fuel-It Stage 2 LPFP JB4 ISO firmware Fuel-It DIY PI Kit bootmod3
      11-13-2017, 11:54 AM   #8
Horley900
That's good to know thanks, I'll be purchasing them tonight.
Have you upgraded the rarb on your car. I notice that on our cars it is only 12mm, is that because of the space constraints with the battery? I'd ideally like to fit the 15mm from the 440i m sport.
      11-13-2017, 03:25 PM   #9
afranke
Whats a rarb? Was that supposed to be swaybar? If so, no, the only suspension work I've done is the springs. Waiting on the first paycheck from my new job to get some BCs and maybe some sways.
      11-13-2017, 03:28 PM   #10
Horley900
So back in my day a rarb was a rear anti roll bar, but I've seen that they go by sway bars now lol.
afranke192.50
      11-13-2017, 03:47 PM   #11
Lancelot
France
361
Depends which side of the pond you are
Sway bar is american, anti roll bar is british English apparently.
Back the topic i fitted big H&R bars on my AH3, didn?t like it, put the 440i bars and now i?m happy
2014 M Sport ActiveHybrid 3
M Performance BBK - F80 CFRP struts brace - Quaife LSD - M adaptive suspension/ST sport springs - Akrapovic Exhaust - HJS EU6 downpipe - Wagner Evo2 Comp IC - BMC air filter - Powerflex Black Subframe Bushings - Bimmertech amp with Focal speakers
afranke192.50
      11-13-2017, 03:54 PM   #12
Horley900
I see, those cheeky Americans and there independence, they have to be different haha.
I did look at the H&R anti roll/sway bar, I thought it might be too stiff as it super thick. Was that the case?
      11-15-2017, 06:01 AM   #13
Lancelot
France
361
They sure are unless you?re on smooth track all day long, in real life it?s too much, so 440i LCI are fine, if need for stronger bars check KW or Eibach, 16mm at the back vs 20 for H&R
