BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Automatic High Beams - Dead?
      04-09-2013, 05:45 PM   #1
omarliendo
Drives: 2012 335i Sport Line - Red
Hi guys,
I drive my car at night a lot because of work so the Automatic High Beams option, which i payed extra for in my MY 2013, was very useful; however, it stopped working a couple of days ago out of nowhere!
Have you guys experienced this issue if you have the Automatic High Beam option or am i the first unlucky one?
Omar Liendo
Atlanta,GA
      04-09-2013, 08:50 PM   #2
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
Were there street lamps in your highway or side street that were part of your commute?
SOLD: 2012 335i Mineral Gray
      04-09-2013, 09:36 PM   #3
bizzyqu
Drives: 2019 M240i xDrive
hold your hand over the sensor and see if that turns them on (the sensor under your rear view mirror)
07 E83 X3 BSM Sport-->10 E90 335i xDrive BSM M-Sport-->13 F30 335i xDrive EB M-Sport-->16 MKVII LB Golf R --> 19 F22 M240i xDrive MG
      04-10-2013, 11:19 AM   #4
omarliendo
Thanks for the replies and the tips guys but yeah, since i use that feature almost every day, i learned all these tricks lol!
It's my fault i should have been more specific:
A lot of times just putting my hand in front of the sensor would do the trick; however, what is different now is that the little green light on the dashboard which indicates that i have the AHB on, does not turn on anymore! So it's like it does not get activated anymore
Omar Liendo
Atlanta,GA
      04-10-2013, 01:49 PM   #5
TonyS
Drives: F30 335i
Forgive me for stating the obvious, but you do have the main headlight switch in the auto "A" position (i.e. to the left) don't you? If I remember correctly AHB only works with the switch in that position.
      04-10-2013, 03:10 PM   #6
tdizzle
Drives: 2017 F80 ZCP
Beat me to it. Sounds silly, but make sure the lights are in the auto position so they come on at dusk/night on their own. I believe that is what the green indicator is that you're speaking of (there are two one on the lower left and one in the middle - lower left is auto headlinghts and middle is auto high beams with the "a").
Then you have to turn the auto high beams on (I dont think it has a 'remember the last setting' for the auto high beams)
      04-18-2013, 02:23 PM   #7
omarliendo
You guys are awesome!! I have no idea when i changed that but apparently i did! It works now!
THANK YOU!!
Omar Liendo
Atlanta,GA
      04-19-2013, 01:01 AM   #8
EJIB
Drives: F30 Luxury 18D 143 BHP 320NM
HBAssist is potentially availbale when both headlight switch is in "A" position AND lights are turned ON (due to low environmental light condition). Only then you can activate HBAssist manually (Switch ON with steering wheel switch). In case sufficient environmental light (driving through tunnel or so) the Auto lights turn off which consequentially RESETS the HBAssist. You have to turn it on manually again when lights turn ON. Also daylight changes in this period of year, so there are less conditions where HBAssist is needed; this can be erronuously regarded as a failure.
Now one year driving and still impressed !!
      04-19-2013, 02:07 PM   #9
ft1338
Drives: None
What option package(s) give me HBAssist?
atlanta, automatic high beams, high beam assist, omar liendo
