07-03-2013, 11:23 AM | #1 |
Rep 3,229
18x10 et40
Would 18x10 et 40 work for the rears? Or is it to high of a offset?
Also what tires? 275-35-18? Or 265? Haha thanks
e92 ///M3 |
07-03-2013, 12:44 PM | #2 | |
Rep 1,997
If you want 35 profile you may want to go with 265s though. I'd have to do more math than my lazy mind wants to do right now to figure that out. I'd try to match the front and rear diameters as close as possible and go from there. Oh and I'm assuming you are asking about F30s (no clue if E9X fitment is about the same or not) |
07-03-2013, 01:32 PM | #3 | ||
Rep 3,229
18x10 et 40. I really want to fit them.
e92 ///M3 |
07-03-2013, 05:58 PM | #4 | |
477
Rep 4,591
They'll definitely fit in the rear, the 18x10 ET40 is done by BBS on a couple of fitments for the F30. The fronts should work too, it may be tucked slightly. You may want to use a spacer, more for the inside clearance than the outside. |
07-03-2013, 08:23 PM | #5 | ||
Rep 3,229
What tire sizes do you recommend?
e92 ///M3 |
07-08-2013, 09:11 AM | #6 |
477
Rep 4,591
We've done MORR VS8.2's with 19x10 rears on 275 width so your 275/35/18's should fit, but the 19's are going to have less chunky of a sidewall. 265/40's will work also, but the sidewall may feel a little tall.
07-01-2022, 08:16 AM | #8 |
Rep 611
07-01-2022, 08:47 AM | #9 |
Rep 9
Yea no for the rear looking for a drag setup at the moment ! Definitely not the front :,)
10-03-2022, 04:01 PM | #11 | |
Rep 5,801
But the wheel widths and offsets will determine if you hit. I have front 245/40-18 Michelin Pilot Sport 4S tires on stock BMW 400M wheels which are 18x8.0" ET34. I'm lowered 0.8" in front and I clear everything fine. My square setup has the same in back with no problem Hope this helps! |
