BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > How to reset oil service / brake pad service indicator
      09-14-2013, 01:53 AM   #1
Sephanite
Drives: BMW Z4
1. Without pressing the brake/clutch, press the start/stop button
2. Wait for the service reminder to disappear
3. Press and hold the odometer reset button. You will notice your trip meter reset and then go back to the value it once was. Keep holding for a couple more seconds
At this point, service values that can be reset will come up. Use the odometer reset button to scroll through the menu.
4. At the value you want to reset, press and hold the odometer reset button. "Reset possible" will change to "Reset?"
5. Press and hold odometer reset button again until value is reset
6. Press the start/stop button to start car or turn off car
Appreciate 7
      09-27-2013, 07:06 PM   #2
Jackalripp
Jacko
Drives: 2012 335i Sport line
2012 BMW 135i  [0.00]
Send a message via Yahoo to Jackalripp
F30
Does this work on the 2012 F30 models?
      09-28-2013, 02:57 AM   #3
Sephanite
Drives: BMW Z4
yes mine is a 2012 f30
      12-22-2014, 09:35 AM   #4
Osmansky
Drives: BMW 316i
Hi
For some reason after the last oil change i couldn't reset the mileage through the cluster
Every time i try to reset i get an error message "reset unsuccessful"
Now its showing "-2000 kMs"
I have a retrofitted NBT so i dont want to go for BMW service as they will say the car needs reprogramming. The guy who retrofitted my NBT said i can use some tools such as ISTA or ISPI NEXT to reset the oil interval
Any feedback will be appreciated
Cheers
      04-08-2015, 12:19 PM   #5
edward.b.mendez
Drives: 2012 BMW 335i Sport line
Originally Posted by Osmansky View Post
Hi
Cheers
I have the exact same problem with my 2012 335i and the dealership in Syracuse can never get it right the first time without me traveling an hour just for them to reprogram the darn car. Does anyone know of a workaround or is this something that any other service center can do without me having to go to the BMW dealership?
      04-10-2015, 03:13 PM   #6
Osmansky
Drives: BMW 316i
Actually what solved me problem was not BMW authorized dealer. Another unauthorized dealer reset the oil interval for me. He just resets this ecu
      04-17-2015, 12:05 AM   #7
group
Drives: Honda
I have a retrofitted NBT so i dont want to go for BMW service as they will say the car needs reprogramming. The guy who retrofitted my NBT said i can use some tools such as ISTA or ISPI NEXT to reset the oil interval..???
Get fast success in certkiller 70-411 and questions by using our 642-874 latest exam We also offer up-to-date www.usna.edu and answers for your prep
      07-20-2017, 09:11 PM   #8
3.0L
3.0L's Avatar
Drives: M235i
Took me several tries, but it finally worked. Many thanks!
///M235i | Mineral Grey Metallic | Premium Package | Technology Package | Driver Assistance Package | Dakota Coral Red/Black Leather | Harman/Kardon Premium 360 watt sound system | 8-speed automatic
Want a Cookie?.
      08-21-2017, 01:39 AM   #9
jackiesimon
Drives: BMW M3
I have used unauthorized dealer to solve this problem. And it really helped me
I like to travel on my car. It is more comfortable and I can stop with my family everywhere and just enjoy the rest
      03-27-2018, 08:39 AM   #10
Axman85
Drives: 335i x-Drive M-Sport Min. Grey
Anyone know how to reset the vehicle inspection reminder? It's not on the list that appears in this reset thread.
Never mind, figured it out in iDrive.
      09-10-2018, 12:35 PM   #11
Lietuvis
Drives: BMW 316d 2013 sedan.
Doesnt work on 2013yrs model. says ,,reset is possible'' but if you try to reset it says ,,reset is unsuccesful''
      09-10-2018, 01:57 PM   #12
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
Reset what? Brakes? If the wear sensor has been tripped it must be replaced to reset the brake wear indicator.
      09-10-2018, 02:05 PM   #13
bavarianride
Drives: bimmer
Does the sensor have 2 trip points, one at 3000-ish miles, the other at minimum pad thickness?
      09-10-2018, 03:25 PM   #14
Billfitz
Billfitz's Avatar
It has one trip point, at about 3mm. When mine went off it started counting down from 1,000 miles, literally, with an update every 100 miles.
      09-10-2018, 06:36 PM   #15
bavarianride
Drives: bimmer
So if pads are replaced at 5mm without tripping sensor, then very likely sensor will not need replacement then. My guess is the electrical contact can be cleaned up and the sensor can be reused.
      09-10-2018, 10:35 PM   #16
Billfitz
Billfitz's Avatar
You can reuse the sensor if it hasn't been tripped. I did on my front pads. It didn't trip because the front sensor is on the driver's side, while the pads that were just about toast were on the passenger side.
      12-01-2018, 02:14 PM   #17
Tonkabot
Drives: 2015 435iX Gran Sport
Just Finally put my rear brakes on the 2015 435iX. The instructions at the top worked perfectly.
I drove another 4500 miles after the rear sensor activated. I didn't realize the car would tell me if it was the front or rear, so I eyeballed them and thought the fronts were more worn, and bought and replaced those only to see the front sensor was not tripped.
At 4500 miles after sensor trip the rear pads had still not worn down to metal, but they were getting close.
I've got the single piston rear calipers, and 4 piston front.
There are apparently 3 different rear brakes.
First time I ever did this type of front brakes, it was quite easy - knocking out the pins with a punch is easier than getting the floating caliper pins back in, I like it.
      07-04-2019, 06:09 AM   #18
Wachtman98682
Drives: 2016 320i xDrive
Change reminder from KM to Miles ?
My oil service reminder is showing KM. Can it be changes to show miles?
      07-04-2019, 09:15 AM   #19
Billfitz
Billfitz's Avatar
You should start a new thread so that your question will be visible, as the subject is not that same as that of this thread.
      02-05-2020, 04:34 AM   #20
hmendes3
Drives: F31
SOLVED (brake service)
With "ISTA D" and ENET cable (Y) yessssssssssssssssssssssssssss
I've tried everything before (Instrument cluster menu, OBD ELM327 with Carly, E-SYS, BMW tools, etc.) with no success.
      09-28-2020, 04:41 PM   #21
SD Convert
Drives: 2017 430i convertible
When I try this, I get the following menu:
Identification
System test
Start roller
Test end
Unlock
How do I get to the menu to reset my brake fluid & pads?
Thanks.
      09-28-2020, 04:50 PM   #22
SD Convert
Did some more digging. I was holding the button down too long. Brakes reset
I also unlocked that menu (unlock code is the sum of the last 5 digits of VIN) and found some potentially interesting menu options.
