09-16-2013, 05:40 PM | #23 |
Rep 3,780
I see no reason for one car to out slalom the other. This is not the 335 vs 328 where we have different engines, balance, noticeable weight and weight placement.
Same engine and trans, same suspension, 100lbs at most variance, and as little as 50lbs when you option a 320 up a bit more than BASE-and that weight is not exclusively over the nose like a 335 in comparison to a 328. One will out shine the other only with the variable of drivers, tires, conditions etc. All it would take is a 320 with a better tire than a similar 328 or vice versa.
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc) '15 Buick Regal "T"(wife) '06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc) |
09-16-2013, 05:46 PM | #24 | ||
Rep 3,619
EBII 2014 335i xDrive
335HP, Sport AT, 19" Wheels, MPE, Prem, Tech, Cold, HK, Driver Assist & DH pkgs Deep Sea Blue Metallic 2013 X5 35d Sport Prem, Convenience, Cold and Premium Sound packages |
09-16-2013, 05:52 PM | #25 |
Rep 430
09-16-2013, 05:55 PM | #26 | |
Rep 3,780
But tuned 320's can be tuned 90% as aggressively as the 328's, so the gap is small.
09-16-2013, 06:10 PM | #27 |
Rep 2,182
Drives: .
Garage List 2018 Audi RSQ3 (8U) [0.00]
2022 BMW X3 xDrive3 ... [10.00] 2015 BMW M235i (F22) [10.00] 2017 Mini Cooper S ... [0.00] |
I always seem to be learning things from your posts. Very informative. Thanks.
09-16-2013, 06:20 PM | #28 |
Rep 5,097
I read the drive and half shafts on 328i are beefer than 320i, that probably will be a factor on how aggressive the 320i can be tuned.
09-16-2013, 06:40 PM | #29 | |
Rep 3,780
Where did you see that, sure it applied to US cars? In some countries, the 320 has smaller brakes, not here. It would surprise me that they kept the bigger brakes for the 320 in the US, but downsized the other running gear components.
09-16-2013, 08:15 PM | #30 | |
Rep 3,332
I'm not saying it's an inferior car - but by every almost measure the 328i will be faster on the road and on the track.
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette |
09-16-2013, 08:26 PM | #31 |
Rep 430
Why no 100% of the boost and benefiting from the higher compression ratio, getting more?
09-16-2013, 09:33 PM | #33 | |
Rep 3,780
You reach a point where the pistons want to see daylight. Low compression means high boost, increasing compression and boost typically not a good combo when going for more power. |
09-16-2013, 11:57 PM | #34 | |
Rep 5,097
6/2013 production N26 for USA(earlier months have same numbers) rear axle output shafts -- 320i: 28mm; 328i: 31mm; 335i: 35mm drive shafts for AT -- 320i: 1563mm; 328i: 1539mm; 335i:1508.5mm The output shafts are beefer for higher HP engines. On the drive shafts, I assume shorter ones may have better power transfer? Not sure. Another interesting observation is, for N20, the MT drive shafts are longer than AT ones(same trend for all 3 engines). EDIT: On the brakes, I recall US spec 328i has smaller brakes than European ones, I wonder if that is the same for 320i too, maybe it is really 328i gets degraded rather than 320i is kept the same as 328i. Last edited by bavarianride; 09-17-2013 at 12:12 AM.. |
09-17-2013, 08:26 AM | #35 | |
Rep 3,780
Looking at all of those numbers, about a 10 percent variation in diameter, we are talking about weight differences here and maybe 1lb lol. In terms of ability to handle power...should be another non issue. In my experience BMWs start shredding driveline parts like driveshafts and axles at silly TORQUE amounts like 600+ ft lbs to the wheels is when my cars are known to do that.
09-17-2013, 10:18 AM | #36 | |
Rep 5,097
09-17-2013, 11:28 AM | #37 | |
Rep 3,780
Would you believe my E36/7 hit 81k miles this week and its on the ORIGINAL and STOCK brakes and clutch. The clutch is holding twice the power of stock and has yet to slip. I only replaced the headgasket just now, not because it failed from 13+psi, but to ensure future reliability and hold more boost. So even if the 320 has a bit daintier components, I do not see it being a failure point until power levels reached that would not happen until big turbos and or internals are beefed up.
09-17-2013, 11:43 AM | #38 | |
Rep 5,097
09-17-2013, 11:57 AM | #39 | |
Rep 3,780
Everyone who hears my clutch and brake specs assume I must granny shift and drive it like a little old lady. They take that back when they get a ride in the car. However, I never launch the car from a dig. If you throttle it in 1st enough to build boost, it's a smoky fishtailing show. To me, BMW drivetrains sell me on the mark. They are always faster than they should be given the specs.
09-17-2013, 12:18 PM | #40 | |
Rep 5,097
