09-26-2013, 12:39 PM | #1 |
Rep 1,449
New Break-in Guidelines for M4?
I was curious to hear input from the outstanding gear heads here if there is any word or your educated guess on what the new break in period will be for the M4. Now that we know the critical Dyno figures what say ye?
1- Rev limit 2- Miles to break in service 3- Speed limit Mainly interested cause I do plan to do ED and want to plan for mileage needed before I can open her up on the Ring. |
09-26-2013, 02:30 PM | #2 |
Rep 3,450
you're putting the cart before the horse here.
too many unknowns and break-in is a subject with two schools of thought and little documented evidence to statistically prove one way is better than the other. |
09-26-2013, 02:43 PM | #3 |
Moderator
7515
Rep 19,368
What are F10 M5 break in guidelines and break-in service mileage? Are they different from E60 M5? The answers to those will likely predict those for your questions regarding the new M3.
09-26-2013, 02:47 PM | #4 | |
Rep 1,449
201X ???? Coming soon
2015 F80 M3 AW/SO - Going Going Gone! |
09-26-2013, 04:28 PM | #5 |
Rep 9,709
Agreed, the M4 has the same rear diff as M5/M6 (1200mile diff oil change). Same DCT gearbox, so suspect break in will mirror F10/F13 M models.
09-26-2013, 05:34 PM | #6 |
Rep 10,407
Pretty much /thread after post #2. But I'll still contradict that point...
Break in is as much or more about transmission, clutches, diff, axles, etc. as it is about engine. Your new M4 engine will have been taken to redline at the factory before you get it. Whatever BMWs guidelines are now or will be, they certainly do not have to be followed religiously.
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK | | Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors | | Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels | | XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit | |
09-27-2013, 08:20 AM | #8 |
Rep 1,425
Drives: MacanGTS, 991.2GT3, E63wagon
09-27-2013, 08:46 AM | #9 | |
Rep 7,298
i wonder if they come with ss lines already? |
09-27-2013, 10:34 AM | #10 | |
Rep 1,425
09-27-2013, 10:44 AM | #11 |
Rep 1,425
Oh and I am sure the normal brakes with SS lines and a good pad will be more than sufficient. I am the first to admit 50% of the decision is for the bling. What I really wish they did was offer slotted rotors. I am sure with more cars getting CCB we will see good aftermarket CCB options come for the car. Or just steel rotor replacements. One thing to keep in mind is that on the M5/6 it uses a different brake booster for CCB since it has higher friction. I remember reading that in the detailed PDF. So going to steel might make for excessively grabby or prematurely wearing rotors.
01-16-2014, 08:32 PM | #12 |
Rep 68
1200 mile service/10w-60 for the new engine?
I know the answer is probably no, but I thought I'd still ask what everyone else thinks. Do you think we'll need the 1200 mile break-in service with the new Ms? Also will they require the nice 10w-60 oil or the crappy 5w-30? I'm guessing since there will be no 1200 mile break-in and you can use the standard oil used in other BMWs.
01-16-2014, 09:09 PM | #14 |
Rep 68
Same bore and stroke as N55. It's not going to use a different oil. Therefore, I concluded it wouldn't need the 1200 mile service as N55 generally doesn't. That being said, I wanted to see what the experts think about it.
01-16-2014, 09:18 PM | #15 |
Commander-In-Chief
2122
Rep 8,924
Drives: 2023 M2 Coupe, 2020 GLE 450
Oil spec for S55
Same bore and stroke means nothing. The working stresses on almost all components are much higher. The fact this engine has a special forged crankshaft tells you something. The driving style from the average owner is expected to be more extreme. I would not be surprised to see a higher or different spec oil requirement from the N55. The cost of the exclusive oils over the ownership period is negligible, IMO, if they better protect the engine.
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 |
01-16-2014, 11:49 PM | #16 | |
Moderator
7515
Rep 19,368
The initial service is not just for the engine oil. The M5/M6 require service at 1200 miles:
http://f10.m5post.com/forums/showthread.php?t=765513 Which you can see covers transmission and differential just as with past M vehicles. And, the engine oil gets changed despite similarities with N63 V8, you'll notice. So, in conclusion, the F8x will probably have the service too. As for oil type, it's not known yet either but the S63 does not use 10W-60. It can take 0W-30, 0w-40, 5w-30 or 5w-40. We'll see how it goes for the S55. Quote:
01-17-2014, 08:24 AM | #17 | |
Rep 2,148
01-17-2014, 09:26 AM | #18 | |
Rep 6,697
My PCar diesel takes 5W-30, but it takes a special diesel forumlation designed not to foul the particulate filter or urea injection system. And let me tell you, it's not cheap. Even M1, in bulk, is $8 / quart. If I bought Porsche oil it would be double. |
01-17-2014, 02:07 PM | #20 |
Rep 2,997
It's too early to know. 10w60....whatever, there's no reason for that spec today. It's just more of a tradition and partnership than anything else. It's not like Porsche spec's 10w60 in their track or turbo vehicles, or any of the other major hard charging manufacturers who build reliable NA and FI engines.
But 10w60 is more a reflection of piston and ring design as well as crank forces. .... In terms of the 1200 mile service, probably will stay around. |
01-17-2014, 02:09 PM | #21 |
Commander-In-Chief
2122
Rep 8,924
Oil spec
And you can be sure BMW will spec the lowest viscosity they can, as it can have an effect on fuel economy.
01-17-2014, 02:20 PM | #22 |
Law Enforcer
25117
Rep 22,290
Drives: '22 Chalk Gray Porsche C2S
