09-27-2013, 03:41 PM | #1 | ||
Rep 428
Some recall news, hopefully with minimal impact!
Saw on the other forum, hopefully they figure something out right away!
Only for N20 and N26 engines Quote:
September 27, 2013 Technical Service October 11, 2013 DCSnet Message Urgent Subject: Delivery Stop N20 N26 Vacuum Pump Oil Supply Message Recipients: General Managers, Sales Managers, Service Managers, Service and Parts Directors, Parts Managers, Service Advisors, Shop Foremen On September 26th, BMW of North America, LLC announced to NHTSA its intention to conduct a voluntary Recall on certain 2012-2014 model year BMW 3 Series, 5 Series, X1, X3 and Z4 models equipped with the N20 or N26 engine, produced from May 2012 to August 2013. Affected vehicles in center inventory must not be retailed or delivered until the Recall repair has been performed. Refer to the file “N20 N26 Delivery Stop.pdf” for vehicles which must be held. Vehicles at BMW vehicle delivery centers will be corrected before shipment to your center. Situation: The oil supply via the intake camshaft to the vacuum pump could become restricted. If this were to occur, the vacuum pump could fail due to lack of lubrication, resulting in a loss of power brake assist. A repair solution for vehicles already retailed is under development and not available at this time. Customers will initially be informed of the Recall in November by letter; and again when parts become available. Please do not contact the Parts Technical Group (PTG) requesting parts. Sincerely, Technical Service |
09-28-2013, 01:22 AM | #2 |
Rep 34
Drives: 2014 328i
Are there details in that “N20 N26 Delivery Stop.pdf” file regarding exactly which vehicles this affects? Is there a VIN range? I have a car in transit which was built at the very end of August which may need the fix.
Normally I'd check the BMW website but the recall search page isn't currently working. |
09-28-2013, 02:45 PM | #3 | |
Rep 428
09-28-2013, 06:41 PM | #4 |
Administrator
40871
Rep 21,240
September 27, 2013
Technical Service October 11, 2013 DCSnet Message Urgent Subject: Delivery Stop N20 N26 Vacuum Pump Oil Supply Message Recipients: General Managers, Sales Managers, Service Managers, Service and Parts Directors, Parts Managers, Service Advisors, Shop Foremen On September 26th, BMW of North America, LLC announced to NHTSA its intention to conduct a voluntary Recall on certain 2012-2014 model year BMW 3 Series, 5 Series, X1, X3 and Z4 models equipped with the N20 or N26 engine, produced from May 2012 to August 2013. Affected vehicles in center inventory must not be retailed or delivered until the Recall repair has been performed. Refer to the file “N20 N26 Delivery Stop.pdf” for vehicles which must be held. Vehicles at BMW vehicle delivery centers will be corrected before shipment to your center. Situation: The oil supply via the intake camshaft to the vacuum pump could become restricted. If this were to occur, the vacuum pump could fail due to lack of lubrication, resulting in a loss of power brake assist. A repair solution for vehicles already retailed is under development and not available at this time. Customers will initially be informed of the Recall in November by letter; and again when parts become available. Please do not contact the Parts Technical Group (PTG) requesting parts. Solution and Repair A repair solution for vehicles already on the road is under development and not available at this time. Existing owners will be notified of the recall in November by letter and again in December by letter when parts are available. Wait to receive your notification letter before contacting your dealership for service. The repair letter will be sent when the dealership has the necessary parts, tools and procedures to preform the repair. The solution involves inserting a locking ring onto the camshaft so the oil supply to the brake assist vacuum pump is not impaired. The repair will take approximately two hours but can vary depending on your BMW dealers schedule. The repair will be preformed free of charge. Affected Models 2012-14 320i/328i, 320i/328i xDrive Sedan manufactured between May 2012 – August 2013 2014 328i xDrive Sports Wagon manufactured between March 2013 – May 2013 2012-13 528i, 528i xDrive Sedan manufactured between June 2012 – June 2013 2013-14 X1 sDrive28i, X1 xDrive28i manufactured between June 2012 – June 2013 2013-14 X3 xDrive28i manufactured between June 2012 – August 2013 2012-14 Z4 sDrive28i manufactured between June 2012 – June 2013 Models not list are not affected due to different lubrication and vacuum pump designs. Number of vehicles affected in the US Up to 76,190 BMWs are affected by this safety issue. The model break down is as follows - 2012-14 320i/328i, 320i/328i xDrive Sedan - 37,473 potentially affected 2014 328i xDrive Sports Wagon - 176 potentially affected 2012-13 528i, 528i xDrive Sedan - 12,708 potentially affected 2013-14 X1 sDrive28i, X1 xDrive28i - 10,547 potentially affected 2013-14 X3 xDrive28i - 14,517 potentially affected 2012-14 Z4 sDrive28i - 770 potentially affected Known accidents BMW is aware of three minor accidents with no confirmed injuries as a result of this problem. The NTSB has 7 reported incidents but that does not mean they have 7 accident reports. Vehicles affected have experienced the failure at low millage. It is not clear if having a higher mileage car means you will not have the failure. Should you continue to drive your N20/N26 powered BMW BMW says it is safe to continue to drive your vehicle for now. As soon as you get the service letter that will be coming in December you should have the recall work performed. If you feel a loss of braking power pull to the side of the road and have your BMW towed to the nearest dealer by BMW Roadside Assistance. Are 4 series deliveries going to be affected BMW has not commented at this time on the 4 series. Models produced as recently as August are affected so it is possible early production 4 series (production started in July) will be held at the vehicle delivery center until the repair is available. We will continue to follow the 4 series delivery story and provided updated information as it happens. What to do now We have no choice but to wait for the letters and more information from BMW. In the mean time everyone be careful out there. There are 7 reported incidences of issues to the NTSB so far. The NTSB estimates that for ever report there are 40+ incidents that are not reported. Has anyone had trouble loss of brake assist in their N20/N26 powered BMW? Does this make anyone nervous to drive their BMW?
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook Follow us on Bimmerpost Twitter Subscribe to Bimmerpost Youtube Channel |
