BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Fog light coding question
      11-09-2013, 02:20 AM   #1
wayner44
Drives: bmw
Hello does anyone know what to code to have the fog lights automatically come on when the headlights are on?
Not the high beams because I know that is illegal.
I like the extra light on the sides while driving and it would be much more convenient if they came on automatically.
      11-09-2013, 08:07 PM   #2
shawnsheridan
Supreme Allied Commander
shawnsheridan's Avatar
Not possible.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      11-10-2013, 01:49 AM   #3
Takkey
Drives: 2019 G20 320i
Hello!
FEM_BODY 3062 LceLampMapping2
MAPPING_NEBELSCHW_L_FUNCTION = 03
MAPPING_NEBELSCHW_R_FUNCTION = 03
If automatically come on when small lights.
MAPPING_NEBELSCHW_L_FUNCTION = 01
MAPPING_NEBELSCHW_R_FUNCTION = 01
However, Foglight switch is disabled.
AndrewC198911329.00
      11-10-2013, 10:25 PM   #4
shawnsheridan
Originally Posted by Takkey View Post
Hello!
The 03 and 01 are Werte Values?
What is the difference the two values?
      11-11-2013, 07:35 AM   #5
Takkey
I write down the results that I have examined.
01 = Small Light ?
02 = Small Light ?
03 = Low Beam
04 = DRL
05 = High Beam
06 = Blinker L
07 = Blinker R
08 = Fog Light
09 = Cornering Light L
0A = Cornering Light R
0C = Brake Light
0D = Brake Force Light
0E = Rear Fog Light
0F = Reverse Light
10 = Parking Light L
11 = Parking Light R
AndrewC198911329.00
psyki303.00
visionaut1732.00
      11-14-2013, 10:19 AM   #6
F30-BKK-JKT
Thailand
Drives: F30XXX
It worked......
Now i have drl on halos and fog at the same time..... Thanks japanese coders
VMR - BC Coilovers - aFe - M Performance - CODED
      11-21-2013, 08:12 AM   #7
JK479
JK479's Avatar
1557
Drives: I6-> iX
Can this coding be done without a computer? Anyone in RI/MA area care to help me just get my car coded so the fog light doesn't appear on turns?
      11-21-2013, 08:50 AM   #8
kapkanimd
Drives: 2020 M8 Competition Gran Coupe
Originally Posted by F30-BKK-JKT View Post
It worked......
Is the fog light switch disabled in yours now? Are you able to turn them off at all ?
      11-21-2013, 09:07 AM   #9
shawnsheridan
No. A computer is needed to make the coding.
      11-22-2013, 03:24 PM   #10
bmw_fascinated
bmw_fascinated's Avatar
31
Drives: F22 228i
nice coding, I'll bookmark this page.
Does "small light" mean that all sidelights/parking lights are on?
Is it possible to code the DRL to stay off until the parking lights (small lights?) are turned on and dim again when switching to lowbeam or turning off the ignition?
I like to observe stars and don't want to tape the headlights when leaving earlier from a meeting
      12-08-2013, 02:56 PM   #11
milest
Turkey
Drives: F30, born 10/23/2012
      12-10-2013, 01:53 AM   #12
Timur
Russian Federation
Drives: BMW 320
Thanks for sharing
      03-05-2018, 09:34 AM   #13
oranga
Drives: 335 6mt
I know i'm posting in an ancient thread, but this seems like the most relevant one I've come across.
I coded the following:
MAPPING_NEBELSCHW_L_FUNCTION = 04
MAPPING_NEBELSCHW_R_FUNCTION = 04
so that the fog lights come on with the DRL angel eyes. During the day when my low beams are off (headlamp switch in auto position), it works just like i want - only the fog lights and angel eyes are on.
However, when it gets dark and the auto headlamps turn on, the fog lights turn off.
I realize if i code the values to 03, then the fog lights will come on with the automatic headlights, but then I wont get the angel eyes + fog lights only during the day.
Is there a way I can get best of both worlds? Basically I want fog lights on all the time.
      03-05-2018, 04:20 PM   #14
a803sgo
Drives: BMW 320D M-SPORT (F30)
I only want fogs with high beams what would be the coding for this?
      03-05-2018, 04:57 PM   #15
oranga
Drives: 335 6mt
If you want the fogs to ONLY come on when the fog lights do, then you would change the values for the two lines to be equal to 05. Refer to Takkey's 2nd post in this thread, he breaks down the values that would correspond to the different lights.
However, if you want to prevent the normal behavior of the fog lights shutting off when you flip the high beams on - you would code the following:
FEM_BODY 3050 NSW_AUS_BEI_FL
aktiv
      03-05-2018, 05:39 PM   #16
a803sgo
aktiv
      03-11-2018, 09:58 PM   #17
oranga
Drives: 335 6mt
anyone?
      03-14-2018, 01:47 PM   #18
vooonoo
¯\_(ツ)_/¯
vooonoo's Avatar
537
Drives: f30 328
2014 f30 328i  [0.00]
I'm commenting in here so I can come back to the thread. So Is or isn't it possible to have the fogs automatically come on with the low beams?
      03-14-2018, 02:13 PM   #19
atzebmw
Drives: Tesla Model 3
No, not automatically.
      03-14-2018, 03:06 PM   #20
oranga
Drives: 335 6mt
Not true, if you code the following:
the fog lights will come on with the low beams.
Basically what those lines are doing is telling the computer to treat the fog lights not as fog lights anymore, but as a different light function, denoted by a number as outlined in Takkey's post.
So if you instead set those values to 0C, the fog lights would only come on when you hit the brakes, lol!
Like i mentioned in a previous post, i have mine set to 04, so my fog lights come on with the angel eyes, however they do not stay on when the low beams turn on, even though the angel eyes are still on.
Someone's gotta have the answer out there right?
      04-09-2018, 11:10 AM   #21
XC007
Drives: 320D F31
The problem is that when low-beams are switched on, the angel-eyes turn off and the parking-lights are switched on in their place (the same but with low intensity). That's why the fogs turn off when low-beams switch on.
If you want the fogs to stay on with parking lights, low-beams and high-beams, then code with option 01. However, they will not be on with angel eyes.
Note that in any option the fogs switch will not work, except if the code is 08.
XC
      04-09-2018, 02:43 PM   #22
oranga
Drives: 335 6mt
Thats a great explanation, thanks XC!
Is there a different coding section that can force the fog lights on, all the time?
