BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > F30 spare tire solution
      11-09-2013, 06:24 PM   #1
ZheHbKa
ZheHbKa's Avatar
Drives: the Wind
2014 BMW 335 Xi  [5.00]
for those who have non run flat tires this is a must, for others just a piece of mind.
here is what the spare looks like and process to building it:
1) bmw E60 spare tire rim- $60
2) kuhmo 135/90/17 tire - $30
3) harbor freight scissor jack - $20
4) 15mm spacer + 5 45mm lugs - $50 - this is what i am selling
$160 total - compare to fully built one for f30 for $450
i tested it on both front and rear wheels and is a great solution, clears M sport brakes and M performance brakes
1. For the spare rim:
http://www.getbmwparts.com/parts/201...=Spare%20wheel
If the link doesn't work, go to list of parts for 2010 535 and then
FRONT SUSPENSION / WHEELS / WHEELS / Spare wheel
2. For the tire, you need 135/90/17. I don't think they have this size tires posted on their website, but you can call them and get the quote. I think the cheapest one they have is around $60-70.
4.For the spacers - i bought a pair, you can save half and get my second half
spare is easily stored in the trunk and secured, does not add significant weight but definitely gives a piece of mind while driving
Any other questions let me know
2014 F30 335 X-Drive | 6-MT | Alpine White/Coral Red | ZMM ZDH ZDA |
      11-10-2013, 02:30 AM   #2
synclastica_86
synclastica_86's Avatar
Hong Kong
147
Drives: F32 435i, E92 M3, S550
Stupid question: is there a space for the spare? Will the performance gain compensate for the extra weight?
      11-10-2013, 06:23 AM   #3
Newton2001
Newton2001's Avatar
Switzerland
Drives: 435i X-Drive M Sport ('13)
Whoaw, cool!
So whatever the size of the other tyres, the whole wheel size stays the same, right?
Si you can use your 17'' spare wheel among 3 other 19'' for a short distance...
Can you make a picture of where you put the jack, spare tyre, etc.?
Thx
      11-10-2013, 06:47 AM   #4
oceanview
oceanview's Avatar
Switzerland
187
Drives: 335i F31 RWD Autom.
Works, unless you've the 18" M Sport Brakes or M Performance Brakes...
Wonder if there is a spare wheel option for that setup too?
EDIT: Ups, just read you tested on that setup?! Does that really work? I'm surprised.
EDIT: Ups, just read again. Together with the 15mm spacer it will clear 18" M Sportbrakes.
To much cross-reading
      11-10-2013, 10:17 AM   #5
zenm@ster
Drives: 535i M Sport
Is a can of fix a flat an option??
Seems more convenient and will probably be sufficient for the vast majority of flat tire issues.
      11-10-2013, 01:54 PM   #6
ZheHbKa
ZheHbKa's Avatar
Drives: the Wind
Not sure about performance to weight gain but ride quality and thread life is definitely better of non rft tires
There is more than enough space in the trunk, jack and wrench fit nicely in the compartment under the trunk cover
Yes works great clears all bmw oem brakes
Pic of the trunk placement attached
Can won't help much heavy car and is very short term
      11-10-2013, 01:55 PM   #7
ZheHbKa
ZheHbKa's Avatar
Drives: the Wind
Originally Posted by Newton2001
Whoaw, cool!
Thx
Yes it's a great solution to get home and then to a tire shop
      11-10-2013, 01:57 PM   #8
ZheHbKa
ZheHbKa's Avatar
Drives: the Wind
Sorry forgot attachment
      11-10-2013, 10:36 PM   #9
joedoe
Drives: 2014MY BMW328i
The useful content is hidden in the dark trunk
      11-11-2013, 09:36 AM   #10
QTC
Drives: '13 F30 320i; B6 A4 1.8T
Can you confirm that the HF scissor jack fits the F30? I read about it fitting the E90, but wanted to make sure before I plunked down the whopping $20 for it. Last piece I need (already have a compressor and plug kit). TIA!
      11-11-2013, 10:54 AM   #11
ZheHbKa
ZheHbKa's Avatar
Drives: the Wind
yes, and really any jack for a mid size sedan will work. fitting is pretty universal
      11-11-2013, 10:56 AM   #12
ZheHbKa
ZheHbKa's Avatar
Drives: the Wind
how about this one
      11-12-2013, 08:36 PM   #13
Newton2001
Newton2001's Avatar
Switzerland
No, I didn't that was my question... so with M Sport Brakes (2NH) you can go under 18' wheels, is that what you mean?
      11-12-2013, 08:58 PM   #14
Axman85
Drives: 335i x-Drive M-Sport Min. Grey
how about this one
So if you have to pick up your best buddy and his wife ( who has a suitcase for shoes) and another for her other things; do you leave the tire behind or her suitcases?
Better off with non run flats and AAA to get your car towed than using your trunk for a spare.
sahajesh812.50
      11-12-2013, 10:54 PM   #15
DJax
Drives: 328D, 997
[QUOTE=ZheHbKa;14950138]for those who have non run flat tires this is a must, for others just a piece of mind.
I have two questions...
What size are your original tires?
Why are you running a 15mm spacer?
Shouldn't the spare fit without the spacer?
DJax
      11-13-2013, 07:02 AM   #16
ZheHbKa
ZheHbKa's Avatar
Drives: the Wind
[QUOTE=DJax;14965889]
What size are your original tires? m-sport 18's
to clear M-sport brakes (since this is 17" spare)
Shouldn't the spare fit without the spacer? this spare rim won't, min 18" rim will but its more $
DJax
      11-13-2013, 07:04 AM   #17
ZheHbKa
ZheHbKa's Avatar
Drives: the Wind
space is a bit of a tradeoff but run flats are expensive and little thread life
      11-13-2013, 09:29 AM   #18
BMWFanatic2008
BMWFanatic2008's Avatar
190
Drives: M4
You might end up waiting for HOURS for a tow truck to show up plus run a risk of scratching/messing up your car (these guys don't know what they're doing).
F87 X4M Comp | Toronto Red | SO/Black Extended Merino Leather | 8AT
F82 M4 | Yas Marina Blue | SO Extended Leather | DCT (Gone)
F80 M3 | Sakhir Orange | SO Extended Leather | DCT (Gone)
F30 335xi | MSport | Estoril Blue | Sport 8AT (Gone)
F30 335xi | MSport | Estoril Blue | 6MT (Gone) | E92 335xi | MSport | LMB | AT (Gone)
      11-25-2013, 06:15 AM   #19
Feanor
Drives: BMW F30 320d Luxury 6MT
Indeed but these days what are the chances of a tyre being so badly damaged that a can of tyre weld won't get you home or to a garage?
In 12 years of driving and over 100,000 miles I have had two flat tyres, neither of which needed a spare - one was a slow overnighter I discovered before setting off, and one mid-journey that tyre weld would've sorted. If I'm representative of the average then I'm happy to take the risk of needing a tow truck once in 10-20 years for the sake of saving a fortune in tyres and having a usable and clean boot space.
In fact, even with a spare tyre people often need to call out a mechanic as wheels often get rusted into place - how many of us carry a soft headed mallet around or make sure suitable lube is applied to every wheel to prevent seizure?
      11-25-2013, 11:08 AM   #20
utenigma
Drives: 2013 F30 335i 8SA M-Adaptive
Originally Posted by Feanor View Post
how many of us ... make sure suitable lube is applied to every wheel to prevent seizure?
I always make sure suitable lube is applied
      11-25-2013, 11:38 AM   #21
Sedan_Clan
Law Enforcer
Sedan_Clan's Avatar
Brazil
6227
Drives: '17 Nardo Grey M4
Or you could just do what I do and use the E9X M3's tire inflation kit. Sure, it won't help with a blow-out, but for your basic flat tire it is extremely efficient.
      11-26-2013, 01:11 PM   #22
Stoofpilot
Naval Aviator
Stoofpilot's Avatar
Drives: 2013 328i
Where do you get the E9X tire inflation kit?
Meatball, Lineup, Airspeed means a successful carrier landing-most of the time.
Ah-those were the days!!
