12-03-2013, 06:26 PM | #3 |
Rep 152
What a shame!
mhdelarosa6.50 |
12-03-2013, 07:37 PM | #4 |
Rep 1,201
sport+ doesn't even do anything special. Turns traction down and makes the accelerator more twitchy. You're better off engaging sport mode and disabling traction control manually.
12-03-2013, 08:20 PM | #5 |
Rep 152
12-03-2013, 11:59 PM | #7 |
Rep 41,232
Try ICMQL => IcmKod_B_Sportlenkung = verbaut.
Sniper10153.00 xdrive_320i67.00 |
12-04-2013, 12:00 AM | #8 |
Rep 40
It is possible . I have done on on my 320i.
Do the following: Kombi => 300C ECO_FDS =>Function FDS_MENUE_TEXT_1=> menue_3 FDS_MENUE_SIGNAL_1=> menue_3 FDS_MENUE_TEXT_2=> menue_3 FDS_MENUE_SIGNAL_2=> menue_3 FDS_MENUE_TEXT_3=> menue_3 FDS_MENUE_SIGNAL_3=> menue_3 FDS_MENUE_TEXT_4=> menue_3 FDS_MENUE_SIGNAL_4=> menue_3 ICM Module/ 3000 Daten/ IcmKod_B_Sportlenkung/ verbaut EGS/3000 Applikation -> Sportschalter_alt -> aktiv EGS/3000 Applikation -> Sportschalter -> aktiv ICM/IcmKod_B_S2TBA -> verbaut It will activate sport+ and sport transmission ))) Or you also could add 2TB option and delete 205 in salapa element |
K3nnykl820.00 |
12-04-2013, 04:22 PM | #10 | |
Rep 152
I'm gonna try that and let you all know. |
12-04-2013, 08:45 PM | #12 | |
Rep 41,232
xdrive_320i67.00 |
12-04-2013, 08:50 PM | #14 |
Rep 41,232
SAT = Option 2TB Sport Automatic Transmission, which is the Paddle Shifters.
xdrive_320i67.00 |
12-04-2013, 10:55 PM | #15 |
Rep 376
I did just the sport + coding, but there is no actual word sport plus in the options, you just push one more past sport and sport plus shows up next to transmission selection. It's there just not... does the FDS MENUE text coding add it in, maybe?
I am guessing adding SAT without paddles is pointless then? |
12-04-2013, 11:03 PM | #16 | |
Rep 41,232
12-04-2013, 11:14 PM | #17 | |
Rep 40
12-04-2013, 11:19 PM | #18 | ||
Rep 40
12-05-2013, 05:46 AM | #19 | |
Rep 152
Im about to replace it with a 125M my friend is giving away since he is replacing his with a M Performance one. Is what you said above the only thing I need to get it working? Or do I need extra harness and coding? |
12-05-2013, 11:04 AM | #20 | |
Rep 41,232
For full 2TB retrofit, at least in F10, it is also GWS (Gear Shift) Module, but it is not needed for the paddles to work.
12-05-2013, 12:07 PM | #21 | |
Rep 152
What's full 2TB retrofit? Paddle shifters? |
12-05-2013, 12:11 PM | #22 | |
Rep 41,232
For F10, it is Steering Wheel with paddles and different GWS Gear Shift. For F30, I don't know if it is Steering Wheel with Paddles only, or also a different GWS Gear Shift.
