BMW Garage | BMW Meets | Register | Today's Posts | Search |
BMW 3-Series (E90 E92) Forum
Any reason why I shouldn't buy these? (Angel Eyes)
12-26-2013, 10:16 AM | #1 |
Gibbon
26
Rep 192
I'm thinking of ordering these Angel Eye bulbs for my LCI E91 (with Halogens):
http://www.ebay.co.uk/itm/2909704357...84.m1423.l2649 Anyone tried these or have any suggestions before I go for it? Thanks
Past Cars: Mini Cooper 1.6 / VX220 2.2 / Z4 3.0i / E46 320CD / E53 X5 3.0D
12-26-2013, 10:27 AM | #2 |
Rep 791
Id ve interested to see the outcome. Iv akways thought that would be the best way. As the standard halogen seem yo give a more solid light output compared to most of the anget eye designs out there.
12-26-2013, 11:31 AM | #4 | |
Rep 9,097
You will require http://www.ebay.co.uk/itm/2709397253...84.m1438.l2649 Search for 20W each bulb as these are 10W each. PS: The LEDs you linked are poor as 24W each is not going to be enough for the cars with xenons to match. There are 40W each out. Again, some companies are listing their H8 as 40W and they are not as bright as real 40W H8.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play |
12-26-2013, 02:22 PM | #5 |
Gibbon
26
Rep 192
Thanks for the info makkan, that's a good reason to not buy them if they won't actually work! Haha!
Those ones you linked look good and are a lot cheaper so that suits me, although the small print in the middle of the listing says "Your vehicle must have stock Xenon headlights for the LED angel eye kit to work and your car needs to have the yellow rings present to start with". Are they definitely the right ones for my car? Thanks |
12-26-2013, 02:29 PM | #6 | |
Rep 9,097
Search on ebay and the one I am talking about are similar in shape but for lci halogen headlights. Best one are 20W each as 10w each are not simply good enough.
12-26-2013, 03:00 PM | #8 | |
Rep 9,097
http://bit.ly/1abb5kf Its not cheap buy defo best in the market for lci halogen headlights.
01-24-2014, 02:35 PM | #9 | |
COBBY
Rep 14
Drives: 2008 E93 325i Convertible
01-26-2014, 05:38 AM | #10 |
Rep 2,445
Drives: 2018 630iGT sport
The trouble I had with the ones I bought (not the same as those linked, but they all share the same fundamental issue, IMO), is that the machined aluminium end cap doesn't lock into the light housing securely like the OEM bulb holder does.
They do fit in (eventually), but there is no positive "click" as it should lock into place. They just twist in....and to me at least...feels like they could just as easily vibrate and twist out. Another question i've asked sellers before is why the need for such a massive heat sink on the LED ones? If they chuck off that much heat, I personally don't really want them fitted into a plastic light housing thanks! |
01-26-2014, 06:17 AM | #11 |
Rep 14
Ive ordered these
http://www.ebay.co.uk/itm/1812759855...84.m1439.l2649 hopefully try and fit them tomorrow along with my new headlight bulbs |
01-26-2014, 11:13 AM | #13 | |
Rep 9,097
Good luck though.
01-30-2014, 02:01 PM | #14 | |
Rep 540
Easy to fit. Loads of room between the back the LED unit and the circular cover to put the wires and 2 electronic box thingies. Took 5 mins each side. I make life easier by removing the air filter cover and paper filter to give more room for my big hands at the back of the RH light. Seem OK to me. Here is the BEFORE These are much more yellow in reality than they appear here. and AFTER The brightness and colour are a true likeness. Hope they last longer than my last attempt at LED replacements for the H8 bulbs (different LED units). I got a full refund as both failed after a few months. Another thing. The H8 bulbs have 3 tabs which lock them in - these are offset and of different sizes. The LEDs will not seat properly unless you line up the different tabs with their respective slots. So take note of the position of the H8 when it pops out. RH H8 rotates anti-clockwise to remove when looking from the rear of the car and the LH H8 rotates clockwise when viewing from the rear of the car. Took me a while to realise that they rotated in different directions the first time I did this.
Jules
01-31-2014, 10:06 AM | #15 |
Rep 71
Looks pretty good. Will be cool to see what it looks like in varying weather conditions. I've just ordered a pair of weisslicht LED from bimmian. Should arrive next week and will post contrasting results.
BMW E92 325I M SPORT
02-06-2014, 06:18 AM | #17 |
Rep 3,200
Drives: E92 325i MSport Coupe
Unless you completely re-engineer the light unit, it will always be like that because the outer ring is powered by the same bulb that lights the inner ring, via a fibre optic cable...
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
