| 01-08-2014, 05:09 PM | #1 |
Rep 160
Dummy headlights?
Anybody else discovered that out of the 4 lens in the headlights, only 2 are used? At first I thought that 2 were for lows and 2 for highs, but they in fact use the same lens. I'm wondering why is that...
Ps: This is for the xenons. Last edited by Bassthe1st; 01-08-2014 at 05:12 PM.. Reason: add |
| 01-08-2014, 05:16 PM | #2 | |
![]() ![]() ![]() ![]() 430
Rep 885
Its also fair to assume its a cost issue in that the difference between independent lamps and an additional xenon arc within the same lamp was not sufficient to justify the additional headlight assemblies. My guess is that the swiveling nature of the lamps was also a factor in decisioning. For what its worth, I think the xenon lights are superb in their current form. |
| 01-08-2014, 05:38 PM | #3 |
![]() 8
Rep 100
It's not an additional Xenon arc...It's just a shutter that opens for high beams. This system called "Bi-Xenon" has been used by BMW since late 2001. The inner set of lights was used as a "flash" high beam or daytime running light. On new BMWs the halos (LEDs now) are sufficiently bright enough to be considered the running lights, and the inner non-functional lights are only to preserve the quad headlight style that BMW has become known for.
| 01-08-2014, 05:39 PM | #4 | |
Rep 2,266
F30 Sapphire Black M-Sport 335i 6MT |
| 01-08-2014, 06:03 PM | #6 |
Rep 243
Drives: 2013 335i M-sport
I wish they had put a turning light in there like the E9X's instead of making it a complete dummy. I'll be looking for a way to retro-fit it until they offer the LED LCI for the F30.
| 01-08-2014, 06:25 PM | #7 |
Rep 7,332
Drives: 2018 340i M Sport
Garage List 2018 BMW 440i Conve ... [0.00]
2010 BMW 128i Conve ... [0.00] 2006 BMW 330i Sport [7.17] 2018 BMW 340i M Sport [8.89] 2020 BMW M340i xDrive [9.00] 2018 BMW 340i M Sport [8.00] 2004 BMW 330i ZHP [7.83] 2000 BMW 328i [6.17] |
BMW should have left the inner lights as the flash-to-pass function, because quick, flashing operation of the xenon lights is detrimental to their longevity. I guess BMW figures this feature will be used infrequently enough that it will not significantly affect the lifetime of the xenons.
| 01-08-2014, 07:05 PM | #8 | |
![]() 8
Rep 100
| 01-08-2014, 08:37 PM | #9 | |
![]() ![]() ![]() 42
Rep 503
The shutter for high beams has been there for a while. While I can't say on the E90, the 2008 E63 had the shutter for brights and the inner bulb was only used for the Angel Eyes. |
| 01-08-2014, 10:55 PM | #10 |
Rep 2,266
It's illegal to flash your brights on the Autobahn to get somebody to move over. So I imagine it's not used much in daylight.
| 01-09-2014, 07:40 AM | #11 |
![]() ![]() ![]() ![]() 78
Rep 875
While the Xenons are blanked on the inner lens I'm pretty sure the new LED light option on the 4 series uses both lenses.
Looking forward to someone trying to install the 4 series LED inner workings into a 3 series. When we got my wife's 2011 X3 I day dreamed about installing a set of driving lights behind the empty lenses. Never got around to doing it but would be nifty. |
| 01-09-2014, 11:05 AM | #12 |
Rep 243
| 01-09-2014, 11:14 AM | #13 |
Rep 2,266
LOL. I did it myself last summer.
| 11-13-2018, 04:18 PM | #14 |
![]() 73
Rep 178
The inners are non-functional on the F30s. It’s there to preserve the traditional BMW look.
The newer (facelift) 320/330/340 with active LED lighting does use the inner lamp. I’ve also seen it used in halogen models (DRL/highbeam). |
| 11-13-2018, 04:54 PM | #15 |
![]() 27
Rep 66
Having non functional lights is kinda goofy.
I'm suprised no one ever figured out some kind of retrofit. I guess there's no need really... The halos look awesome and the xenon headlights are very good. |
| 11-14-2018, 06:03 AM | #18 | |
Rep 4,980
Drives: '23 X1 28i xDrive
| 09-03-2020, 07:14 AM | #20 |
Rep 18,319
Really? What damages did you, or anyone, suffer because two of the lenses are only there for cosmetic purposes? In the realm of First World Problems this one is way down the list.
| 09-03-2020, 08:14 AM | #22 |
¯\_(ツ)_/¯
1035
Rep 1,800
Lmaoooo +1
Planefixer4 Why??? They pass DOT regulations and provide adequate lighting. There is no need to do anything regarding the lights and BMW. If you have an A&P then modify your lights to add another projector.
![]() Apex SM-10/DWS06+ | 400m/X-ice Xi3 | Injen Exhaust | Stoptech SS Lines | 335 Front Brakes Hawk HPS 5.0 | RBF600 | ER Charge Pipes | Wagner Evo Comp 2 FMIC |
tex26702747.00 |
| Bookmarks |
