01-09-2014, 05:39 PM | #1 |
Rep 56
Traction Mode vs. Dynamic Stability Control (DSC)
Ok, I have a question re: the difference between the two.
Driving in all the snow we've had recently, I've been playing around with DSC. In regular driving mode (DSC on) when I gun the car on slippery roads, the icon lights up in the dash and I don't spin out. If I press the button on the console to turn DSC off, the dash light comes on telling me DSC is off and iDrive tells me I'm in "Traction" mode. So now, on snowy roads, I can get better traction, but if I gun the engine, the DSC light still flashes keeping me from spinning out. I thought that by turning off DSC, it would no longer do that? The manual said something about pressing and holding the button, but I'm not sure what that does differently than just pressing it and turning it on/off? Thanks in advance. |
01-09-2014, 05:43 PM | #2 |
Rep 3,780
To fully turn it off, you have to push and hold the button for a number of seconds, it might be as much as ten. One single push of the button does not turn it OFF.
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc) '15 Buick Regal "T"(wife) '06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc) |
01-09-2014, 05:43 PM | #3 | |
Rep 936
01-09-2014, 05:53 PM | #4 |
Rep 794
Drives: 2021 M2C, 97 M3
From BMW's web site:
Dynamic Traction Control (DTC) (Activated with a single press of the traction control button.): Dynamic Traction Control (DTC) allows more wheel slip and thus a more dynamic driving style with higher wheel traction and DSC controlling stability. A small amount of spin on the drive wheels improves traction when pulling off from a standstill in snow or on loose terrain. Dynamic Traction Control (DTC) is a sub-function of the Dynamic Stability Control (DSC) system that can be turned on and off. DTC has two major roles: to regulate traction and to enable sports-style driving while providing active stability control. When the drive wheels start losing traction the DSC automatically begins stabilisation measures. The Dynamic Stability Control system curbs the engine output and stops slip on the wheels. In exceptional situations, however, a small amount of wheel slip can be an advantage. When driving in deep snow, slush or on loose terrain a small amount of wheel spin improves traction. For these occasions, as well as those when the drivers want a sportier driving style, the DTC can be activated by pressing a button and this allows more slip and reduces the DSC’s curbing of the engine. The result: better traction and more thrust. The DTC also makes driving on snow and ice-free roads more dynamic. When activated, the DTC allows sporty drivers more room to manoeuvre around curves than the Dynamic Stability Control and even permits controlled drifts. The driver retains complete control over the vehicle in every situation and the Dynamic Stability Control’s stabilising measures remain active even when the DTC is activated. Pressing and holding the traction control button for a few seconds completely disables DSC
Performance Center Delivery, June 21, 2013: 2013 E92 335is | Le Mans Blue | Gray Leather with Black | 6MT | 19" Style 313's | Michelin Pilot Super Sports | BMW Carbon Fiber Rear Spoiler | |
jy228i6.00 |
01-09-2014, 06:59 PM | #6 |
Rep 503
The terminology between DSC/DTC quickly becomes confusing.
BMW refers to the situation as "The car defaults to DTC OFF. Pressing the button turns on DTC" The icon is the same between DTC ON and DSC totally off (pressing and holding the button) |
01-09-2014, 07:22 PM | #7 | |
Rep 794
Not the most intuitive, but I give BMW credit for not only giving us the traction mode, but being able to fully defeat it when desired and have it really be off.
01-10-2014, 02:14 AM | #8 |
Rep 36
As far as I can tell, the warning light is on in DTC mode just to remind you that the rear end can slide a bit, so you might not exactly stay centered in your lane as well as you should. But it won't actually let you spin out. I've never needed more than about a quarter turn of opposite lock with it. The power cut seems to be very minimal in most conditions. You can really spin up the rears pretty freely. Seems it doesn't like bumps though. If you hit a good sized bump you'll get a big power cut every time.
01-10-2014, 11:04 AM | #11 | |
Rep 503
01-10-2014, 11:37 AM | #12 | |
Rep 503
By pressing and holding the DSC/DTC button, you can completely shut off the whole DSC system, which includes DTC, and the car will not attempt to control wheel spin at all. |
01-10-2014, 12:51 PM | #13 |
Rep 876
Try it, it's easy to test. We have had a bunch of snow here so it is really easy to test out. When I press the DSC Off button I can hit the gas and spin the rear tires as long as I stay 'relatively' straight. I can bounce off redline indefinitely if I wanted to. As soon as the rear end steps out a few degrees DTC kicks in and kills the wheel spin.
If I hold the DSC button for 5 seconds then I can spin tires as long as I want AND I can as sideways as I want with absolutely no intervention. |
01-10-2014, 04:52 PM | #14 |
Rep 1,267
How does Sport+ fit in this picture? When enabling Sport+ mode, DSC is OFF, and DTC is ON, correct?
And I think if you press and hold the DSC off button you will be stuck in Comfort mode. |
01-10-2014, 04:53 PM | #15 | |
Rep 502
01-10-2014, 05:01 PM | #17 |
Rep 502
If DTC is a sub function of DSC, how could DSC be turned off with DTC still active? That seems kind of backwards. As I understand it, pressing the button once turns DSC off (as per an above post, I am not at home to check myself right now). Yet, in this mode, DTC will kick in when the car slides too much. I think this is what is making this so confusing for me.
01-10-2014, 06:36 PM | #18 | |
Rep 56
01-10-2014, 07:22 PM | #19 | |
Rep 794
01-10-2014, 10:29 PM | #20 | |
Rep 57
01-11-2014, 11:41 PM | #21 | |
Rep 502
As I understand it at this point: Mode 1: Normal/no buttons pressed - Squiggly icon traction system active, DSC active, DTC inactive Mode 2: Squiggly icon button pressed - Squiggly icon traction system deactivated, DTC activated, DSC still active Mode 3: Press and hold squiggly icon button - All systems off (squiggly icon system/DTC/DSC) haha Sorry to carry on with this. |
01-11-2014, 11:45 PM | #22 | |
Rep 502
Sport+ appears to be the same as being in sport and hitting the traction off button once. |
