02-21-2014, 01:45 PM | #1 |
Rep 166
DHP Working?
I have a MY14 335ix with DHP. From day one I find myself constantly switching between Sport (I have it set for chassis only) and comfort. I find myself asking Can I tell? I think sport is slightly stiffer/rougher but I'm not sure? Other times I think "Ok I can tell...I think". Now I have it lowered on H&R Xdrive Sport springs and it's pretty close to stock feel wise yet I still can't say that I can tell a real difference between Sport and Comfort.
It's been a brutal cold winter and I've never driven the car above freezing, does that matter? Currently I'm on stock 18's but come spring I'll be on 20's come spring, will it be more noticeable then? |
02-21-2014, 09:09 PM | #2 | |
Rep 3,344
Drives: 2022 M3, 2022 X5 40i;
I agree with you so far. I have about 500 miles now, and I set sport to chassis only, and I think I can tell a slight difference in the steering stiffness but not the suspension. Since I have only 500 miles haven't pushed it yet though. I actually expected a noticeable difference between the settings. I'm interested in what others think. On 397 18s with Nokians for winter. |
02-21-2014, 09:57 PM | #3 |
Rep 166
I just got mine broke in 1200 miles and I got on it today after putting in the jb4 last night. I think I noticed the dampers the faster I went 65+Mph but still it's subtle. I don't think I feel the steering change at all.
02-22-2014, 12:32 PM | #4 | |
Rep 3,434
Have you checked your tire pressure? Maybe its a little low and thereby masking the sport mode stiffness. |
02-22-2014, 12:39 PM | #5 | |
Rep 3,434
Now, when I switch from comfort to sport mode, the steering feels noticeably stiffer. I'm sure it was the same as before, but when you don't add the dramatic difference of throttle response to the mix. |
02-22-2014, 04:52 PM | #6 |
Rep 1,911
I agree when you set Sport mode to "Chassis Only" it's more difficult to tell the difference except on an uneven road (or maybe during competitive driving).. Now after installing H&R Sport Springs it's even harder to tell the difference for me, but I haven't had enough cockpit time to experiment further.
2022 G80 M3 Comp M xDrive |
02-23-2014, 08:45 AM | #7 |
Rep 3,344
I hardly tell a difference in the steering. It may just be me getting use to electronic vs hydraulic
02-24-2014, 04:52 PM | #8 |
Rep 1,201
I'm usually like you guys and can't tell these things, but on the F30, it's very noticeable. For the steering. Try sitting at a light and turn the steering wheel left and right in comfort, then switch to sport and do it again, it becomes almost twice as heavy. And for the chassis only suspension stiffness, you'll notice it the most when you're going over bumps. I have a slightly bumpy freeway right near my house, and when I drive over in comfort, I feel the car rocking up and down like a boat. In sport, it tidies down the undulations much better. Still not as stiff as I'd like, but it makes a big difference.
02-25-2014, 03:29 AM | #9 |
Infidel
123
Rep 1,102
Guys, remember that you have the xDrive with the standard non-sport springs. Changing to H&R springs doesnt equate to OEM Sport springs, instead you get an even lower ride with less difference between the modes. If you try out a OEM RWD DHP-equipped car you would feel the difference, itīs very noticeable unless you are Stephen Hawking...
But you should feel a difference in the steering, that one is perceptible. Maybe not as much if you have softer winter tires on now, the difference is felt less then...
Dec. 2022: Fully loaded Carbon Black G08 iX3 LCI M Sport Pro
Former: Glacier Ag. F31 328iA RWD M Sport oct. 2012, sold July 2022 | Sport Automatic | Adap. M Susp. | Pano. Moonroof | 20" ATS Racelight Grey w. Michelin PSS| M Sport brakes | Harman Kardon | Elec. Seats | PDC F&R | ACC Stop&Go | 335i MPE | Perf. Parts | |
02-26-2014, 12:26 AM | #10 |
Rep 95
When I first drove my car with DHP, I could very distinctly feel the difference between comfort and sport. Now that I have driven the car for about 1K miles, I think the difference is still felt, but more subtle now that I got use to it. I definitely set to chassis only mode because I wanted the firmer steering and suspension, but did not want the faster shifting/throttle for everyday use. I can get that by shifting the AT to Sport mode anytime I want anyway.
03-27-2014, 09:45 PM | #11 |
Rep 3,344
Just as an update to an almost dead thread. The reason why I couldn't tell any difference is because within 7 miles of driving my car I put on my winter setup which are very soft Nokian tires. Putting the stock run flats on show a very clear difference in the suspension feeling, as well as the steering.
04-14-2014, 03:53 AM | #13 |
Rep 1,747
Quite surprised at the replies.
The difference felt in steering weight and suspension firmness between comfort and sport is marked. Huge difference. What I'm not sure about is whether the steering gets even heavier from sport to sport plus. Sometimes I think it does but not entirely sure. |
04-19-2014, 02:35 AM | #14 |
Rep 8
I do feel the difference between sport and comfort. The car in comfort is so bouncy that i switch to sport just after starting the engine
i have another question: is there any difference in shocks and steering between sport and sport+? As far is i understood there should not be any, but yesterday i tried both modes (i have actually never used sport+ before as i saw no point in it) and it seemed the shocks worked slightly different in sport+. A little stiffer and producing less noise on bumps. Also it seemed the steering wheel got a bit stiffer. But the difference was so light that it can be explained by "placebo" effect what do you think? Could you also try both modes and tell your opinion if there is any difference in handling? |
