BMW Garage | BMW Meets | Register | Today's Posts | Search |
BMW 3-Series (E90 E92) Forum
Speaker upgrades
11-11-2007, 08:28 PM | #1 |
Rep 34
Speaker upgrades
I am new to this site and had a few question if someone can help me out. I want to improve the sound in my car with the least amount of work and money possible. I have a 2006 325i (e90) with the standard professional audio system. First, I'd like to upgrade the speakers in the doors and rear panels. I wanted to get these speakers:
http://www.infinitysystems.com/car/p...=US&Region=USA I know that the higher the sensitivity of a speaker, the more efficient, and the less power they need to sound good. These are the most efficient speakers i can find. I guess my questions are: (1) will I will be able to play music at louder volumes without distortion; (2) will there be a worth while improvement in sound quality; and (3) do they fit? Thanks everyone...really appreciate the help. |
11-11-2007, 10:46 PM | #2 |
Rep 1,691
Drives: 911 992 C2S
the most difficult problem is finding speakers that fit in the factory mounts as bmw uses non-standard speaker sizes. I have found 2 companies here in Japan, but have yet to approach them. one i approach them, i'll post the story.
11-12-2007, 08:15 AM | #3 |
Rep 34
In this post:
http://www.e90post.com/forums/showthread.php?t=86780 the guy says that the mounting depth is 50mm which is like 1.9". The infinities seem to have a 1.8" mounting depth. Is it the diameter that is a problem? |
11-12-2007, 08:30 AM | #4 |
Rep 649
Bavarian Audio's speaker replacement set is supposed to be coming out soon. It is made to directly swap with the factory speakers.
http://www.bavariansoundwerks.com/index.php |
11-12-2007, 09:02 AM | #5 | |
Moderator
324
Rep 5,493
Other speakes that fit - Focal 100KP Components (tweeters go in the mirror housing) --- DLS 8" 3-way Ultimate components (8" slim-line woofer under the seats - yes they fit..., 3" mid-range - need to make an adaptor ring from MDF, easy job... 1" tweeter in the mirror housing) But the Infinity's are the cheapest acceptable-sounding speaker that fit in the doors.
... ... DMS Remap Review ----- Quaife LSD Review ----- Hartge Antiroll Bars Review ----- Bilstein PSS10 B16 Ride Control Review ----- Detail by ShineOn ----- Paintshield Review |
11-12-2007, 09:06 AM | #6 | |
Moderator
324
Rep 5,493
If you want to upgrade the bass units and don't want to mess about with modifying slightly the standard enclosure, then order replacement Logic 7 bass units from BMW directly - will cost around $700 but will drop straight in. Feed them off a good external amp and you should get very good bass, as the Logic 7 drivers are actually pretty good, but let down seriously by a bad amp.
11-12-2007, 09:14 AM | #7 | |
Rep 13,012
11-12-2007, 09:20 AM | #8 |
Rep 34
I just got off the phone with a guy at crutchfield.com and he told me the infinity 4" kappas won't fit because the tweeter is too high. Has anyone actually installed these in their car?
Yes, i know about the bavariansoundwerks set coming out soon, but they want over $600 for their set. If i bought the inifinty speakers, two sets would be well under $300. Trying to keep it very low budget. |
11-12-2007, 09:31 AM | #9 | |
Moderator
324
Rep 5,493
However I'm not using them because I don't like the way they respond higher up the fequency range where I'm crossing over into the Focal 4" mids... using the DLS 8" woofer/midbass unit instead..
11-12-2007, 09:33 AM | #10 | |
Rep 13,012
http://www.woofersetc.com/index.cfm?...roduct_ID=2911 Low budget, component, they fit, very efficient... |
11-12-2007, 09:36 AM | #11 | |
Moderator
324
Rep 5,493
Another 4" Co-axial to try is the MB Quart Discus DKG110, which definitely DO fit... Incidentally, if you were to consider component speakers: Focal 100KP MB Quart PVF210 MB Quart RUA210 (ultra-shallow mount) should be some others, but haven't got the list in front of me
11-12-2007, 06:02 PM | #12 |
Rep 863
I upgraded the exact Infinity speakers for my rears. However,the high is not high enough for me, so I replaced it with a Polk 4" and it sounds better, plus, I also added a 1" Polk tweeter at the OEM spot. had them in || to get 2ohms. I didn't want to take the door out to replace the fronts. I am using stock amp and it does sound much better now for sure because we have 2 identical 325s in our house and you can really tell the difference. totally, it costs me around 150 bucks at circuitcity. Very cheap upgrade. they sometimes have buy 1 , get 1 half off sale.
For installation of the Infinity, you have to break one of the legs to make it fit. for the Polk BD, you have to bend one of the legs. At the end, they will fit fine into the OEM slot, at least for the rears |
04-11-2008, 10:24 AM | #13 | |
Several N54 cars, V1,3, V2.0.2, and V3.1
Rep 778
04-22-2008, 09:15 PM | #14 |
Rep 221
I have the infinity's in my car and they fit just fine. I have them in the front door and rear deck and it's just fine, not fit issues. I also bought them from crutchfield. If you want a good cheap mod, run them off the factory amp and then put a seperate amp in and run that amp to the subs. If you go all out, you could get a 4 channel amp and then a mono or two channel for the subs. One warning: I would not replace the factory tweeters with the infinity kappa 1". They are piercingly loud when you use the passive XO supplied and well then require a EQ to iron them out...
