BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > A permanent Fix for the 335i/435i 2500 RPM Rattle/Buzzing/Whirring Noise?
      02-22-2014, 09:11 PM   #1
Tjcf14
Drives: 2014 335i MSport
BMW has released a Technical Service Bulletin – SIB 64 01 14 for Heating and Air-conditioning for the 335i / 435i with N55 engine.
Bulletin states that there is an intermittent whirring noise from the IHKA system when the engine is under load between 2,000 and 3,000 rpm, and sometimes higher RPMs.
Cause has been identified by BMWNA as vibrations coming from the A/C low-pressure hose, which are resonating into the heating and air conditioning system. (In my 335, this resonance could be heard in the cabin, and felt in the steering column.) The resonance will rattle/buzz whatever is loose in the dash.
BMW has developed a new mass weight kit to dampen vibrations in the A/C low pressure hose, being transmitted from the engine.
After experiencing this problem from the second week of owning my new F30, I had this kit installed today. Problem first manifested itself at about 200 miles, today I have over 4500 miles. When I applied moderate load to the engine in gears 1 to 4, there would be an unmistakable engine vibration right around 2500 RPM. My experience matches many of the videos posted by other Bimmerpost members.
My dealer was earnest in attempting to isolate the problem. First repair attempt, they initially found an engine cover loose. Second repair attempt they insulated the plastic engine cowling, nav screen, AC hoses, etc. Felt tape / wrapping was applied in multiple locations. 3rd attempt, after driving the car without the dash, and still hearing the noise, they isolated the problem to the AC hose. I can’t say enough about the terrific service efforts at the dealership. They worked tirelessly, including researching the problem from the various Bimmerpost threads I sent them. After communicating with their regional BMW reps, they were told a service bulletin was coming.
Bulletin was released this week, part ordered Monday, delivered Thursday, and installed today. Am very hopeful this will do the trick and I’ll finally be rattle/vibration/whirring noise free. Highlighted circle in the picture below shows the new kit installed on the A/C hose.
Drove the car about 15 miles today. The vibration/buzzing/whirring sound are definitely better – but need more drive time to fully determine if this new mass weight kit has cured all ills.
      02-22-2014, 10:34 PM   #2
BavarianFanatic
Too much is never enough
Drives: Too Many
Thanks for posting!
      02-23-2014, 06:40 AM   #3
Steven1077
England
235
Drives: M140i
The fix is under the hood? That looks like an easy fix, my 435i will be built soon so I'm hoping they added this fix from the factory.
Thanks for the info, I'm sure that will save a lot of searching for others who have this problem getting it fixed.
      02-23-2014, 08:10 AM   #4
TheHitchhiker
TheHitchhiker's Avatar
Drives: 2019 BMW X5 50i
That is great news. I have the issue but wasn't able to replicate it at the dealer. However now I know how to replicate it and will take it there soon. So they can apply the fix! Keep us posted if it comes back!
Current: 2019 G05 x5 50i M-Sport
Past: 2016 F10 550i M-Sport ~ 2015 F83 M4 Convertible ~ 2013 F30 335i M-Sport ~ 2006 E85 Z4 30i
      02-23-2014, 08:21 AM   #5
howiegu
Member
howiegu's Avatar
Drives: 16' 340xi Msport
Many thanks for sharing.
I had it for year an a half, kind got used to it, now I know what to ask at the dealership.
      02-23-2014, 08:31 AM   #6
The Nerd
The Nerd's Avatar
110
Drives: 2013 BMW 335i Dinan S2 (MPPK)
So this isn't the same thing as the "electrical" sounding buzz that can be heard when accelerating slowly with the radio off (has to be very quiet to hear it)? Almost sounds like electrical interference or something. Not the same?
      02-23-2014, 09:33 AM   #7
BavarianFanatic
Drives: Too Many
I think it's the same thing.
      02-23-2014, 11:48 AM   #8
gomichaelkgo
Drives: 2014 335i
Wow, I got rid of an F30 335 because of this. Now, my new one does it too, but not as bad. If like to wait a bit to see if this works for you all before I take mine into the dealer.
I'm going to zip tie some heavy things to my hose to see if it helps...
Last edited by gomichaelkgo; 02-23-2014 at 12:03 PM.. Reason: Zip ties are awesome
      02-23-2014, 01:48 PM   #9
joonix214
Indentured Servant
Drives: 2016 F80 M3 Azurite Black 6SPD
Wow, this is great news. Keep us updated in whether the rattle creeps up again. I was having this issue as well. Hopefully, this completely fixes the issue.
      02-23-2014, 02:17 PM   #10
Coolhydro
Drives: Ducati , f30 335i sport
Great find! Is there a ID or Number for this Service Bulletin?
2012 335i | White | Sport | Premium | DHP | HK | Lane Departure | Nav
      02-23-2014, 07:40 PM   #11
dmk11
Drives: '14 335i 6MT
What's interesting is that this hose already has weight attached 5-10 inches upstream. It's hard to believe that rubber hose would cause this noise. What's the connection between low pressure ac hose and engine under load at 2500 rpm.
      02-23-2014, 09:43 PM   #12
claykin
Drives: various BMW
What is the plastic shroud I have circled in yellow? My 2014 335i does not have this shroud. I can see wires. connectors etc. where you have a shroud.
My neighbors 2013 is same as mine. Maybe BMW added after July 2013 builds?
2016 535i MSport | 2017 540i | 2019 X3 | 2019 540i MSport
      02-23-2014, 11:55 PM   #13
Glassy
E36, E46, E90, E92, F32
Glassy's Avatar
Drives: G20 M340i
Thank you for the info! Please keep us updated!!
      02-24-2014, 02:41 AM   #14
m7ammed
m7ammed's Avatar
Saudi Arabia
119
Drives: 2019 M2 Competition
Please keep us posted if you can get a PDF version of the SIB it would be great so I can give it to my dealer in Saudi to fix the issue
      02-24-2014, 05:24 AM   #15
Tjcf14
Dealership would not provide a hard copy for me to keep. My initial post has the bulletin number. Your dealer should be able to look up.
      02-24-2014, 05:31 AM   #16
BMW30_BLACK
Drives: BMW 32o
Does this refer only to 335 ? how about 320i ?
      02-24-2014, 07:31 AM   #17
jtuds
Drives: 335rwd Dinan S2
So this is not the howling/whirring noise that some of us hear when we have our heat/AC fan on?
      02-24-2014, 07:55 AM   #18
Tjcf14
My understanding is that this is only for N55 engine.
      02-24-2014, 07:59 AM   #19
fecurtis
Drives: 2014 BMW 335i M-Sport
This is certainly good to know. Thanks for informing the rest of us.
      02-24-2014, 08:26 AM   #20
Tjcf14
If whirring noise from AC occurs when idling I'd say no. The sound many of us have is a buzzing with moderate engine load.
      02-24-2014, 08:27 AM   #21
ft1330
Drives: 2014 335i
Holy crap thanks for posting. Through my testing I knew it was AC related as I've posted many times before. I thought it was a vent but apparently it was a hose. Still doubtful it is that but I can't wait to go to the dealership.
      02-24-2014, 09:39 AM   #22
ft1330
Drives: 2014 335i
I was wondering too. August 2013 build and no cover for me. Is it what the hose is supposedly vibrating against?
