05-02-2014, 10:13 PM | #1 |
Too Many Hobbies!
33
Rep 129
JB4 Stage 2 N55 F30 335i Rough Idle?
So recently I upgraded my BMS JB4 from Stage 1 to Stage 2 and the harness I had with the Stage 1 had the new rewiring ready for Stage 2 so I did not have to mess with the plugs.
Upon completion and uploading the new HEX file to the JB4 software and uploading the JB4 Stage 2 to run on MAP 2 since I run nothing but 93 octane and current engine mods are only the MPE and an upgraded aFe Pro5R oiled drop in filter. For some reason on cold starts the motor seems to rumble almost like it is starving for gas or oxygen. Then after a 3-5 min warm up it goes away. This happens every morning before I go to work. Why is this happening? Anyone else running MAP 2 experiencing this issue? When I had the JB4 Stage 1 it never had any rough idle upon start up. Last edited by alexchen86; 05-02-2014 at 10:24 PM.. |
05-03-2014, 12:29 PM | #2 |
Rep 1,997
Has the intake changed since stage 1? I don't know of anyone experiencing that issue with just changing to stage 2 but quite a few have intake related idle issues. Including myself.
05-04-2014, 06:01 AM | #4 | |
Rep 646
05-04-2014, 09:48 AM | #5 |
Too Many Hobbies!
33
Rep 129
No the intake has not been changed. I just put in a simple aFe Pro5 oiled drop in filter.
Will upgrading to a short ram or cold air get rid of this idling? I started it u this morning no issues. I start it up 10 minutes later rough idle again.... Jon at BMS has not heard of this issue before. |
05-26-2015, 12:24 AM | #7 |
Rep 34
I have a BMS intake with N55 Stage 2 JB4 and I get a rough idle as well. Not really sure if the JB4 takes a while to learn car conditions or what? I run map 1 so does not require a down pipe. I had the same products on my e90 without any issues.
05-27-2015, 01:13 AM | #8 |
Too Many Hobbies!
33
Rep 129
If you want to risk it go ahead. Me? I'm already in line for European delivery for my M4. If you actually listen to the science and rudimentary software some of these piggybacks utilize it is a joke! Some do not even have an external ground to the chassis! Others are just wrapped in an open plastic "heat resistant plastic" box?
Haha no thank you. Go to the BMW CHANNEL and listen to their engineers. If you want power but can't afford an M car don't ruin a gorgeous BMW. |
05-27-2015, 04:00 AM | #9 | |
Rep 1,252
335i is base is like 43k$ and M3 63$ pricing 335i with standard options makes it almost 50k$ which is close to M3 in all other countries 335i base price is 50k$ and M3 base price 90k $
Docrace 6266
05-27-2015, 05:32 AM | #10 | |
Pace Car Driver
1574
Rep 3,174
I have Dish Network, what channel number is this? Last edited by G30 B58; 05-27-2015 at 05:42 AM.. |
