08-13-2019, 12:14 PM | #1 |
Rep 1,170
Full e85
Is it possible to run full e85 on a f30 335i
Pwg I do a mixture now with 4 gallons and it helps out so much with my timing when ever I don't use e85 my timing is all over the place according to my logs and bm3 support my question is is it possible to run full e85 and if it is what's the steps or what exactly do I need or is way too much of a hassle Would I need to replace injectors and lpfp and just do too much to the car to accept e85 Also I'm not going to lie is so much cheaper lol I live here in la county so man gas prices are always higher here
bmw m2
08-13-2019, 12:19 PM | #2 |
Rep 1,375
You do realize, your gas mileage will take a SERIOUS hit right? So, you'll save money filling up each time but will be filling up more often so it kind of cancels each other out.
You'll need a tune at a minimum (MHD or BM3).MHD offers a full E85 OTS tune already with no upgrades required. I don't believe BM3 has an OTS E85 map available yet. -Nick |
08-13-2019, 12:21 PM | #3 | |
Rep 1,170
Why do people say I need to upgrade lpfp and spark plugs etc. Right now at the moment I am getting 16.8 mpg On 4 gallons of e85 and the rest 91
bmw m2
Phyrexia504.50 |
08-13-2019, 12:31 PM | #4 | ||
Rep 1,375
Phyrexia504.50 |
08-13-2019, 02:52 PM | #5 |
Rep 1,071
You will definitely blow your fuel pumps running full e85 if you don't upgrade them. I'd say you're already testing your luck running 4 gallons. I've spoken to MHD about this too, and they recommend just ~1 gallon on stock FPs. Not sure why others are getting a different answer.
08-13-2019, 02:57 PM | #6 |
Resident Pedant
505
Rep 792
This thread is confusing. I just put 300 miles on a tank of E30 (4.25 gallons E85 + Shell 93) running the v1.08 Stage 2+ E20 tune. Was that a no-no? The car ran great and my logs look good. I flashed back to the 93 octane tune this afternoon.
I thought the E85 tune was not for stock fuel systems. MHD app and website are unclear. |
08-13-2019, 03:35 PM | #7 | |
Rep 1,105
You can run the Full 85 tune with stock fueling OR the E20-E30 maps (depending if you are EWG or PWG) with stock fueling. If your map is set for E20 and you run E40, then your Fueling system will eventually not keep up. There is a reason why the OTS maps are set to a certain E20-E30 limit and you shouldn't go past that!
harkes1091.50 |
08-13-2019, 03:36 PM | #8 | |
Gettin It Figured Out
1823
Rep 2,669
bm3 offers 100octane and e30 maps .
08-13-2019, 03:37 PM | #9 | |
1823
Rep 2,669
This ^^^ The HPFP is the weak link in your fuel system .
08-13-2019, 04:10 PM | #10 |
Rep 221
I'm running 8 gal E85 with 93, so about E50. At first it was by accident (I wasn't paying attention). I ran some logs and everything looked great so I've kept it in that range. The main issue as has been stated here is that HPFP can't flow enough for full E85 and crash's sending the car into limp mode.
My thread and logs here: https://f30.bimmerpost.com/forums/sh....php?t=1641595 My car is a PWG so the turbo does't flow as much as the later EWG which would put a bigger strain on the pump.
2011 F25 X3 35i |M-Sport Front Bumper Conversion|Largus Full Adjustable Coilovers|FTP Charge Pipes|Gutted Catalytic Downpipe|RB Oil Cooler Thermostat Delete|25 Row Oil Cooler|Custom Built Cold Air Intake|9"AEM Cone Filter Behind Kidney Grills With Outerwear|Precision Raceworks Coils|BM3 Stage 2 E30 Tune| BM3 Upgraded 8-speed TCU Flash|395mm X5M Front Brakes
08-13-2019, 04:58 PM | #11 | |
Resident Pedant
505
Rep 792
The License Store says "E85 mix map" and the description says "E30 Map". So I filled up my car with an E30 mix, bought the maps, go to flash, and saw that I only have E20 maps and E85 maps available. Meanwhile the MHD Website advertises only an E25 map pack for F-series N55.
Haven't seen any indication that the E85 map was for stock fuel systems until today, in this thread. No documentation on MHD's part at all. :shrug: Quote:
08-13-2019, 06:53 PM | #12 | |
Rep 188
Your gas mileage will be horrible though, i get around 14-16 mpg and have to fill up about every 2 days but then again i drive about 70-80 miles per day so your results might be different. |
H4CK1NT05H24.50 |
08-13-2019, 06:59 PM | #13 | ||
Rep 1,375
08-14-2019, 07:55 AM | #14 |
Rep 1,499
Are there really people out there running the MHD full E85 tune with no supporting fueling upgrades, i.e. upgraded LPFP with PI or upgraded HPFP?
08-14-2019, 08:12 AM | #15 |
Rep 1,375
08-14-2019, 08:46 AM | #16 | |
Modder of everything I own
147
Rep 491
I've been running e50 for the last year+ with both stock LPFP/stock HPFP with no issues and with Stage 2 LPFP (walbro 450)/stock HPFP with no issues, all logs have looked good.
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
08-14-2019, 08:52 AM | #17 | |
Rep 153
I was a beta tester for this map. Stg1 should be ok without any problem but for stg2 it's not the same. They released a map too hard for the HPFP, I have some pressure drops after 5000rpm, corrected by lowering the boost. I'm running like 12,5-13psi at this time, curves are ok, no drops. Running full e85 since 3 months, my HPFP is still alive lol. |
Phyrexia504.50 |
08-14-2019, 09:09 AM | #18 | |
147
Rep 491
08-14-2019, 09:32 AM | #19 |
Rep 153
08-14-2019, 11:15 AM | #20 |
Rep 221
What gains are you guys running full E85 with the lower boost pressures seeing?
Does the increased timing really offset the reduced boost pressure in terms of overall power?
08-14-2019, 11:58 AM | #21 | ||
Rep 1,105
If you are EWG, then the only maps available to you are the E20 and full E85. Im not sure what is available for the PWG turbo cars since i run a EWG turbo. Also, I have not purchased the E85 mix maps so im not sure about the description your talking about but from everything i've read on the forums, you can run full E85 on stock fueling, at the sacrifice of lower boost.
08-14-2019, 02:52 PM | #22 | |
Rep 1,499
So is the Full E85 map faster than the Stage2+ E30 or 93 octane maps? I'd love to see a log if you have one.
Phyrexia504.50 |
