BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Photo, Video, Media Gallery, Journals > ronanz's F32 EBII Build Thread : Update 10/27/18
      09-08-2015, 09:34 PM   #1
ronanz
Gettin It Figured Out
ronanz's Avatar
Drives: 435i FBO PS2 bm3 w/ options
ronanz's F32 EBII Build Thread : Update 10/17/19
Figured the time has come to post my build thread before she gets put away for winter.
Although I understand having the “M” fender badge located ANYWHERE on a U.S specced car is HIGHLY controversial (even though they're standard on M-Sport Models everywhere else in the World), I believe the smaller badge should be relegated to the M-Sport (and should stand alone...should not preceed nor follow numerical model badging) while the LARGER “M” should only be reserved for the TRUE “M” cars (kind of a big brother/sister – little brother/sister view).
Yes, I realize the left exhaust tip is off center... It has since been corrected!! JEEZ!
**DISCLAIMER : Customizing, modding and or tuning cars make absolute ZERO financial sense (unless they're super exotics), you have to do it 'cause you enjoy it and it makes you happy. If you're going to jump in, do it with both feet or don't bother.
*** RETIRED - NO LONGER ENZO TUNED **** Decided to pull trigger on ENZO Performance Tune (She'll be the Test/Development Mule for their N55 PT S2 Tune). Car scheduled for shipping the week of 11/16 then returned the end of January - 1st week of February. BIG thanks to Mike@N54Tuning.com for making it happen with parts!!
Little background, car is a 2014 435i EWG with MPPK and DinanTronics S2 (ENZO Baseline Numbers PRIOR to FBO S2 Tune can be found HERE). I’m not looking to break any records, just want something that’ll perform well with 93-95 octane (utilizing 4gal e85 to 10-11gal 91 octane)
BIG thanks to Chris at Chris@EnzoPerform for making the Tune happen! VERY much appreciated!!
**UPDATED 12/30 Exhaust Note w/ S2 PureTurbo & FBO's
Ohhhh....this makes me happy!! .
***UPDATE 02/12/16 : ENZO Tune Complete!!
Final Numbers: 465whp/405tq on 93oct Pump gas!!
ACF Performance Cold Start
3/7/20 NoFlyZoneArizona 1/2 Mile Event
PERFORMANCE:
- JordanTuned Custom ACN91oct & e40 Maps - Bootmod3 w/ Agent Device & Map Bundle
- PureTurbo S2 with install kit (parts courtesy of Mike@N54Tuning)
- Dorch Engineering S2 HPFP Kit (Found HERE) Kit includes Low/High Pressure Fuel Lines with HPFP wiring harness
- Fuel-It Walbro 450 S2 LPFP (Found HERE )
- Fuel-It Flex-Fuel Sensor w/ Bluetooth Analyzer & upgraded HPFP Fuel Line (Found HERE )
- Jb4 w/ BT (used solely as Boost Controller) (RETIRED - No longer used)
- PureTurbo inlet pipe (parts courtesy of Mike@N54Tuning)
- Custom ENZO Catless Downpipe
- ER FMIC - Anodized Flat Black (parts courtesy of Mike@N54Tuning) Info found HERE
- ER TIC Anodized Flat Black - Turbo to Intercooler pipe (parts courtesy of Mike@N54Tuning) Info found HERE
- GFB DV+ Diverter Valve : Info found HERE (Part#: T9356)
- Plugs: NGK SILZKBR8D8S (97506) Gapped @ .022
- ER Charge Pipe Anodized Flat Black (via Mike@N54Tuning.com ) Info found HERE
- Dinan Cold Air Intake ( Found HERE )
- BMS Sport Oil Cooler Valve ( Found HERE )
- BMS Blue Billet Aluminum Oil Thermostat Lid & Caps ( Found HERE )
- M Performance Limited Slip Differential (33-10-7-555-607)
- Dinan Springs ( Found HERE )
- Dinan Bump Stops ( Found HERE )
- Dinan ShockWare ( Found HERE )
- F80/F82 Connecting Support/Chassis Brace (Part # 33312284647
- (6 ea) Chassis Brace replacement Torq Screws (Part # 07119907189)
- Wheels: 19" Forgestar CF5V 9.0 +35 / 10 +42 - Powdercoated Gloss Gunmetal - (via GetYourWheels )
- Tires: Michelin PS 4S 245/35 x 275/30
- M Performance Power Pack (MPPK)
- DinanTronics S2 EWG (For MPPK Equipped ONLY) - (RETIRED - SOLD)
COSMETIC/ACCESSORIES EXTERIOR:
- CQuartz Finest - Nanotech Ceramic Paint Coating
- SunTek PPF C Protectant Film
- Vorsteiner CF Front Lip ( locally 3 stage painted EBII Candy / Line-X'd Bottom to protect against scratching )
- OEM M4 Grill ( via Jason@Tischer / getBMWparts.com )
Front Left Part # 51138054331
Front Right Part # 51138054332
- Custom Engine Cover: CF Hydro-Dipped, EBII Border with Custom Pin Striping ( via zman1237 )
- CF Kidneys ( locally 3 stage painted EBII Candy ) ( via Eric @ RW Carbon )
- Painted Front Reflectors ( via IND Distribution )
- CF Fender Grills/Gills ( via Eric @ RW_Carbon )
- CF Mirror Covers ( locally 3 stage painted EBII Candy ) ( via Eric @ RW_Carbon ) Retired
- CF F80/F82 inspired Mirror Covers ( locally 3 stage painted EBII Candy )
- NEW CF F80/F82 inspired Mirror Covers (out to get painted . ) Can be found HERE
- Painted Key Hole Cover ( via iND )
- OEM M4 Trunk Lid ( 99% PnP ) ( via Jason@Tischer / getBMWparts.com )
- OEM M4 CF Spoiler ( locally 3 stage painted EBII Candy) ( via Jason@Tischer / getBMWparts.com )
- OEM Locally Painted Rear Diffuser (via Jason@Tischer / getBMWparts.com )
- M Performance Exhaust (MPE) ( via Jason@Tischer / getBMWparts.com )
- M CF Exhaust Tips ( via Jason@Tischer / getBMWparts.com )
COSMETIC/ACCESSORIES INTERIOR:
- Escort Passport 9500ix (Hardwired Smart Cable)
- OEM M4 CF Dash Trim Panels
- OEM Illuminated LCI AC/radio trim retrofit - BIG thanks to tboooe for the harness hookup!! .
- Custom CF M-Sport Steering Wheel
- F80/F82 Paddles
- CF Steering Wheel Trim ( via Eric @ RW_Carbon )
- OEM CF M4 Door Handle Trim (via Ryan @ iND )
- 4x4 Shop.ca's 10.25″ Screen PX6 Android 8.1 Version 6 Core with 2GB RAM /32GB HD NBT System - Found HERE
- BimmerTech SmartView Smart Phone Mirroring Retrofit ( via Nelson@BimmerTech & Patrys@BimmerTech ) REMOVED/RETIRED
- Custom CF iDrive Controller Center Console
- OEM M Performance CF Auto Transmission Selector Lever ( via Jason@Tischer / getBMWparts.com )
- OEM iDrive Touch Controller - 100% PnP ( other than Nav & Touch capabilities, all 100% functional - Part# 65829350723 )
- OEM M Performance Carbon Fiber E-brake Grip with Alcantara Boot (Part # 34402222540)
- BimmerTech Audiotec Fischer PP82DSP AMP Retrofit ( via Nelson@BimmerTech & Patrys@BimmerTech )
- BSW “S1” Speaker Upgrade ( via BavSound.com )
- BSW Under Seat Ghost Subs ( via BavSound.com )
- OEM M Performance Stainless Steel Pedal Covers & Footrest (Part# 35002232278)
- Various “Coding” (via CodeMyCar.com)
- AWRON Gauge ( via EAS ) (Removed/Retired due to Jb4 - Can't share CANBUS) ***SOLD
My Build Thread can be found HERE
Appreciate 13
      09-09-2015, 06:35 AM   #2
Bedista
Bedista's Avatar
53
Drives: 328i
well done! any before pics?
      09-09-2015, 08:00 AM   #3
LordNathanD
LordNathanD's Avatar
Drives: G21 Dravit Grey M340d Touring
absolutely stunning mate, wouldn't change a thing!
F30Allen123.00
      09-09-2015, 08:45 AM   #4
Lobo.
Drives: EBII 435i
Very nice car! That M4 trunk lid looks amazing. That is a cool picture with Camel Rock.
      09-09-2015, 02:36 PM   #5
Aaaaaaaaa
Drives: The other M3
Those mirrors...
      09-09-2015, 05:00 PM   #6
ronanz
ronanz's Avatar
Thank you! No, unfortunately I never bothered to really take any before pics
Thank You! Much appreciated!!
Thank you! Are you local? Camel Rock is truly a natural wonder!
Originally Posted by pheerix View Post
Those mirrors...
You likey? Painting the CF was the most difficult part to get right
      09-09-2015, 07:37 PM   #7
PCR0303
Drives: AW F32
Wow looks fantastic! Love the EB, wish I got it. Love all the mods, everything about it. That left exhaust tip though :x
Alpine White M Performance F32 428i - Exhaust conversion + More. Check out my build
      09-10-2015, 11:00 AM   #8
mike@x-ph.com
mike@x-ph.com's Avatar
Drives: 07-335/12-328/18-M4/21-M4CP
Looks great, good job on your mod choices
https://x-ph.com/sale/
Phone number 725-221-5267
      09-10-2015, 01:53 PM   #9
GetYourWheels
Drives: F10
Wow! Amazing build!
I love the blue cleared CF pieces, very unique touch!
As well as that M4 trunk/spoiler combo
Quality build, thanks for sharing the photos!
If you dont mind I'm going to use some of those photos in our Shipment of the Day Thread!
      09-10-2015, 07:00 PM   #10
ZuerstBMW
¡Viva España!
ZuerstBMW's Avatar
425
Drives: 24 G20 330i Skyscraper Gray
Beautiful car!!!
24 G20 330i Skyscraper Gray Metallic Black, Open Pore Fine Wood Oak Grain Interior Trim MODS Clear Guard, 15% Ceramic Tint, Floating Caps
      09-11-2015, 12:50 AM   #11
Harlequin
Harlequin's Avatar
Australia
362
Drives: F32 Coupé
All of this is awesome.
      09-11-2015, 03:31 PM   #12
ronanz
ronanz's Avatar
Thank you!
Thank you!
Originally Posted by GetYourWheels View Post
Wow! Amazing build!
Much appreciated!!
Originally Posted by ZuerstBMW View Post
Beautiful car!!!
Thank You!!
Thank You!!
      09-14-2015, 11:44 AM   #13
WP7778
WP7778's Avatar
Drives: '13 BMW 335i
Awesome car, very good mods here
For the cf mirrors, how would you rate the product in terms of fitment and looks, experienced any problems compared to oem?
I still can't justify spending twice the amount for oem ones if they look and fit the same
Last edited by WP7778; 09-14-2015 at 11:45 AM.. Reason: blocked out txt correction
      09-14-2015, 12:23 PM   #14
ronanz
ronanz's Avatar
Thank you. Can't go wrong with RW Carbon ... 9.5 out of 10 for fitment, quality and Customer Service! VERY happy, absolutely ZERO problems vs. OEM.
      09-18-2015, 10:40 AM   #15
david51
david51's Avatar
France
574
Drives: bmw M3 F80
Very good taste for equipment Magnificent
      09-18-2015, 12:16 PM   #16
.BMW.
.BMW.'s Avatar
Sweden
1877
Drives: BMW F11/F31
Looks great!
Nice wide stance.
      09-18-2015, 02:43 PM   #17
Dang3r
Deceased
Dang3r's Avatar
12491
Drives: HP4 Comp.
Excellent mods done, awesome look, but I havent cut the 4 at the kidneys
Citizen of ///M - Town, where too much is just right
Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox
      09-18-2015, 08:16 PM   #18
ronanz
ronanz's Avatar
Originally Posted by .BMW. View Post
Looks great!
Nice wide stance.
Thank you! I cut the 4 out due to my vehicle not being a M4. M-Sport yes..., M4...not so much.
      09-21-2015, 07:12 AM   #19
zman1237
zman1237's Avatar
55
Drives: F12 M6, F32 428i M-Sport
Any interior pictures? I'd like to see the M4 carbon fiber interior. Where did you get it? Thanks
F32 M-Sport
F12 M6 Competition
      09-27-2015, 11:03 AM   #20
ronanz
ronanz's Avatar
Here ya go...purchased from eBay seller potomac_german_auto
also purchased my Touch Controller from him
      09-27-2015, 11:18 AM   #21
zman1237
zman1237's Avatar
55
Looks great! I've been in contact with him but he is currently out of stock. He's on the lookout for me though. Just to double check, you only got the front dash and vent CF from him correct? He didn't have the door pulls or console portion? Thanks for your help.
      09-27-2015, 11:27 AM   #22
ronanz
ronanz's Avatar
Yes, that's correct...just the Dash Trim Panels. I will eventually vinyl wrap lower trim to match surrounding blue trim.
