BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Bootmod3 N55-EWG Version 7.0 is up !
      08-06-2020, 06:24 PM   #353
Joeirl92
Joeirl92's Avatar
Drives: 14' 435i 6MT ; 17'Z06 7MT
Originally Posted by designatedposter View Post
Originally Posted by Joeirl92 View Post
Hey guys. The community here seems great so I finally decided to pull the trigger on creating an account!
Warranty was out as of July so I decided to go crazy lol.
Currently running a Stage 2 91 OCT BM3 435i 6MT STOCK plugs
Mods: Wagner EVO2 Comp intercooler, CTS Turbo intake, Evoracewerks chargepipe, CTS Turbo catless DP, AWE midpipe and axleback
I have no experience with tuning, therefore I have a couple of questions regarding BM3. This is my first car that I'm tuning and I did these mods all in a span of a week, so I'm literally brand new. Any insight would be dope!
I live in CA with shit 91oct, but I live right by a station with 100oct. What do you guys think about mixing (ie 4gal of 100 and 11gal 91) to get that stage 2 93 tune? Any pros and/or cons in mixing octane?
I also experienced a slight stutter when flooring throttle in 4th at around 3.5k RPM. I'm going to need to provide some logs for you guys to help me there beause I know that can mean a ton of things. i'll read up on how to get those logs and get back if anyone is down to point me in the right direction to a possible problem.
Appreciate y'all and I'm stoked to be here!
you can most certainly mix fuel to bring up the average octane to a level that is adequate for the respective tune, but in my opinion, the difference between the tunes for 91 octane and 93 is not noticeable. you can conduct your own test and determine it it's worth the effort and cost.
let's see your log as-is right now to determine if your fuel is even good enough for the 91 tune, as most of the time, it's not and could potentially benefit from going to the acn91 tune.
another option is installing a water meth system and you can even daily run the race tune. again, in my opinion, its not noticeable going from 91 to race tune.
that stutter could be your high pressure fuel pump, or clutch slipping.
https://www.bootmod3.net/log?id=5f2c...729b3b4ea27f67
Here is my log! I honestly don't know what I'm looking at but if mixing fuel isn't a bad thing I'll probably go for the e30 route as I've been told it actually sees a power gain. I need to study up on how to read these things but in the mean time I posted it here. Thanks for looking through it when you get the time!
2014 6MT 435i BM3 Stage 2 E30+ - ERW Chargepipe, CTS Turbo Intake, WAGNER EVO COMP II FMIC, CTS Turbo DP, AWE Performance midpipe & Axleback, Gapped NGK plugs, SPEC Stage 2+ clutch upgrade, DORCH stage 2 HPFP.
      08-06-2020, 08:27 PM   #354
thejeremyman9
thejeremyman9's Avatar
4392
Drives: 2015 BMW 335i
Here is my Log. For some reason I didn't experience any stuttering in 3rd or 4th gear. The only change made since I last experienced it was my midpipe and axle back install. So strange.
I'm definitely interested in E85 it's just my car is probably only driven 100 miles a week max. It sits several days at a time. Would you still recommend??
Thanks for taking the time to check this out for me!
Timing is pretty awful in that log man... like only 1-2 degrees up top and negative on some cylinders throughout the pull. You are losing a ton of power from the timing pulls. How many miles on plugs and what brand/gap?
If timing is consistently that bad you need to either run the ACN map or get more octane in your fuel.
Yes, i still recommend it. I am down to driving my car once a week now as well, sometimes only like 20 miles per week. Its fine with E30.
Read this recent thread for E85: https://f30.bimmerpost.com/forums/sh....php?t=1742607
Specifically my post here: https://f30.bimmerpost.com/forums/sh...91&postcount=8
      08-06-2020, 09:12 PM   #355
Joeirl92
Joeirl92's Avatar
Specifically my post here: https://f30.bimmerpost.com/forums/sh...38;postcount=8
I'm on stock plugs. 2014 with 45k miles! I thought that was early for replacements but I guess I should swap them out for some gapped plugs. Any suggestions??
And I'll go on that ACN91 map then in the mean time. Unless you suggest I just go e30? . I'm bummed but that's why I'm here. Thanks for letting me know man. Much appreciated
      08-07-2020, 12:36 AM   #356
thejeremyman9
4392
You can run the ACN91 map if you dont want to have to mix E85... but if it were me there is no doubt i would run do E85 mix and run the E30 map. It will make significantly more power than the ACN map even if you have good timing on the ACN one (which might not even happen). I ran the 91 map on MHD for a while before going to the E20 map (there is no E30 for EWG on MHD) and I will never go back.
For spark plugs, i changed mine at 45k to a set of new OEM Bosch. Read here: https://f30.bimmerpost.com/forums/sh....php?t=1709198
      08-07-2020, 02:30 PM   #357
Joeirl92
Joeirl92's Avatar
Yeah I definitely need new plugs man. Ran the e30 map and got horrible stuttering in third and 4th and high RPMS.
Second gear pull felt amazing though. A huge difference in power for sure! I read into your post so i'll be getting on those plugs.
      08-07-2020, 03:09 PM   #358
thejeremyman9
4392
Get some logs, before and after the plug change.
Also, when you pull the plugs, i would recommend checking the gap and condition of the ones coming out. Good to know if something was out of spec there.
      12-24-2020, 02:35 PM   #359
Silverlining_m2
Silverlining_m2's Avatar
1747
Drives: 2023 M2, 2024 m235i
Hey all! And thejeremyman9 !!
Added a gallon of e85 to my shell 93oct to see if it would help with the vibration I was feeling under immediate acceleration. I honestly think it helped.
Would anyone mind checking these logs for me? I see occasional timing corrections in cylinders 3 and 5, and the iat's get into the high 40's at the end of the 4th gear pull. It's 19° here, so thats about 30° difference. I'm not great at this, but it looks decent for stock plugs and coils? Let me know what you think if you have the time. And Merry Christmas to all the ptf/bm3 family
https://www.bootmod3.net/log?id=5fe4...729b3fe468e86f
https://www.bootmod3.net/log?id=5fe4...90c67c6b36626e
2023 M2. ZB. Manual.
2024 m235i
      12-24-2020, 08:20 PM   #360
n55david
n55david's Avatar
2017 m240i xDrive  [0.00]
2015 X3 x35i  [0.00]
2015 335i xdrive  [0.00]
Our fuel here is trash right now. we are in the "winter blend" season. I'm not surprised that even with a little 85 it wasn't enough. I would try again with maybe 1.1 or 1.2 gallons.
Edit: Also I have yet to see a station test out at true e85. Meijer seems to always be e80, and same with the marathons I've tested. I've never tested anything else.
2017 m240i xDrive 10.67@132.32mph w/bm3
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
      12-24-2020, 08:32 PM   #361
Silverlining_m2
1747
I'll definitely try 1.5 gallons next tank. Just followed your insta too.
2024 m235i
      12-24-2020, 10:11 PM   #362
n55david
n55david's Avatar
2015 X3 x35i  [0.00]
yeah, I noticed! bro... that ass though. that Sony is treating you well!
      12-26-2020, 11:09 PM   #363
thejeremyman9
4392
I just took a look at this log: https://www.bootmod3.net/log?id=5fe4...90c67c6b36626e
Timing looks completely fine honestly. A few small corrections on one or two cylinders is pretty much unavoidable and this looks much better than most peoples logs on the 93 map.
The other thing that stands out is you have multiple throttle cosures back to back, down to ~40%. Not sure why. Don't typically see that in 93 map logs i dont think. Aside from that looks fine though. I wouldnt worry that much about the IAT, although you do have more IAT rise throughout the pull than i do. Which IC are you running?
      12-27-2020, 07:26 AM   #364
Silverlining_m2
1747
The same 5" vrsf you are I believe! I did a couple logs yesterday with literally zero timing corrections but wasn't looking at throttle closures. What causes them? Just added boost deviation to my future logs. Maybe I'm over boosting?
edit:
The throttle closures DO seem to be when my actual boost is over target? Am I reading that correctly?
2024 m235i
      12-27-2020, 09:28 AM   #365
Munchi435i
Munchi435i's Avatar
Drives: 2014 Alpine White 435i M-sport
edit:
Yes throttle closers mostly occur when overboosting and is perfectly normal.
      12-27-2020, 10:43 AM   #366
Silverlining_m2
1747
edit:
Awesome thanks for the clarification. I ran 2 logs yesterday that still have them, but literally zero timing corrections! Running great and feeling like a million bucks
2024 m235i
      12-27-2020, 08:11 PM   #367
thejeremyman9
4392
Yeah i didnt realize you were overboosting at those times, the throttle closure is indeed a normal response to that. The question then becomes, why the strange boost control? Other people's 93 logs dont seem to do that. Its not a huge issue or something, just a little atypical from what ive seen from other logs on here.
      10-08-2022, 10:48 PM   #368
ericlr1225
ericlr1225's Avatar
Drives: 2018 M2 LCI 6MT
For who flashed V7.1 N55 map Why my BM3 shows the latest version is v5.9. Thanks
      10-09-2022, 06:17 AM   #369
n55david
n55david's Avatar
2015 X3 x35i  [0.00]
If you have a 5.9 version it's because you have an m2
This forum is for 335/435 cars man
They are different map versions...I literally have every single bm3 ots map, 😀
      10-09-2022, 06:40 PM   #370
ericlr1225
ericlr1225's Avatar
Got it Thank you~
n55david1304.50
      10-09-2022, 07:06 PM   #371
n55david
n55david's Avatar
2015 X3 x35i  [0.00]
Got it Thank you~
No problem!
