12-22-2016, 02:30 PM | #45 |
Rep 2,379
Cuts what? Boost?
(A Dane in China) |
12-23-2016, 08:37 AM | #47 | |
Rep 1,862
Drives: powered by bootmod3
thank you! |
FSociety3816.50 |
12-30-2016, 02:47 AM | #48 |
IG @bmwF9xG80
3817
Rep 7,595
Convinced me to get Meth before/by spring after I do some Dyno's on 93 + another DP baseline
AEM Kit here we come
60-130 6.5s X4M
60-130 5.04s G80 M3 Stock Turbo 60-130 4.82s | 9.4@148mph 1/4 Hybrids IG: @bmwF9XG80 |
12-30-2016, 09:08 PM | #50 |
Rep 693
01-04-2017, 01:55 AM | #51 |
Rep 181
I recently had my car on a dynojet and the best run was 410hp/463tq. My mods are: catless dp, cp, IC, JB4 with EWG harness, and I was running 3.5 gal of e85 with the rest of my tank 91 oct. and on map5. My friend's 328 with jb4, meth, catted dp, and cp put down 276hp/349tq on 91. Do you guys think I can get closer to 440hp/550tq by running meth on map3 or 100 octane on map7? I also have an injen intake sitting in my room but i heard that it won't add any power- just sound? Thanks in advance
I had 2 runs with map5 and 2 with map7. Map7 kept cutting boost for some reason, so i switched back to 5 and that solved the problem. Sorry for the slightly grainy pic Last edited by grassy_91; 01-04-2017 at 02:04 AM.. |
01-04-2017, 09:53 AM | #52 | |
Rep 969
Are you auto or 6 speed? What gear was it done in? Also adjust your boost safety to like 21psi. That's why you probably were getting cut out on map 7.
01-04-2017, 08:51 PM | #53 |
Rep 181
Auto and 5th gear. Im sorry, but can you tell me how to adjust my boost? Im still new to turbo cars and tuning!
01-04-2017, 08:52 PM | #54 |
Rep 181
01-05-2017, 09:44 AM | #55 |
Rep 969
You're not adjusting the target boost... that's what the different maps are doing through the JB4. The boost safety is there for a safety feature... on map 7 you may be over posting a bit and as soon as it hits for example 19 psi, the fuel cuts out. You can raise it to 20-21 psi. If you have the Bluetooth module... go under settings, then user adjustment settings and scroll down it's under boost safety. Then click save.
01-05-2017, 06:10 PM | #56 | |
Rep 181
01-09-2017, 06:23 PM | #57 |
Rep 1,782
Can the PWG be fitted with EWG wires?
13' 335i M Sport. EBII/Coral Red 6MT. RPI GT exhaust, Resonator delete, PS1, GFB DV , BM3 Stage 2, ER CP, VRSF DP, VRSF 5.5in Stepped FMIC, Dinan Shockware. Carbon M Performance rear diffuser. M4 trunk lip. Conti DWS06 225/40/19 and 255/35/19
01-23-2017, 12:29 PM | #59 |
Rep 271
Great numbers OP. I just picked up a BM3. Anxious to see what numbers I can put down with my mods. I am shocked that you have no port injection. I guess that is the magic of a tune.
2021 M550i
BMS Pedal tuner JB4 |
FSociety3816.50 |
01-23-2017, 12:48 PM | #60 |
Rep 1,130
Chicken_Joe608.00 |
01-23-2017, 04:54 PM | #61 |
Rep 1,782
Ahhh
01-23-2017, 04:58 PM | #62 |
Rep 1,782
Then why do they sell EWG wires for the JB4? If your car is EWG then you buy EWG harness.
01-23-2017, 05:05 PM | #63 |
Rep 1,130
01-23-2017, 05:05 PM | #64 | |
IG @bmwF9xG80
3817
Rep 7,595
(Did you try checking on n54tech or searching here?) EWG wires add-on is for EWG cars only to manipulate the electronic waste gate PWG cars do not have this because it uses the Pneumatic WG
60-130 6.5s X4M
60-130 5.04s G80 M3 Stock Turbo 60-130 4.82s | 9.4@148mph 1/4 Hybrids IG: @bmwF9XG80 Last edited by FSociety; 01-23-2017 at 08:01 PM.. |
Jadar1754.50 |
01-23-2017, 06:17 PM | #65 |
Rep 1,782
Is there a safe space on this forum because your words hurt my feelings.
01-23-2017, 06:25 PM | #66 | |
Gettin It Figured Out
1823
Rep 2,669
I hear the i3 side is pretty chill... .
