08-03-2015, 07:11 AM | #1 |
Rep 18
Hit a nasty pothole...
Hit a nasty pothole on Saturday night coming home and my two left tires exploded. Extremely frustrating because it would never have happened if I hadn't agreed to drive someone else home.
The tires are completely finished and because it was a Sunday I tried to chance it taking the car to Canadian Tire since they were one of the only places open and also because I can finance the tires there with 0 interest over 12 months. It cost me $167.17 to tow the car there. My original plan was to put the two right tires in the front and get some new ones for the back. But the guy says that it's dangerous to mix tire types (note that my current tires are new and that they have less than 10000 km on them) because of the all wheel drive system. He says it'll be okay if he can find the same model of tire that I already have but says that it looks like it's a discontinued model. So he says most likely I'll have to buy 4 brand new tires. Then he says if I do have to buy 4 new tires, I'll have to buy run flats again because that's what BMW recommends and that's what the wheels were built to carry. He says that if I put non run flats on there, that there's a danger that the tires could slip off the rim. This all sounds ridiculous to me, at least the bit about run flats and sounds like he just wants me to buy a more expensive tires. What do you guys make of this ? |
08-03-2015, 07:55 AM | #2 |
Rep 603
What is the tread depth on your other two tires? Ultimately I wouldn't mix run-flats with non run-flats but there is no reason otherwise you couldn't just replace the two tires that are ruined. Also no reason you couldn't replace all of them with non run-flats. I had a similar situation where I hit a pothole and ruined 2 left tires. In my case the tires were very new and I replaced with 2 of the same tires. (2/32 of tread wear from new). Best of luck!
- 2022 X3M Comp
- 2021 X5 xDrive 40i - 2018 F80 M3 (sold) |
08-03-2015, 08:09 AM | #3 |
Pace Car Driver
1548
Rep 3,164
So much BS from "that guy"
The wheels were built to run run-flats.....what a crock. Go to someone who know what they're talking about. If you have run-flats, why did you have your car towed? |
08-03-2015, 08:23 AM | #4 |
Rep 254
Drives: E30 M3 & 325ic-F30 335i Xdrive
He had to get his car towed because Run Flats are useless when you have a side wall blow out.
08-03-2015, 08:27 AM | #5 | |
Pace Car Driver
1548
Rep 3,164
http://f30.bimmerpost.com/forums/sho...06&postcount=1 That depends ..... on lots of things. |
08-03-2015, 08:28 AM | #6 |
Rep 268
Mixing tires isn't recommended because different tires have different levels of grip and could be dangerous during an emergency maneuver. They could also have different noise level, stiffer or weaker side wall, different tread pattern, one set may perform better in rain, icy conditions, etc. At the end of the day, you can still do it if that's what you want to do.
The part about non-RFT's slipping of the wheels is BS. For fun, ask the guy what the difference is between RFT and non-RFT wheels. If you can swing it, buy 4 new tires (RFT or non-RFT based on your budget). Then sell your other two tires on this forum. If you have room, then keep 1 or 2 of the old tires as spare, in case you hit more pot holes in the future. All the best. |
08-03-2015, 08:30 AM | #7 |
Rep 3,947
08-03-2015, 08:49 AM | #8 |
Rep 18
Not sure of the exact thread depth but they were pretty new, under 10k km, they still looked pretty new too.
Yeah I had my car towed because while they are run flats, the noise the car was making when I was just slowly driving it out of my garage did not make it seem like a good idea to drive it all the way to Canadian Tire. The last thing I wanted was to risk damaging the wheel. Still hoping that the wheels and the ball joints have been spared... Anyways, so they just called back and as I suspected, no one can seem to find the model of tire I currently have, so I'm going to just buy 4 new summer performance tires and sell the 2 run flats. Otherwise I'll be waiting around for days trying to find them and get them shipped to the service center. I told the guy the model of tire I wanted (Michelin Pilot Super Sport) and he's like ahhh but you need run flat tires otherwise your tire will fall off the wheel. I'm like, BMW JUST told me over the phone that its perfectly fine to put non run flats. He's like ohhhhh, really you sure? Well I'll try to inquire and get back to you. Friggin' amatures. The 2 remaining tires are Continental 225 45 18 SSR Conti Pro Contact 91V if anyone's interested. |
08-03-2015, 08:55 AM | #10 |
Rep 962
I feel for ya man, our roads are such crap. I always feel like I'm on an obstacle course.
On a different note, not sure if Canadian Tire is a good place to take your BMW for anything. As you have just experienced... In the future, keep in mind that BMW roadside assistance (free) will tow your car to any garage you want, not just the BMW dealer. Why? Because if this happens on a Sunday and the dealer is closed, what are they expecting you to do? Best of luck! |
08-03-2015, 08:56 AM | #11 |
Rep 514
Canadian Tire.... doesn't surprise me Jonathan. They shove a bunch of uneducated kids to work to work there. I'd never go there to service a BMW....
2022 BMW M340 X-Drive
2020 BMW X3 30i M-Package (retired) 2018 BMW 440i X-Drive Gran Coupe l Premium Enhanced Package l M-Performance Package + M-Performance Pack 2 (retired) 2013 BMW 335i X-Drive (retired) |
08-03-2015, 09:01 AM | #12 | |
Rep 18
And actually I did call BMW assist and they said they will only tow me to a BMW dealer. That's why I had to spring for my own towing. Have they towed you to a regular garage? |
08-03-2015, 09:03 AM | #13 | |
Gettin It Figured Out
1820
Rep 2,669
You might want to run with chains, just in case... .
08-03-2015, 09:04 AM | #14 | |
Rep 18
Anyways, I sympathize with you since your car's been in and out of the shop the past month... I just want her back !! |
08-03-2015, 09:16 AM | #15 |
Rep 18
08-03-2015, 09:55 AM | #16 |
Rep 4,451
Drives: '23 X1 28i xDrive
08-03-2015, 10:18 AM | #17 | |
Rep 962
08-03-2015, 10:23 AM | #18 | |
Rep 15,858
BMW use EH2 (extended hump) rims for run-flats, as the tires can run with zero pressure. The extended hump is to prevent a deflated run-flat demounting to the middle of the rim, (moving from the bead area). It is this added security being one reason run-flat tires are more difficult to remove and mount. It is the run-flat tire that requires the upgraded rim, not the other way around, a non run-flat is more secure on the EH2 rim. Just wish the tire shops grasped the technical requirements. HighlandPete |
08-03-2015, 11:08 AM | #19 | |
Rep 693
There is some truth to the issue of replacing them with the same tire, this is obviously the best course. However, if they are no longer in production it is possible to replace them with tires that are identical in all other respects. If you match the tires for treadwear rating, load index, speed rating and obviously design (A/S, Ultra Summer, max summer, etc) and get replacements with the most similar tread design as well. While the best choice might be to replace all 4 since they are discontinued, it is not a "requirement" as long as other factors can be met. Though I agree with Saad, now's a good time to replace the RFTs with non-RFTs and then just sell your two remaining RFTs to recoup a little cost. Oh, and petition your local authorities to fix their pitiful roads.
2018 M240i X-Drive | Sunset Orange Met
2015 328d X-Drive Touring M-Sport (Traded) 2015 Audi S4 Sepang Blue P+ | DSG | Tech Package | Adaptive Suspension | B&O 2015 Audi S3 Misano Red | 19" Sport pack w/Mag Ride | B&O 1983 Porsche 944 All stock |
08-03-2015, 11:31 AM | #20 | |
Rep 18
08-03-2015, 11:35 AM | #21 |
Rep 18
Montreal must have the WORST roads in the country.
Anyways, so in the end, I will be buying LivFast's wheels and tires. And I will mount my winter tires onto my existing wheels. So I guess something good came out of this after all. |
08-03-2015, 11:56 AM | #22 |
Rep 514
Good thing you have a good friend
