09-16-2023, 11:00 AM | #111 | |
Rep 51
I had read multiple threads on intercoolers, several in here and found lots of great information here. I even thought about the ATM, but since it falls into to the tune/fin catagory as the Wagner I looked at it since it’s easier to get.
2016 BMW 428i F32 Coupe N26, Midnight Blue/Tan interior, CSF 8115B, FBO's, Navardi Stage 2 tune, HiFlo Cat and Mid-Pipe, Valvetronic Axle Back, H&R Super Sport springs, 20x9 33et 20x10.5 46et, 245/30ZR20 285/25ZR20, updated from Sportline to M-Sport Exterior
09-16-2023, 12:59 PM | #112 | |
Rep 4,333
i'd get MAD Race over CSF or Wagner Comp 2 used MAD Race in classifieds https://f30.bimmerpost.com/forums/sh....php?t=2044110 used ATM in classifieds https://f30.bimmerpost.com/forums/sh....php?t=2043607 . Last edited by alohasurftoad; 09-16-2023 at 01:12 PM.. |
09-16-2023, 01:06 PM | #113 | |
Rep 51
alohasurftoad3081.50 |
09-16-2023, 01:41 PM | #114 |
Rep 51
Went ahead and got the CSF 8115B.
Thanks for the replies.
09-16-2023, 05:02 PM | #115 |
Rep 51
I swear the CSF 8115 core dimensions must be a NASA level secret, can find it anywhere. LoL.
09-16-2023, 07:49 PM | #116 |
Rep 190,807
5.5"
09-16-2023, 08:19 PM | #117 |
Rep 51
09-17-2023, 09:59 AM | #118 | |
Rep 190,807
to answer your question, the CSF is enough for N26 FBO stage 2
HELLCO24.00 |
09-17-2023, 10:58 AM | #119 | |
Rep 51
I agree on the varying opinions. Thank you for your help. -Mike
09-18-2023, 11:37 AM | #120 |
Rep 190,807
09-27-2023, 09:15 AM | #121 |
Rep 51
Not sure if this is an intercooler design issue or a boost pipe issue.
Running into an issue that is keeping me from finishing my CSF 8115B intercooler and FTP SG71335F hard pipe installation on my 2016 428i F32 N26. Every site I check shows this to be correct pipe kit for my car when I enter the car specs, but obviously something is wrong here. The hard pipe that goes from the turbo to the intercooler will not line up with the turbo. The turbo outlet pipe is not matching up with turbo outlet. It's too long and/or the wrong angle, putting the pipe above the turbo outlet by a good bit, it's actually almost touching the EWG which sits above the turbo housing. The first image shows how far apart the pipe is vs the turbo outlet. The turbo outlet is in the LH lower part of the picture, the boost pipe inlet is in the RH upper part of the picture. Pipe is fully seated at the intercooler. I can't tighten up the intercooler retaining screws any further. If I tighten them up all the way the pipe will probably break the EWG. Has anybody run across this? What is the fix? Thanks in advance. |
09-27-2023, 09:25 AM | #122 |
Rep 190,807
Boost pipes dont line up with all intercoolers, unlike the charge pipe.
Given that the stock boost pipe is not prone to failure, i recommend keeping it
HELLCO24.00 |
09-27-2023, 09:43 AM | #123 |
Rep 51
09-28-2023, 06:36 PM | #124 |
Rep 1,065
CSF and the ATM intercooler the boost pipe doesn’t fit. It fits on the n55, but not n20.
MY13: TTE400 Stage 2 turbo.
e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block Build Thread: https://f30.bimmerpost.com/forums/sh....php?t=1742413 IG + YT: Sqwin_n20 |
09-28-2023, 09:11 PM | #125 |
Rep 190,807
09-28-2023, 11:19 PM | #126 | |
Rep 51
Doesn't seem to be a "direct drop-in replacement" to me. The F32 N20 is in their Fitment Guide for the 8115. Last edited by HELLCO; 09-28-2023 at 11:27 PM.. |
09-28-2023, 11:32 PM | #127 | |
Rep 1,065
I’m telling you regardless of what the documents say the CSF intercooler and aftermarket boost pipes don’t fit. CSF Copied ATM and ATM has a full disclosure some boost pipes fit and some don’t.
HELLCO24.00 |
09-29-2023, 09:57 AM | #128 | |
Rep 190,807
It will fit perfectly with the stock boost pipe, which is what CSF claims. they never say it will fit with every other aftermarket boost pipe. To be fair, this is not a CSF-specific issue, most aftermarket intercoolers will not fit with all aftermarket boost pipe. Given that the intercooler is the more important upgrade, i would not choose my FMIC bas on my boost pipe, i'd rather keep the boost pipe stock and get the best intercooler
HELLCO24.00 |
09-29-2023, 12:45 PM | #129 |
Rep 51
I understand, it's just very frustrating when you do the research to make sure everything you're ordering fits your car per the manufactures claims, then upon execution, it's problem after problem,.... after problem.
Thank you everyone who's responded to my questions along the way. |
mike@x-ph.com24200.50 |
