07-08-2017, 07:59 PM | #23 | ||
Rep 322
Hope this helps |
07-08-2017, 09:59 PM | #24 |
Rep 2,981
Drives: 2013 BMW F30 EBII
You don't even have to pull the ebrake...with foot on the brake, just turn the car off and it goes into park automatically.
Drives: 2011 Porsche 958, 1965 Chevy C10, 1988 Porsche 944 Sold:2010 e90 Montego Blue, 2013 F30 EBII, 2013 Tangerine Scream Ford Focus ST, 2006 Mini R50,2004 VW Touareg, 2012 Camaro Convertible, 2008 Porsche 911 Convertible, 2007 Corvette, 2004 BMW e64 convertible, 2000 Dodge Dakota, 1999 Ford F150, 1999 Porsche Boxster, 1999 Ferrari Modena, 1992 BMW e36, 1990 Nissan 240sx, 1979 Celica, 1974 Mustang II
My Build Thread |
07-08-2017, 10:02 PM | #25 | |
Rep 322
Not sure how come people that have done it can?t share then info. It would make it so much easier |
roll_the_dice508.00 |
11-02-2017, 02:37 PM | #27 | |
Rep 306
What does the 330e use the button for? |
11-13-2017, 11:09 AM | #28 |
Rep 2,981
Anyone tried this swap yet? I can't find a DCT shifter for sale...
My Build Thread |
11-13-2017, 12:56 PM | #29 | |
Rep 306
https://rover.ebay.com/rover/0/0/0?m...2F152506949302 https://rover.ebay.com/rover/0/0/0?m...2F272895234938 Look closely at images in first link and you can see section of shifter frame that would need removal/modification to fit in F3x/F4x center console, though it appears it could most likely be cut off on both sides. Last edited by kabrichx; 11-13-2017 at 01:13 PM.. |
11-26-2017, 04:31 AM | #30 |
Rep 129
And somebody have more informations yet? Did somebody try it? Is it Plug n Play except the P Button? Is the Cable Connection the same? Any Coding require?
12-18-2017, 12:52 AM | #31 | |
Rep 7
It works!! Im able to shift into all gears. I can get park when in drive by pressing the Start/Stop button. But there is only one issue. At startup or at a full stop the message "Not possible to change gear position" appears. Seems some coding will be the next step. Last edited by icbmwsnpdx; 12-18-2017 at 01:13 AM.. |
12-18-2017, 06:29 AM | #32 |
Rep 1,383
I might be being dumb here, but surely can't you just split open the pre-existing shifter and follow the circuit for the park button, then wire it up the same as to the gearbox button on the DCT shifter? My only worry would be matching the functionality of the different modes (manual, reverse, neutral etc)
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) |
12-19-2017, 06:30 AM | #33 | |
Rep 216
Drives: F30 335i PWG
12-19-2017, 04:18 PM | #34 |
Rep 710
Drives: 23 M3 Competition
I'm seriously debating on doing this. I can't stand the F30 shifter.
14 F30 N55 AWD SpeedTech EFR-8374, E70 MHD, Motive tuned
23 M3 Competition - Stock |
12-20-2017, 12:34 AM | #35 |
Rep 7
Correct, just the warning messages. I think the main issue is the unlock button on the stock shifter missing on the DCT shifter. But stepping on the brake unlocks the DCT shifter from park. Maybe if just the FEM was coded to DTC, and not the ICM or the KOMBI then it would ignore the missing unlock button and suppress the message. Any ESYS experts out there? I love the feel and way this DCT shifts. |
12-20-2017, 12:38 AM | #36 | |
Rep 216
2013 335i BSM ~ Stage 3 turbo, forged internals and more check out my build thread https://f30.bimmerpost.com/forums/sh...7#post23789807
12-20-2017, 04:56 PM | #37 |
Rep 7
12-29-2017, 12:30 AM | #38 | |
Rep 10,473
01-11-2018, 11:16 PM | #40 |
Rep 10,473
You need to be more precise than that unless you are planning to do major surgery.
01-12-2018, 03:27 PM | #41 |
Rep 1,953
Drives: 2013 328i xDrive
01-12-2018, 11:28 PM | #42 |
Rep 216
would the shifter from an E9x or E6x M car work by any chance? As they are much cheaper on eBay
01-12-2018, 11:32 PM | #43 |
Rep 10,473
01-17-2018, 05:13 PM | #44 |
Rep 7
